2 Replies Latest reply on Sep 2, 2009 6:08 AM by San Question
    Dynamic Object Creation in MXML Class
    San Question
      Hi ,
      1)         In the below code i have created a static error box in MXML file . can u please help me to create the dynamic errorbox instead of the below static object.
      Static Object Creation :
          <mx:Fade id="ViewStack_EffectStart" duration="500" alphaFrom="0.0" alphaTo="1.0"/>
          <mx:Fade id="ViewStack_EffectEnd" duration="500" alphaFrom="1.0" alphaTo="0.0"/>
      <comp:ErrorBox id="errorBox" active="{active}" showEffect="{ViewStack_EffectStart}" hideEffect="{ViewStack_EffectEnd}"/> .
      2).  The above static objects is working fine, but the problem is that we have lot of similiar static object which creates a memory issue.If we create dynamic objects, will it avoid the issue.Is dynamic objects advisible?.
      Thanks in advance.Please reply ASAP.
      Thanks ,
      San.
        • 1. Re: Dynamic Object Creation in MXML Class
          Andrew Rosewarn Level 3
          You need to create your errorbox as a component with some public properties for things like the error message as below
          <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="318" height="158"  backgroundColor="#EDDDDD">
              <mx:Script>
                  <![CDATA[
                      [Bindable]
                      private var _errorMessage:String;
                      [Bindable]
                      public function set errorMessage(value:String):void {
                          _errorMessage = value;
                      public function get errorMessage():String {
                          return _errorMessage;
              </mx:Script>
              <mx:Text x="20" y="24" text="{_errorMessage}" width="279" height="114"/>
          </mx:Canvas>
          Then you can set the errror Message for diffferent errors as shown below in the main app
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"  >
              <mx:Script>
                  <![CDATA[
                      import mx.managers.PopUpManager;
                      private var errorBox:ErrorBox;
                      private function showError():void {
                          errorBox = new ErrorBox();
                          errorBox.errorMessage = 'This is an error';
                          PopUpManager.addPopUp(errorBox,this);
                          PopUpManager.centerPopUp(errorBox);
                      private function removeError():void {
                          PopUpManager.removePopUp(errorBox);
              </mx:Script>
              <mx:Button x="42" y="41" label="Show Error" width="106" click="showError()"/>
              <mx:Button x="42" y="71" label="Remove Error" width="106" click="removeError()"/>
          </mx:Application>
          To take if further and to fit your needs you'll probably want to add more public properties to set things like error icons or buttons to select and return a response, warning messages etx.
          Hope that helps
          Andrew
          • 2. Re: Dynamic Object Creation in MXML Class
            San Question Level 1
            Hi ,
                 The below dynamic object creation is not working . can u please guide me to create dynamic object.
                  with curly brace initilization ( active = "{active}" ).
            Eg:
            Dynamic Object Creation:
            Eg:
                       var   errorBox:ErrorBox  = new ErrorBox ();
                      errorBox.active="{active}";
                      errorBox.showEffect="{ViewStack_EffectStart}";
                      errorBox.hideEffect="{ViewStack_EffectEnd}";
            Santhosh.
