3 Replies Latest reply on Sep 1, 2009 11:53 PM by Flex harUI
    Timer class does not work
    _gilado
      I needed a periodic showStatus funcation and was reading the setInterval docs where it suggest to use the Timer class instead.
      I gave it a try, it won't work. However setInterval does work
      Compiled using flex sdk "Version 3.3.0 build 4852"
      The player's about sends me to http://www.adobe.com/software/flash/about/ ,  which reports "You have version 10,0,32,18 installed"
      Below is the code with setInterval enabeld (works) simply comment this line and uncomment the section that uses a Timer above it to test the other case.
      package
          import flash.display.Sprite;
          import flash.text.TextField;
          import flash.utils.setInterval;
          import flash.utils.Timer;
          import flash.events.TimerEvent;
          import flash.events.Event;
          public class Main extends Sprite
              private var statusLine:TextField;
              private var statusText:String = "";
              private var statusTimer:Timer;
              private var timerStep:Number = 100;
              private var elapsedTime:Number = 0;
              public function Main()
                  statusLine = new TextField();
                  statusLine.width = 400;
                  statusLine.height = 400;
                  statusLine.multiline = true;
                  statusLine.wordWrap = true;
                  statusLine.text = "Starting";
                  addChild(statusLine);
                  // NOTE: Adobe livedocs for setInterval says:
                  // "Instead of using the setInterval() method, consider creating
                  //  a Timer object, with the specified interval, ..."
                  // statusTimer = new Timer(timerStep,0);
                  // statusTimer.addEventListener("timer",showStatus); // One sample shows it this way
                  // statusTimer.addEventListener(TimerEvent.TIMER,showStatus); // The other sample reads like this
                  // statusTimer.start();
                  // except it does not work! stick with setInterval() for now
                  setInterval(showStatus,timerStep);
              private function showStatus():void
                  var txt:String = "";
                  elapsedTime += timerStep;
                  txt += " > " + Math.round(elapsedTime/100)/10 + " < ";
                  statusLine.text = txt;
        • 1. Re: Timer class does not work
          sri harsha namala Level 2
                  Once Check the Following Code. its Working
          package {
          public class TestTimer extends Sprite
                  private var counter:int=0;
          public function TestTimer()
                      statusTimer=new Timer(100);
                      statusTimer.addEventListener(TimerEvent.TIMER,fireTimer);
          private function fireTimer(event:TimerEvent):void
          statusLine.text="fired Timer"+counter;
          counter++;
          • 2. Re: Timer class does not work
            _gilado Level 1
            Your'e right! the key is to pass the timer event to the call back function.
            I made this one change to my original code and it started to work:
            I replaced
            with
            private function showStatus(event:TimerEvent):void
            • 3. Re: Timer class does not work
              Flex harUI Adobe Employee
              You should have gotten a runtime error if you didn't do that.
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              Blog: http://blogs.adobe.com/aharui
