5 Replies Latest reply on Sep 4, 2009 10:19 PM by 435.mahesh
    problem in linkbar?
    435.mahesh Level 1
      Hi
      i have an applicationcontrolbar.Inside that linkbar will be thr.
      But my requirement is i want linkbar to right side in applicationcontrolbar.But it is
      not moving to right side.I have x and y attributes for both(applicationcontrolbar and linkbar).
      plz help me
      Regards
      D.Mahesh Babu
        • 1. Re: problem in linkbar?
          Bhavika_Patil
          Did you put link bar in HBOX?
          • 2. Re: problem in linkbar?
            Andrew Rosewarn Level 3
            HI
            ApplicationBar has a horizontalAlignment property set that to right
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"  >
                <mx:Script>
                    <![CDATA[
                </mx:Script>
                <mx:ApplicationControlBar y="10" left="10" right="10" horizontalAlign="right">
                    <mx:LinkBar dataProvider="['One','Two,'Three'']">
                    </mx:LinkBar>
                </mx:ApplicationControlBar>
            </mx:Application>
            If you also need items to the left use a Spacer and set the width to 100% to push them apart.
            Hop this helps
            Andrew
            • 3. Re: problem in linkbar?
              435.mahesh Level 1
              Thanq.
              i have applicationcontrobar.
              Inside two buttons(home and admin) and linkbar(aplat|st) and linkbutton(signout).
              applicationcontrolbar look like this
              home,admin                                           ap|at|st   signout
              How to achieve this?
              Regards
              D.Mahesh Babu
              • 4. Re: problem in linkbar?
                Use a spacer to seperate
                    <mx:Script>
                        <![CDATA[
                    </mx:Script>
                        <mx:Button label="Button"/>
                        <mx:Spacer width="100%"/>
                        </mx:LinkBar>
                </mx:Application>
