4 Replies Latest reply on Sep 2, 2009 8:09 AM by 3adlouz
    Datgrid and Item Renderer scrollling problem
    3adlouz
      Hello,
      I have a Datgrid containign item rendrer as follows :
      <mx:DataGrid  width="800" id="gridSecondaire" styleName="dataGridStyle" verticalScrollPolicy="off" headerHeight="30" >
                <mx:columns>
                     <mx:DataGridColumn rendererIsEditor="true"
                                                editorDataField="result"
                                                itemRenderer="com.cdf.intra_cmmi.view.advancedTree.BodyDetailDocumentRenderer" />
                </mx:columns>
           </mx:DataGrid>
      The problem is I when i scroll the datagrid the  rows do not stay in the same position how to solve this please ?
        • 1. Re: Datgrid and Item Renderer scrollling problem
          babo_ya Level 3
          Can you copy/paste your itemRenderer? and also the main mxml file
          BaBo,
          • 2. Re: Datgrid and Item Renderer scrollling problem
            ShardulSingh Level 3
            Pls add the code below inside the script tag of Your ItemRenderer.
            override public function set data(value:Object):void
                         super.data = value;
            You can also visit http://forums.adobe.com/message/2216445#2216445  for more detail.
            with Regards,
            Shardul Singh Bartwal
            • 3. Re: Datgrid and Item Renderer scrollling problem
              3adlouz Level 1
              Here the item Renderer
              ===================ITEM RENDRER==========================
              <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" height="28" width="388" creationComplete="init(event)"  click="clickTexte(event);">
                  <mx:Script>
                  <![CDATA[
                      [Embed(source="images/icon/tree_defaultLeafIcon.png")]
                      public static const tree_defaultLeafIcon:Class;
                      [Embed(source="images/icon/tree_pptLeafIcon.png")]
                      public static const tree_pptLeafIcon:Class;
                      [Embed(source="images/icon/tree_xlsLeafIcon.png")]
                      public static const tree_xlsLeafIcon:Class;
                      [Embed(source="images/icon/anglais.png")]
                      private var anglaisIcon:Class;
                      import com.sqli.intra_cmmi.constants.ConstantAssets;
                      private function clickTexte(event:MouseEvent):void {
                              var fileReference:FileReference = new FileReference();
                              fileReference.download(new URLRequest(data.chemin_document));
                      private function init(event:Event):void {
                          import com.sqli.intra_cmmi.vo.DocumentVO;
                          import mx.controls.Alert;
                          import mx.collections.ArrayCollection;
                              var nom_document:String =data.nom_document as String;
                              var description_document:String = data.description_document as String;
                              var language_document:String =data.language_document as String;
                              var ext:String = data.ext as String;
                              var type:String = data.type_document as String;
                              var chemin_document:String = data.chemin_document as String;
                              switch (type)
                                      case "Modèle":
                                          imageTypeDoc.source = ConstantAssets.modele;
                                          break;
                                      case "Guide":
                                          imageTypeDoc.source = ConstantAssets.guide;
                                          break;
                                      case "Document":
                                          imageTypeDoc.source = ConstantAssets.document;
                                          break;
                                      case "Outils":
                                          imageTypeDoc.source = ConstantAssets.outils;
                                          break;
                                      case "Check-liste":
                                          imageTypeDoc.source = ConstantAssets.checklist;
                                          break;
                                      default:
                              nom.text=nom_document+' ('+ext+')';
                              if(language_document!='1036'){
                                  imageAnglais.source=anglaisIcon;
                              if(description_document!=""){
                                  imageDescription.source=anglaisIcon;
              </mx:Script>
                  <mx:Image id="imageTypeDoc" x="5" y="5" height="15" width="15"   />
                  <mx:Text x="23" y="3" width="326" id="nom"/>
                  <mx:Image x="351" y="5" height="15" width="15" id="imageAnglais"/>
                  <mx:Image x="370" y="5" height="15" width="15" id="imageDescription"/>
              </mx:Canvas>
              ======================Main.MXLM  (Blue Code part) ===============================
                  width="830"  creationComplete="init()">
                  <mx:Script>
                      <![CDATA[
                          import com.sqli.intra_cmmi.services.MainService;
                          import mx.rpc.events.FaultEvent;
                          import mx.rpc.events.ResultEvent;
                          import com.sqli.intra_cmmi.controller.ProduitController;
                          import com.sqli.intra_cmmi.services.VerticalMenuService;
                          //import com.sqli.intra_cmmi.services.MainService;
                          import com.sqli.intra_cmmi.vo.ProduitVO;
                          public var objectList : Array = new Array();
                          public function init():void
                              myProc.listeDomaineProcessus();
                              if(VerticalMenuService.getInstance().produitVerticalMenu.getChildren().length > 0)
                                  // On positionne l'accordion des produits sous l'accordion commun
                                  VerticalMenuService.getInstance().produitVerticalMenu.y = VerticalMenuService.getInstance().verticalMenu.height - 49;
                                  MainService.getInstance().lefter.addChild(VerticalMenuService.getInstance().produitVertic alMenu);
                              var id:String;
                              id=ProduitController.getInstance().currentProduitId;
                              if(id!=null)
                                  myProd.getProduitDescription(id);
                                  myProd.getDocumentPrincipauxByProduit(id,1);
                                  myProd.getDocumentSecondaireByProduit(id,0);
                                  myProd.getRolesProduit(id);
                                  myProd.getAjustementProduitByID(id);
                          private function getDataListener_listeDomaineProcessus(event:ResultEvent):void
                              //refPhase= new ArrayCollection();
                              this.objectList = event.result as Array;
                              // Peupler l'accordion
                              ProduitController.getInstance().populateVerticalMenu(this.objectList);
                          private function getDataListener_getDocumentSecondaireByProduit(event:ResultEvent):void
                              var obje:Array = event.result as Array;
                              if(obje.length>0)
                                  gridSecondaire.dataProvider = event.result as Array;
                                  gridSecondaire.rowHeight = 33;
                                  gridSecondaire.height = obje.length*33+30;
                                  var maximumHeight : int = 228;
                                  if ( gridSecondaire.height > maximumHeight){
                                    gridSecondaire.verticalScrollPolicy = "on";
                                    gridSecondaire.height = maximumHeight;
                              else
                                  gridSecondaire.visible=false;
                                  gridSecondaire.includeInLayout=false;
                          override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                              super.updateDisplayList(unscaledWidth, unscaledHeight);
                              // Peupler l'accordion (rafraichissement lors du passage d'une rubrique à une autre)
                          private function getDataListener_getProduitDescription(event:ResultEvent):void{
                                  description.title=ProduitVO(event.result).nom_produit;
                                  idPanelDescription.htmlText=ProduitVO(event.result).description_produit;
                          private function faultListener(event:FaultEvent):void {
                                  Alert.show(event.fault.message, "Error");
                  </mx:Script>
                  <mx:VBox verticalGap="20"  horizontalCenter="0" top="10" bottom="10">
                  <mx:Panel width="800" height="121" id="description"  styleName="stylePanel"  >
                      <mx:Label paddingLeft="5"  paddingRight="5" paddingTop="40"  width="100%" id="idPanelDescription"/>
                  </mx:Panel>
                      <mx:columns>
                          <mx:DataGridColumn rendererIsEditor="true"  editorDataField="result"
                           itemRenderer="com.sqli.intra_cmmi.view.advancedTree.BodyDetailDocumentRenderer"
                            headerText="Documents secondaires"/>
                          <mx:DataGridColumn rendererIsEditor="true"  editorDataField="result" dataField="livrable_document" headerText="Livrables" width="100"/>
                      </mx:columns>
                  </mx:DataGrid>
                  </mx:VBox>
                  <mx:RemoteObject id="myProc" destination="zend" source="ProcessusService" showBusyCursor="true" fault="faultListener(event)">
                      <mx:method name="listeDomaineProcessus" result="getDataListener_listeDomaineProcessus(event);" />
                  </mx:RemoteObject>
                  <mx:RemoteObject id="myProd" destination="zend" source="ProduitsService" showBusyCursor="true" fault="faultListener(event)">
                      <mx:method name="getRolesProduit" result="getDataListener_getRolesProduit(event);" />
                      <mx:method name="getDocumentPrincipauxByProduit" result="getDataListener_getDocumentPrincipauxByProduit(event);" />
                      <mx:method name="getDocumentSecondaireByProduit" result="getDataListener_getDocumentSecondaireByProduit(event);" />
                      <mx:method name="getAjustementProduitByID" result="getDataListener_getAjustementProduit(event);" />
                      <mx:method name="getProduitDescription" result="getDataListener_getProduitDescription(event);" />
                  </mx:RemoteObject>
              </mx:Canvas>
              • 4. Re: Datgrid and Item Renderer scrollling problem
                3adlouz Level 1
                I did but it does not solve the problem
                2009/9/2 ShardulSingh <forums@adobe.com>
                             super.data = value;
                more detail.
                with Regards,
