2 Replies Latest reply on Sep 2, 2009 8:29 AM by Barna Biro
    MXML Dynamic Object Creation
    San Question
      Hi ,
      Static Object Creation :
      Eg:
          <mx:Fade id="ViewStack_EffectStart" duration="500" alphaFrom="0.0" alphaTo="1.0"/>
          <mx:Fade id="ViewStack_EffectEnd" duration="500" alphaFrom="1.0" alphaTo="0.0"/>
      <comp:ErrorBox id="errorBox" active="{active}" showEffect="{ViewStack_EffectStart}" hideEffect="{ViewStack_EffectEnd}"/> .
      The above static objects is working fine, but the problem is that we have lot of similiar static object which creates a memory issue.If we create dynamic objects, will it avoid the issue.Is dynamic objects advisible?.
      Thanks in advance.Please reply ASAP.
      Thanks ,
      San.
        • 1. Re: MXML Dynamic Object Creation
          babo_ya Level 3
          hmn.. I don't understand your questions fully.
          What about create the fade object in "Model" and reference the same Fade object for all dynamic objects?
          or r u asking to find out how to create fade in actionscript?
          var fade:Fade = new Fade();
          fade.target = this;
          fade.alphaFrom = 0;
          fade.alphaTo = 1;
          fade.play();
          hope this helps,
          BaBo,
          • 2. Re: MXML Dynamic Object Creation
            Barna Biro Level 3
            I don't really understand your problem either. What do you want to create dynamically? The tween? The component itself? Either way, I don't really see why would that be of much help. It would be great if you could try to shed some light on this because your description/question was totally cryptic.
