6 Replies Latest reply on Sep 3, 2009 8:39 AM by sergei_developer
    BlazeDS message error
    sergei_developer
      I get message error when I used remoteobject .  I define it in remote-config.xml :
      <destination id="myUtils" >
           <properties>
              <source>com.mtsys.utils.HTTPUtils</source>
              <scope>session</scope>
           </properties>
          </destination>
      but "destination 'myUtils' " doesn't exist.
        • 1. Re: BlazeDS message error
          alejandrorrr Level 1
          Sergei,
                    Based on what you posted it is very difficult to help you troubleshoot this one. I will shoot in the dark here:
          • be sure to check that the services-config.xml is properly configured so you Flex/Air app will be able to reach the endpoint
          • If you are using AIR remember that app is not ran in the context of your BlazeDS/Tomcat but in a desktop so a special config is needed to setup remoting. (you can google that one)
          • make sure you have at least one default channel.
          As i said, it is very hard with no context, maybe if you post more info on your problem we could be of help
          Greetings
          Alex
          • 2. Re: BlazeDS message error
            sergei_developer Level 1
            Hi, Alex!
            I has left service-config as default . And for remoting-config as:
            <?xml version="1.0" encoding="UTF-8"?>
            <service id="remoting-service"
                class="flex.messaging.services.RemotingService">
                <adapters>
                    <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
                </adapters>
                <default-channels>
                    <channel ref="my-amf"/>
                </default-channels>
                <destination id="helloWorld" >
                 <properties>
                    <source>example.HelloWorld</source>
                 </properties>
                </destination>
            </service>
            And don't work for :
                <adapters>
                </adapters>
                <default-channels>
                 </default-channels>
                 <properties>
                 </properties>
                </destination>
            </service>
            • 3. Re: BlazeDS message error
              I don't understand what's wrong. All classes are existing
              • 4. Re: BlazeDS message error
                I'm sorry , Alex . It's my mistake . I defined wrong path for my sevice - config!
                • 5. Re: BlazeDS message error
                  Sergei, Im happy to hear you sorted that one out. I use BlazeDS all the time and it is a wonderful tool, but there are a lot of not so obvious tricks to take advantage of the tool. Whenever in doubt also check out LiveCycle docs, as it is BlazeDS granddaddy.
                  Cheers
                  Alex
                  • 6. Re: BlazeDS message error
                    Alex, I use BlazeDS near two month and had to fix too many details to use it (like blazeDS and JBoss). I'll check out LiveCycle docs. It was strongly recomended to use next frameworks:
                    http://puremvc.org/
                    http://mate.asfusion.com/
                    http://opensource.adobe.com/wiki/display/cairngorm/Cairngorm
                    May be you are using it or will use
