7 Replies Latest reply on Sep 2, 2009 3:50 AM by sathiyabala
    How to set focus on a textbox
    sathiyabala Level 1
      Hai
              I need to set focus on the textbox, now i have used the code which i have given below, it is focusing on the textbox but i am not able to tye anything on the textbox only after the user clicks using mouse on the txtbox , after that oly i can type the txt on it.
              Without onclick of the txtbox, in onfocus itself i need to type the text in txtbox.
              I am using the setfocus in the login page for the username, but not able to type the txt.
              Login page is in flex, i used to call the swf directly while build. it is not passed through HTML
              can anyone help me.
      Thanks In Advance
      private
      function getfocusLogin(event:Event):void{
      userName.addEventListener(KeyboardEvent.KEY_DOWN, EnterKeyEvent);
      password.addEventListener(KeyboardEvent.KEY_DOWN, EnterKeyEvent);
      log.addEventListener (KeyboardEvent.KEY_DOWN , EnterKeyEvent);
      userName.setFocus();
      private function EnterKeyEvent (event:KeyboardEvent):void{
      if(event.keyCode == 13){
      login();
      <mx:HTTPService
      id="logIn" showBusyCursor="true" useProxy="false" url="../LoginAction.do" method="POST" result="loginresultHandler(event)" fault="loginfaultHandler(event)"
      <mx:request>
      <userName>{userName.text}
      </userName>
      <password>{password.text}
      </password>
      </mx:request>
      </mx:HTTPService>
        • 1. Re: How to set focus on a textbox
          Flex harUI Adobe Employee
          This is a common issue with Flash in Browsers.  AFAIK there is only a solution for IE, not other browsers and it involves JavaScript call setFocus on the object tag on one of the document or window events.  If you google you'll find it.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: How to set focus on a textbox
            sathiyabala Level 1
            Hai
                        Thank you for your reply, but i am not able to get any from google, any other thing can u suggest
                        Emergency pl
            Thanks in Advance
            • 3. Re: How to set focus on a textbox
              ShardulSingh Level 3
              Pls find the solution of your problem, I have replied this question for someone else here.Pls let me know if you have any issue still.
              http://forums.adobe.com/message/2132197#2132197
              Hope this will fullfill your requirement.
              with Regards,
              Shardul Singh Bartwal
              • 4. Re: How to set focus on a textbox
                sathiyabala Level 1
                Hai Shardul Singh Bartwal
                               Thank u For your reply , but i am not using html, directly the swf oly i am using.
                               In build.xml i will mention where the swf should be placed after build, so it will be placed in that path, for login how to send swf from html
                              Can u help me
                Thanks In Advance
                • 5. Re: How to set focus on a textbox
                  Sorry to say I am not getting your problem.
                  But what I will suggest dont do any thing else,simply open the swf which you have been created after building your application i.e. under the
                  'bin-debug' or 'bin-release' folder.I think in that it will be already working fine but in builder during running or debugging you will not see it working.
                  • 6. Re: How to set focus on a textbox
                    sathiyabala Level 1
                                    I implemented as u said, the cursor is blinking over that textbox and the focus is also there, but not able to type anyting
                                               in that textbox....
                    FLEX CODE
                    private function getfocusLogin(event:Event):void{
                    mx:FormItem
                    label="UserName" color="#F29E0C" themeColor="#EB8A0B" fontFamily="Verdana"
                    <mx:TextInput id="userName" x="717" y="273" width="140" color="#050505" name="user" creationComplete="getfocusLogin(event)"
                    </mx:FormItem>
                    HTML CODE
                    html>
                    head>
                    title>GRC Project</title>
                    <link rel="shortcut icon" href="<%=request.getContextPath()%>/imgs/login/favicon.ico" >
                    <script>
                    function
                    focusFlash(){
                    setFocus.focus();
                    lapFocus.focus();
                    functi
                    on fetchresolution(){
                    if ((screen.width < 800 ) && (screen.height < 600)){
                    ale
                    rt("Lowest height "+ screen.width);
                    ale
                    rt("Lowest width"+ screen.height);
                    }else
                    if ((screen.width <= 1024) && (screen.height <= 768)){
                    obj = document.getElementBy
                    Id("desktop");
                    obj.style.visibility
                    = 'visible';
                    }else
                    if ((screen.width <= 1280 ) && (screen.height <= 800)){
                    Id("laptop");
                    = 'visible';
                    </script>
                    head>
                    body bgcolor="#FFFFFF" body scroll="no" marginheight=0 topmargin=0 leftmargin=0 bottommargin=0 rightmargin=0 onLoad="fetchresolution()">
                    div id="desktop" style="position: absolute; visibility: hidden;">
                    OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" id="setFocus" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0"
                    height
                    ="600" width="1020" id="Charting">
                    <param name=movie value="<%=request.getContextPath()%>/pages/flexreportlogin/flexreportlogin.swf">
                    <param name="quality" value="best" />
                    <param name="scale" value="noscale" />
                    <param name="salign" value="t" />
                    <param name="wmode" value="opaque" />
                    <param name="allowScriptAccess" value="sameDomain" />
                    <EMBED src="<%=request.getContextPath()%>/pages/flexreportlogin/flexreportlogin.swf" allowScriptAccess="sameDomain" quality=high NAME="Charting" ALIGN="" TYPE="application/x-shockwave-flash" height="600" width="1020"
                    PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer">
                    </EMBED>
                    OBJECT>
                    div>
                    div id="laptop" style="position: absolute; visibility: hidden;">
                    OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" id="lapFocus" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0"
                    width
                    ="1275" HEIGHT="650" id="lapchart">
                    <EMBED src="<%=request.getContextPath()%>/pages/flexreportlogin/flexreportlogin.swf" allowScriptAccess="sameDomain" quality=high NAME="lapchart" ALIGN="" TYPE="application/x-shockwave-flash" width="1275" HEIGHT="650"
                    </EMBED>
                    OBJECT>
                    div>
                    body>
                    html>
                    • 7. Hai Shardul Singh Bartwal that is working fine Thank u
                      sathiyabala Level 1
                                     Thank u For your reply , It is working fine, it is correct answer, thank u very much....
