20 Replies Latest reply on Feb 27, 2010 5:13 PM by djkencloud
    Snowleopard & Flash CS4 (Crash)
    axxxo
      Hello everyone
      I have a weird problem on my late 2008 Macbook Pro. I installed Snowleopard, everything works fine so far. After then, I installed my CS4 (Design Premium). From the additional installer on the disc, I also installed "Rosetta".
      When I try to open Flash CS4 now, it works so far. When I try to create a new project (e.g. Actionscript 3.0), it takes about 4 Seconds and Flash crashes. I got the same problems with Fireworks CS4 too.
      It might be a hardware-problem. On my brand-new Macbook Air, the CS4 package works like a charm. No crashes.
      Is there any fix available? Or do I have to deactivate something that I can get it work?
      Here's the crash-report:
      Process:         Adobe Flash CS4 [214]
      Path:            /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/Adobe Flash CS4
      Identifier:      com.adobe.flash-10.0
      Version:         10.0.2.566 (10.0.2)
      Code Type:       X86 (Native)
      Parent Process:  launchd [100]
      Date/Time:       2009-09-02 18:21:38.646 +0200
      OS Version:      Mac OS X 10.6 (10A432)
      Report Version:  6
      Interval Since Last Report:          4761 sec
      Crashes Since Last Report:           1
      Per-App Interval Since Last Report:  101 sec
      Per-App Crashes Since Last Report:   1
      Anonymous UUID:                      D6CAD354-2273-4019-882D-D02F97091804
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000000c
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      Java information:
      Exception type: Bus Error (0xa) at pc=0x95101de2
      Java VM: Java HotSpot(TM) Client VM (14.1-b02-90 mixed mode macosx-x86)
      Current thread (0x29000c00):  JavaThread "main" [_thread_in_native, id=-1606007552, stack(0xbf800000,0xc0000000)]
      Stack: [0xbf800000,0xc0000000]
      Java Threads: ( => current thread )
        0x2d0af000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1293451264, stack(0xb2d78000,0xb2e78000)]
        0x2d0ae400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1294508032, stack(0xb2c76000,0xb2d76000)]
        0x2d0ad400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1295564800, stack(0xb2b74000,0xb2c74000)]
        0x2900a800 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1325809664, stack(0xb0e9c000,0xb0f9c000)]
        0x29004c00 JavaThread "Finalizer" daemon [_thread_blocked, id=-1326866432, stack(0xb0d9a000,0xb0e9a000)]
        0x2d0a7000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1329614848, stack(0xb0afb000,0xb0bfb000)]
      =>0x29000c00 JavaThread "main" [_thread_in_native, id=-1606007552, stack(0xbf800000,0xc0000000)]
      Other Threads:
        0x2d0a3000 VMThread [stack: 0xb09f9000,0xb0af9000] [id=-1330671616]
        0x2d0b8000 WatcherThread [stack: 0xb2e7a000,0xb2f7a000] [id=-1292394496]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      par new generation   total 14336K, used 3635K [0x2d800000, 0x2e800000, 0x2e800000)
        eden space 12288K,  29% used [0x2d800000, 0x2db8ce50, 0x2e400000)
        from space 2048K,   0% used [0x2e400000, 0x2e400000, 0x2e600000)
        to   space 2048K,   0% used [0x2e600000, 0x2e600000, 0x2e800000)
      concurrent mark-sweep generation total 49152K, used 0K [0x2e800000, 0x31800000, 0x35800000)
      concurrent-mark-sweep perm gen total 12288K, used 4068K [0x35800000, 0x36400000, 0x39800000)
      Virtual Machine Arguments:
      JVM Args: -Djava.library.path=/Applications/Adobe Flash CS4/JVM/bin -Djava.awt.headless=true -Xmx128m
      Java Command: <unknown>
      Launcher Type: generic
      Physical Memory: Page Size = 4k, Total = 2048M, Free = 613M
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libTrueTypeScaler.dylib           0x95101de2 fnt_SH_Common(fnt_LocalGraphicStateType*, long*, long*, int*) + 87
      1   libTrueTypeScaler.dylib           0x95105fca fnt_SHZ(fnt_LocalGraphicStateType*) + 31
      2   libTrueTypeScaler.dylib           0x950fe4ae fnt_InnerExecute(fnt_LocalGraphicStateType*, unsigned char*, unsigned char*) + 59
      3   libTrueTypeScaler.dylib           0x950fe42d fnt_Execute(fnt_ElementType**, fnt_GlobalGraphicStateType*, unsigned char*, unsigned char*, void (*)(), memoryContext*, unsigned char, unsigned char, unsigned char) + 438
      4   libTrueTypeScaler.dylib           0x950fe261 RunFontProgram(fsg_SplineKey*, void (*)()) + 129
      5   libTrueTypeScaler.dylib           0x950fe0f9 CreateGlyphElement(fsg_SplineKey*, long, unsigned char, unsigned char) + 216
      6   libTrueTypeScaler.dylib           0x950fa5ad CreateScalerGlyphBlock(fsg_SplineKey*, memoryContext*, scalerGlyph const*) + 229
      7   libTrueTypeScaler.dylib           0x950fa417 AssureGlyphBlock(fsg_SplineKey*, memoryContext*, transformBlockCacheNode*, scalerGlyph*) + 180
      8   libTrueTypeScaler.dylib           0x950f664d TTGetStrikeSpecs + 598
      9   ...ple.ApplicationServices.ATS    0x98a482d5 HandleOFAScalerMessage + 1165
      10  ...ple.ApplicationServices.ATS    0x98a47dde SendStrikeMessage + 162
      11  ...ple.ApplicationServices.ATS    0x98a4b0e4 _eOFAGetStrikeSpecs + 471
      12  ...ple.ApplicationServices.ATS    0x98a45c47 _eGetGlyphVectorIndex + 994
      13  ...ple.ApplicationServices.ATS    0x98a450ef OldGlyphsCacheStrike(TStrike*, void (*)(StrikeSpecs const*, void const*), void*) + 136
      14  ...ple.ApplicationServices.ATS    0x98a44d3d _eGCGetStrikeMetrics + 65
      15  ...ple.ApplicationServices.ATS    0x98a439e3 _eATSFontGetHorizontalMetrics + 173
      16  ...ple.ApplicationServices.ATS    0x98a4391c ATSFontGetHorizontalMetrics + 76
      17  com.adobe.flash-10.0              0x007c4fbd 0x1000 + 8142781
      18  com.adobe.flash-10.0              0x007c6f5f 0x1000 + 8150879
      19  com.adobe.flash-10.0              0x007c6fcb 0x1000 + 8150987
      20  com.adobe.flash-10.0              0x007c38ae 0x1000 + 8136878
      21  com.adobe.flash-10.0              0x0078f048 0x1000 + 7921736
      22  com.adobe.flash-10.0              0x006a533c 0x1000 + 6964028
      23  com.adobe.flash-10.0              0x0078129e 0x1000 + 7864990
      24  com.adobe.flash-10.0              0x007875dd 0x1000 + 7890397
      25  com.adobe.flash-10.0              0x0074a681 0x1000 + 7640705
      26  com.adobe.flash-10.0              0x00754ff8 0x1000 + 7684088
      27  com.adobe.flash-10.0              0x008fe8d3 0x1000 + 9427155
      28  com.adobe.flash-10.0              0x0012c1de 0x1000 + 1225182
      29  com.adobe.flash-10.0              0x0012ca61 0x1000 + 1227361
      30  com.adobe.flash-10.0              0x008a601f 0x1000 + 9064479
      31  com.adobe.flash-10.0              0x0096612e 0x1000 + 9851182
      32  com.adobe.flash-10.0              0x008ca08a 0x1000 + 9212042
      33  com.adobe.flash-10.0              0x008c9350 0x1000 + 9208656
      34  com.adobe.flash-10.0              0x008c5c54 0x1000 + 9194580
      35  com.adobe.flash-10.0              0x008c5b29 0x1000 + 9194281
      36  com.adobe.flash-10.0              0x0095e8e9 0x1000 + 9820393
      37  com.adobe.flash-10.0              0x008c9350 0x1000 + 9208656
      38  com.adobe.flash-10.0              0x000e6179 0x1000 + 938361
      39  com.adobe.flash-10.0              0x008c5c54 0x1000 + 9194580
      40  com.adobe.flash-10.0              0x008c5b29 0x1000 + 9194281
      41  com.adobe.flash-10.0              0x005577da 0x1000 + 5597146
      42  com.adobe.flash-10.0              0x00557904 0x1000 + 5597444
      43  com.adobe.flash-10.0              0x0087a812 0x1000 + 8886290
      44  com.adobe.flash-10.0              0x00872439 0x1000 + 8852537
      45  com.adobe.flash-10.0              0x00872502 0x1000 + 8852738
      46  com.adobe.flash-10.0              0x00872b82 0x1000 + 8854402
      47  dvaui                             0x07d4f296 dvaui::controls::UI_Button::PerformAction(bool, dvacore::utility::Flags<unsigned char>) + 102
      48  dvaui                             0x07d4ff89 dvaui::controls::UI_Button::UI_DoMouseEvent(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 191
      49  com.adobe.flash-10.0              0x00873411 0x1000 + 8856593
      50  dvaui                             0x07e7104f dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 175
      51  dvaui                             0x07f1f193 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 151
      52  dvaui                             0x07f1f1c6 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 202
      53  dvaui                             0x07f1f1c6 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 202
      54  dvaui                             0x07f1f1c6 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 202
      55  dvaui                             0x07f1f1c6 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 202
      56  dvaui                             0x07f1f1c6 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 202
      57  dvaui                             0x07f1f1c6 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 202
      58  dvaui                             0x07e71b03 dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent const&, bool) + 89
      59  dvaui                             0x07e73811 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 193
      60  dvaui                             0x07ebd19d dvaui::ui::OS_View::UI_DispatchMouseEventFromOS(dvaui::ui::OS_Event*) + 411
      61  dvaui                             0x07ec5a65 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 833
      62  dvaui                             0x07ebcd7d dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 29
      63  dvaui                             0x07ebda5e dvaui::ui::OS_View::CallCarbonEventHandlerProc(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 112
      64  dvaui                             0x07f2bcc3 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*), boost::_bi::list3<boost::_bi::value<OpaqueEventHandlerCallRef*>, boost::_bi::value<OpaqueEventRef*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 33
      65  dvacore                           0x0831bb8a boost::function0<int, std::allocator<boost::function_base> >::operator()() const + 34
      66  dvacore                           0x082737cf dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::functio n0<int, std::allocator<boost::function_base> >) + 17
      67  dvaui                             0x07ebe38b dvaui::ui::OS_View::CarbonEventHandlerProc(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 279
      68  com.apple.HIToolbox               0x93030129 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      69  com.apple.HIToolbox               0x9302f3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      70  com.apple.HIToolbox               0x93051a81 SendEventToEventTarget + 52
      71  com.apple.HIToolbox               0x9309fc12 HIView::Click(OpaqueEventRef*) + 480
      72  com.apple.HIToolbox               0x9309f9df HandleClickAsHIView(OpaqueWindowPtr*, OpaqueEventRef*) + 151
      73  com.apple.HIToolbox               0x9309e2bc HandleWindowClick(OpaqueWindowPtr*, Point, short, unsigned long, OpaqueEventRef*) + 491
      74  com.apple.HIToolbox               0x9309ddbf HandleMouseEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 786
      75  com.apple.HIToolbox               0x9309d6d6 StandardWindowEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 93
      76  com.apple.HIToolbox               0x93030129 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      77  com.apple.HIToolbox               0x9302f3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      78  com.apple.HIToolbox               0x9309c33b CallNextEventHandler + 95
      79  AdobeOwl                          0x066a1a7f OWLWorkspaceBookmarkSnapshot + 102545
      80  AdobeOwl                          0x06633606 OWLToolbarCreateNonComposite + 756
      81  AdobeOwl                          0x0660e742 OWLDockGetPreferredOrigin + 67494
      82  AdobeOwl                          0x065a22b1 OWLThemeChangeInterpolator + 1357
      83  com.apple.HIToolbox               0x93030129 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      84  com.apple.HIToolbox               0x9302f3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      85  com.apple.HIToolbox               0x93051a81 SendEventToEventTarget + 52
      86  com.apple.HIToolbox               0x93063537 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257
      87  com.apple.HIToolbox               0x9303057a DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
      88  com.apple.HIToolbox               0x9302f3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      89  com.apple.HIToolbox               0x93051a81 SendEventToEventTarget + 52
      90  com.apple.HIToolbox               0x931da8f7 ToolboxEventDispatcher + 86
      91  com.apple.HIToolbox               0x931daa2f RunApplicationEventLoop + 243
      92  com.adobe.flash-10.0              0x00993fed 0x1000 + 10039277
      93  com.adobe.flash-10.0              0x0089ed33 0x1000 + 9035059
      94  com.adobe.flash-10.0              0x0089edde 0x1000 + 9035230
      95  com.adobe.flash-10.0              0x00003742 0x1000 + 10050
      96  com.adobe.flash-10.0              0x00003669 0x1000 + 9833
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib                 0x9368010a kevent + 10
      1   libSystem.B.dylib                 0x93680824 _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib                 0x9367fce1 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib                 0x9367fa86 _dispatch_worker_thread2 + 234
      4   libSystem.B.dylib                 0x9367f511 _pthread_wqthread + 390
      5   libSystem.B.dylib                 0x9367f356 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib                 0x93659942 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib                 0x93687480 _pthread_cond_wait + 1089
      2   libSystem.B.dylib                 0x936d0743 pthread_cond_wait + 48
      3   com.adobe.amt.services            0x1e19c552 AMTConditionLock::LockWhenCondition(int) + 46
      4   com.adobe.amt.services            0x1e197995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
      5   com.adobe.amt.services            0x1e19c5b0 AMTThread::Worker(void*) + 20
      6   libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      7   libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 3:
      0   libSystem.B.dylib                 0x936598fa mach_msg_trap + 10
      1   libSystem.B.dylib                 0x9365a067 mach_msg + 68
      2   ...ple.CoreServices.CarbonCore    0x98c102d8 TS_exception_listener_thread + 160
      3   libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      4   libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 4:
      0   libSystem.B.dylib                 0x9368782a __semwait_signal + 10
      1   libSystem.B.dylib                 0x936874e6 _pthread_cond_wait + 1191
      2   libSystem.B.dylib                 0x93689178 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore    0x98b7da2a TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore    0x98b6940d TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore    0x98b64d2f MPWaitOnQueue + 250
      6   AdobeACE                          0x04b9438d 0x4b63000 + 201613
      7   AdobeACE                          0x04b93d85 0x4b63000 + 200069
      8   ...ple.CoreServices.CarbonCore    0x98b489fa PrivateMPEntryPoint + 68
      9   libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      10  libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 5:
      0   libSystem.B.dylib                 0x9368c5b9 syscall + 5
      1   com.apple.OpenTransport           0x208af851 CarbonSelectThreadFunc + 257
      2   libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      3   libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 6:
      3   com.apple.OpenTransport           0x208abd73 CarbonOperationThreadFunc + 203
      4   libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      5   libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 7:  Java: Exception Handler Thread
      2   libSystem.B.dylib                 0x936c5818 mach_msg_server + 520
      3   libclient.dylib                   0x27810595 JNI_CreateJavaVM_Impl + 60869
      4   libclient.dylib                   0x2781053a JNI_CreateJavaVM_Impl + 60778
      5   libclient.dylib                   0x2780eaa3 JNI_CreateJavaVM_Impl + 53971
      Thread 8:  Java: Gang worker#0 (Parallel GC Threads)
      2   libclient.dylib                   0x2780f693 JNI_CreateJavaVM_Impl + 57027
      3   libclient.dylib                   0x2780f51b JNI_CreateJavaVM_Impl + 56651
      4   libclient.dylib                   0x2780f098 JNI_CreateJavaVM_Impl + 55496
      5   libclient.dylib                   0x2780ecf8 JNI_CreateJavaVM_Impl + 54568
      6   libclient.dylib                   0x278250e1 jio_vsnprintf + 321
      7   libclient.dylib                   0x2782501a jio_vsnprintf + 122
      8   libclient.dylib                   0x2780eaa3 JNI_CreateJavaVM_Impl + 53971
      Thread 9:  Java: Gang worker#1 (Parallel GC Threads)
      Thread 10:  Java: Concurrent Mark-Sweep GC Thread
      2   libclient.dylib                   0x2780f7a7 JNI_CreateJavaVM_Impl + 57303
      3   libclient.dylib                   0x2782c360 jio_vsnprintf + 29632
      4   libclient.dylib                   0x2780f127 JNI_CreateJavaVM_Impl + 55639
      6   libclient.dylib                   0x278e92cc JVM_Available + 29852
      7   libclient.dylib                   0x2782c142 jio_vsnprintf + 29090
      Thread 11:  Java: VM Thread
      6   libclient.dylib                   0x278a46fb JVM_Lseek + 142747
      7   libclient.dylib                   0x278a443a JVM_Lseek + 142042
      Thread 12:  Java: Reference Handler
      4   libclient.dylib                   0x278b9435 JVM_MonitorWait + 5461
      5   libclient.dylib                   0x278b839e JVM_MonitorWait + 1214
      6   libclient.dylib                   0x278b801a JVM_MonitorWait + 314
      7   ???                               0x2a899839 0 + 713660473
      8   ???                               0x2a891db1 0 + 713629105
      9   ???                               0x2a891db1 0 + 713629105
      10  ???                               0x2a88f2d3 0 + 713618131
      11  libclient.dylib                   0x278a5f70 JVM_Lseek + 149008
      12  libclient.dylib                   0x278a5d16 JVM_Lseek + 148406
      13  libclient.dylib                   0x278b78bb JVM_InternString + 2123
      14  libclient.dylib                   0x278b772a JVM_InternString + 1722
      15  libclient.dylib                   0x278b7514 JVM_InternString + 1188
      16  libclient.dylib                   0x278b6faf JVM_StartThread + 2175
      17  libclient.dylib                   0x2780eaa3 JNI_CreateJavaVM_Impl + 53971
      18  libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      19  libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 13:  Java: Finalizer
      9   ???                               0x2a891f17 0 + 713629463
      10  ???                               0x2a891f17 0 + 713629463
      11  ???                               0x2a88f2d3 0 + 713618131
      12  libclient.dylib                   0x278a5f70 JVM_Lseek + 149008
      13  libclient.dylib                   0x278a5d16 JVM_Lseek + 148406
      14  libclient.dylib                   0x278b78bb JVM_InternString + 2123
      15  libclient.dylib                   0x278b772a JVM_InternString + 1722
      16  libclient.dylib                   0x278b7514 JVM_InternString + 1188
      17  libclient.dylib                   0x278b6faf JVM_StartThread + 2175
      18  libclient.dylib                   0x2780eaa3 JNI_CreateJavaVM_Impl + 53971
      19  libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      20  libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 14:  Java: Surrogate Locker Thread (CMS)
      5   libclient.dylib                   0x2780ec19 JNI_CreateJavaVM_Impl + 54345
      6   libclient.dylib                   0x278ce817 JVM_IsPrimitiveClass + 7639
      7   libclient.dylib                   0x278ce391 JVM_IsPrimitiveClass + 6481
      8   libclient.dylib                   0x278b7514 JVM_InternString + 1188
      9   libclient.dylib                   0x278b6faf JVM_StartThread + 2175
      10  libclient.dylib                   0x2780eaa3 JNI_CreateJavaVM_Impl + 53971
      11  libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      12  libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 15:  Java: Signal Dispatcher
      0   libSystem.B.dylib                 0x93659936 semaphore_wait_trap + 10
      1   libclient.dylib                   0x278cf2de JVM_IsPrimitiveClass + 10398
      2   libclient.dylib                   0x278cf0ae JVM_IsPrimitiveClass + 9838
      3   libclient.dylib                   0x278b7514 JVM_InternString + 1188
      4   libclient.dylib                   0x278b6faf JVM_StartThread + 2175
      Thread 16:  Java: CompilerThread0
      6   libclient.dylib                   0x278d0642 JVM_IsPrimitiveClass + 15362
      7   libclient.dylib                   0x278d041b JVM_IsPrimitiveClass + 14811
      Thread 17:  Java: Low Memory Detector
      6   libclient.dylib                   0x278d45b2 JVM_IsPrimitiveClass + 31602
      7   libclient.dylib                   0x278b7514 JVM_InternString + 1188
      8   libclient.dylib                   0x278b6faf JVM_StartThread + 2175
      9   libclient.dylib                   0x2780eaa3 JNI_CreateJavaVM_Impl + 53971
      10  libSystem.B.dylib                 0x93686fe1 _pthread_start + 345
      11  libSystem.B.dylib                 0x93686e66 thread_start + 34
      Thread 18:  Java: VM Periodic Task Thread
      3   libclient.dylib                   0x278d588d JVM_IsPrimitiveClass + 36429
      4   libclient.dylib                   0x278d5433 JVM_IsPrimitiveClass + 35315
      Thread 19:
      0   libSystem.B.dylib                 0x93659a0e mach_wait_until + 10
      1   libSystem.B.dylib                 0x936e1c05 nanosleep + 345
      2   com.adobe.flash.flbridge          0x22d2b3e9 ScObjects::Thread::sleep(unsigned int) + 143
      3   com.adobe.flash.flbridge          0x22d2b449 ScObjects::Thread::wait(unsigned int) + 23
      4   com.adobe.flash.flbridge          0x22d1c20a ScObjects::BridgeTalkThread::run() + 332
      5   com.adobe.flash.flbridge          0x22d2b70b ScObjects::Thread::go(void*) + 239
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000010  ebx: 0xbfff9db0  ecx: 0xbfff9d14  edx: 0xbfff9d18
        edi: 0x00000000  esi: 0x00000000  ebp: 0xbfff9cd8  esp: 0xbfff9ca0
         ss: 0x0000001f  efl: 0x00010202  eip: 0x95101de2   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x0000000c
      Binary Images:
          0x1000 -  0x123eff0 +com.adobe.flash-10.0 10.0.2.566 (10.0.2) <A7C69920-4EEA-48D1-9C7E-9895FBF62001> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/Adobe Flash CS4
      0x1728000 -  0x17fafe7 +AdobeAXEDOMCore ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
      0x18ae000 -  0x193b2cb +libicucnv.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x1968000 -  0x1a3723b +libicui18n.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
      0x1ae0000 -  0x1bb4db7 +libicuuc.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
      0x1c15000 -  0x25c557f +libicudata.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x25c8000 -  0x25d7fc3 +libChar16.dylib ??? (???) <B97A174D-CCAC-40FD-A8D1-2A3891CC5CDD> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/libChar16.dylib
      0x25e0000 -  0x25f8fc0 +libCoreTypes.dylib ??? (???) <7EEBDBBF-181B-4706-8A5D-10266B36304F> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/libCoreTypes.dylib
      0x261b000 -  0x262afef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/frameworks/ZLib.dylib
      0x262f000 -  0x2843fef  com.apple.carbonframeworktemplate 1.0 (1.0) <AC98929C-640F-4C7E-8737-9928CF7B8CD4> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
      0x2b8c000 -  0x2b93ff7  com.apple.JavaVM 13.0.0 (13.0.0) <73B4CB4C-7C91-D148-E6DD-CFD578055BF7> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
      0x2b9b000 -  0x3858fdf +com.adobe.illustrator 338 (14.0.0) <D8621BED-6312-45E6-89E1-F49896F3E87E> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
      0x4951000 -  0x49a1fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <9B4C73DE-716B-4787-BB01-E1DDDC6DEA53> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
      0x4a3a000 -  0x4a89ff3 +FilterPort ??? (???) <66918FA0-9135-4C31-81DA-D4B5F8FDB798> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
      0x4b28000 -  0x4b29027 +SPBasic ??? (???) <9121C50E-FA52-4FA2-B299-AF180C3A1316> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
      0x4b2d000 -  0x4b49ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
      0x4b63000 -  0x4c70fff +AdobeACE ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x4c8e000 -  0x5196fff +AdobeAGM ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x5306000 -  0x5345ff7 +AdobeARE ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
      0x534f000 -  0x5368fff +AdobeBIB ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x5372000 -  0x5393ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x53a0000 -  0x563cfef +AdobeCoolType ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x56c7000 -  0x5a91fef +AdobeMPS ??? (???) <4E366E06-A4EB-4717-9639-0443743F5104> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
      0x5b20000 -  0x5c08fdf +AdobePDFPort ??? (???) <F54A25D1-5E7A-472E-83D1-10D187434C85> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
      0x5c4d000 -  0x6245fdf +AdobePDFL ??? (???) <D2996BF8-17D2-4801-93F7-2F227538DCD8> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
      0x6389000 -  0x63adff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
      0x63c0000 -  0x63e2fed +AdobeAXE16SharedExpat ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
      0x63fd000 -  0x645dfc7 +AdobeXMP ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x646c000 -  0x6541fdd +FileInfo ??? (???) <F0932F89-FC98-4BA9-B4F2-C58D0E71D3C1> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x6572000 -  0x6585fff +com.adobe.AdobeSFL AdobeSFL 1.1 (1.1.0.12) <6B1D574E-0F4A-4B80-82F6-7DF7AA9C50CD> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
      0x658c000 -  0x6786fef +AdobeOwl ??? (???) <466BD72B-E2A5-447A-9384-B6DC9AD3AE0C> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x6801000 -  0x7533fff +com.adobe.psl AdobePSL 11.0.0.1724 (11.0.0.1724) <6BE27A60-E0F9-4483-8E57-2A7A5227D878> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x7867000 -  0x7c4101f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
      0x7cf5000 -  0x7cfbfff +com.adobe.AdobeCrashReporter 2.5 (2.5.02272007) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
      0x7d02000 -  0x7d1efd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
      0x7d29000 -  0x7f71fc7 +dvaui ??? (???) <6B82E781-8BA9-4287-89F1-339854AC1D32> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
      0x825b000 -  0x83beff4 +dvacore ??? (???) <98D9BE6F-6D5E-4070-AD40-332F83CAC417> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
      0x8558000 -  0x870eff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <CB2EC3BF-6771-4DAB-BF29-6775FB6F9608> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x8745000 -  0x8774ff7 +com.adobe.headlights.LogSessionFramework ??? (2.0.0.06112008) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x879c000 -  0x87adffb +LogTransport2 ??? (???) <835B7B84-5A67-370B-AB39-8E448AA81FA0> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogTransport2.framework/Versions/A/LogTransport2
      0x87b7000 -  0x87bdfff +com.adobe.pip ??? (1.0.0.220) <2CA89939-DFA7-4686-8536-8A1F1107CAF1> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
      0x87c3000 -  0x8853fc3 +WRServices ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0x89d5000 -  0x8a38027 +com.adobe.PlugPlug 1.0.0.71 (1.0.0.71) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
      0x8a99000 -  0x8ad9ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x8af2000 -  0x8ba7fe7  libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
      0x8ce0000 -  0x8ce1ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x8ffd000 -  0x8ffdff7  libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
      0xa559000 -  0xa5a0fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0xa5b0000 -  0xa5bdff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0xa731000 -  0xa732ff7  ATSHI.dylib ??? (???) <251A0D44-8909-BC8C-49DF-477BA8304FDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
      0xa737000 -  0xa745fe7  libSimplifiedChineseConverter.dylib ??? (???) <4C9CC2D9-2F13-4465-5447-2516FCD9255B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0xa749000 -  0xa74cfcf +libwchar.dylib ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/libwchar.dylib
      0xa780000 -  0xa7edfff +com.DivXInc.DivXDecoder 6.6.0 (6.6.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
      0x1e17c000 - 0x1e21dfc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x1e8ec000 - 0x1e8feff7  libTraditionalChineseConverter.dylib ??? (???) <C4E0D62B-4D1A-8DAD-D10B-2C055AA0479C> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x1eab0000 - 0x1ead9fef  com.apple.audio.CoreAudioKit 1.6 (1.6) <E9D5679D-0F3A-EE19-76F9-559F42E5DF8C> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
      0x1f042000 - 0x1f073fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/registration.framework/Versions/A/registration
      0x1f200000 - 0x1f682fe3 +AdobeLM_libFNP.dylib ??? (???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/AdobeLM_libFNP.dylib
      0x20000000 - 0x2005cff2 +AdobeUpdater ??? (???) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/A/AdobeUpdater
      0x20553000 - 0x20591fd4 +com.adobe.emlaunch 1.1 (1.0) /Library/Application Support/Adobe/EMLaunch.bundle/Contents/MacOS/EMLaunch
      0x205dc000 - 0x205f402f +com.macromedia.Flash.FLAir 10.0.0 (10.0.0 d544) <33151461-3D89-4331-936C-4737D11C97F1> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLAir1_1.bundle/Contents/MacOS/FLAir1_1
      0x2074d000 - 0x2074dfff +com.macromedia.Flash.flastoragelib 9.0 (9.0) <4A09437D-BEFE-48C6-A7B5-5C094044AA9E> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
      0x20876000 - 0x20899ff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
      0x208a8000 - 0x208c3ff7  com.apple.OpenTransport 10.6.0 (10.6.0) <ECA6FEC6-5ECD-51BA-162F-CFC43899196A> /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
      0x208d4000 - 0x208ebfff +com.macromedia.Flash.FLAir 10.0.1 (10.0.1 d156) <88E2D410-7BBD-46EC-BF99-21E2ED7BF9E9> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLAir1_5.bundle/Contents/MacOS/FLAir1_5
      0x208f8000 - 0x208fafff +com.macromedia.Flash.FLfile 10.0.0.544 (10.0.0) <A983B337-B19A-4DC7-B46A-2AE8F683B3B8> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
      0x20b27000 - 0x20b3cff7 +com.yourcompany.PointGrid ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
      0x221b7000 - 0x221bfff7  libverify.dylib ??? (???) <0B49EBEC-AC21-9771-4616-D7507CDA7B4D> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
      0x221c4000 - 0x221cbff7  JavaNativeFoundation ??? (???) <41C861E0-F76F-9EEE-9BB4-F924CDF763DD> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
      0x22218000 - 0x22235ff7  libjava.jnilib ??? (???) <C134666B-0870-1793-EF20-0A4510394309> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
      0x22750000 - 0x2275cff7  libzip.jnilib ??? (???) <34AB8700-84F9-168C-0B27-BFA9607D2C7E> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
      0x22cfb000 - 0x22d3ffe3 +com.adobe.flash.flbridge 10.0.0.544 (10.0.0) <E556D6D9-DA9B-435F-93D5-D10A357EC120> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
      0x22dfd000 - 0x22e60feb +com.yourcompany.Brush ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
      0x22f8b000 - 0x23007ff7 +com.yourcompany.Collision ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
      0x23e00000 - 0x23ecffcb  com.apple.carbonbundletemplate 1.0 (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FlashIK.bundle/Contents/MacOS/FlashIK
      0x27800000 - 0x27bf6ff7  libclient.dylib ??? (???) <84358FE1-AD10-6876-1539-4B09901E17E1> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
      0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
      0x9000a000 - 0x90050ff7  libauto.dylib ??? (???) <FAB17F30-A28B-E33D-6E21-C7119C9C83ED> /usr/lib/libauto.dylib
      0x900d6000 - 0x90185fef  com.apple.ColorSync 4.6.0 (4.6.0) <66ABAE86-B0EC-D641-913D-08ACA965F9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x90186000 - 0x90235ff3  com.apple.ink.framework 1.3 (104) <8526D880-D367-3EF9-DBFD-9A6AB240F57A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x902ab000 - 0x902abff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x902ac000 - 0x9123aff7  com.apple.QuickTimeComponents.component 7.6.3 (1584) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
      0x9123b000 - 0x9123efe7  libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x9123f000 - 0x914a1ff3  com.apple.security 6.0 (36910) <F045B57C-054F-F06F-EF7E-EABEC2700274> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x914a2000 - 0x914a8fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x914de000 - 0x9151bff7  com.apple.SystemConfiguration 1.10 (1.10) <897AEEAF-CF5D-2843-C33B-31A0A7C98A6A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x9151c000 - 0x9151eff7  libRadiance.dylib ??? (???) <0E03CF64-0931-7B9A-F617-4387B809D6D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x915b6000 - 0x9162fff3  com.apple.audio.CoreAudio 3.2.0 (3.2) <91AE891E-6015-AABE-3512-2D5EBCA0937B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x916d9000 - 0x9176afe3  com.apple.print.framework.PrintCore 6.0 (312) <C588530A-0F2C-DD72-E308-3B8735125189> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x918f5000 - 0x91a1dfe7  com.apple.CoreData 102 (246) <E7E6CE39-9B51-13C8-FE31-8FE57CF7BDE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x91a1e000 - 0x91a22ff7  IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x91a23000 - 0x91d1cfef  com.apple.QuickTime 7.6.3 (1584) <687233E1-F428-5224-08D5-5874BEA2300D> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x91f21000 - 0x91f47fff  com.apple.DictionaryServices 1.1 (1.1) <07694B30-56A9-5C98-B8BC-DA0628715FA8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x91f48000 - 0x91f6aff3  com.apple.DirectoryService.Framework 3.6 (621) <61569C79-6567-BE8F-4F76-BAC04E5FBF79> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x91f6b000 - 0x91f75ff7  libGL.dylib ??? (???) <B375A3B6-2983-A4E4-50FB-9087FD606FD6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x91fa8000 - 0x91fabffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x91fac000 - 0x91fc8fe3  com.apple.openscripting 1.3 (???) <D2FF4419-FD71-5D4A-F397-B03E82085232> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x91fd7000 - 0x9200dfff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
      0x92067000 - 0x920a1fe7  libFontRegistry.dylib ??? (???) <EE633CF6-8827-EF05-10A4-5F2937120227> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x920a2000 - 0x920a6ff7  libGIF.dylib ??? (???) <51848EBF-27D4-0F85-C22A-D1AE10D328F3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x920a9000 - 0x9212bffb  SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x9212c000 - 0x92133fff  com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x92135000 - 0x92206ff3  ColorSyncDeprecated.dylib ??? (???) <AFD6DAC8-12EF-B2A0-5322-E902D5B48B0A> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
      0x92207000 - 0x9220cff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x9220d000 - 0x92384fef  com.apple.CoreFoundation 6.6 (550) <193E33D6-2E92-3452-773B-60A1A9CCC573> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x923a3000 - 0x923cdff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x923ce000 - 0x923ceff7  com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x923da000 - 0x924a4fef  com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x924a5000 - 0x925a6fe7  libxml2.2.dylib ??? (???) <C242A74D-280A-90C3-3F79-891624AA45D2> /usr/lib/libxml2.2.dylib
      0x925a7000 - 0x925b1ff7  com.apple.HelpData 2.0.3 (33) <AD60F037-CE57-C93A-F865-2CEEE3F08F31> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x925b2000 - 0x925c4ff7  com.apple.MultitouchSupport.framework 200.20 (200.20) <1D7EE15B-ADDD-1F57-F1FB-FB5252910D5A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x925c5000 - 0x925f6ff7  libGLImage.dylib ??? (???) <0FB347C7-A579-4E51-4733-39AB28064554> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x927ca000 - 0x927e2ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x92942000 - 0x92ca6ff7  com.apple.QuartzCore 1.6.0 (226.0) <7E29DD09-BE04-AA06-5C81-5C093F16901B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x92d02000 - 0x92d52ff7  com.apple.framework.familycontrols 2.0 (2.0) <50617342-E578-4C1C-938A-19A37ECA91CA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x92d53000 - 0x92d6eff7  libPng.dylib ??? (???) <38DD4AA1-0643-85A0-F2F5-EE9269729975> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x92d6f000 - 0x92d70ff7  com.apple.audio.units.AudioUnit 1.6 (1.6) <68180B96-381C-A09D-5576-606A134FD953> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x92e37000 - 0x92e5fff7  libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x92fd5000 - 0x92fe2ff7  com.apple.NetFS 3.2 (3.2) <E6FD80B0-0238-0C42-A3EC-EBDEC107A1C3> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x92fe3000 - 0x93027fe7  com.apple.Metadata 10.6.0 (507.1) <CBD1B22B-5F10-C784-03A2-35106B97DF3F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x93028000 - 0x9334bfef  com.apple.HIToolbox 1.6.0 (???) <6F95AF67-678A-D8BC-FFC2-029C9AA2F44A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x9334c000 - 0x933f3fe7  com.apple.CFNetwork 454.4 (454.4) <7C563385-9893-3B48-8607-5BC81DA2C4CF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x933f4000 - 0x9351dfe7  com.apple.audio.toolbox.AudioToolbox 1.6 (1.6) <62BEEBE6-68FC-4A48-91CF-39DA2BD793F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x9351e000 - 0x93527ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x93528000 - 0x935d0ff7  com.apple.QD 3.31 (???) <40FCAC85-4E4F-2290-90D4-F66D550ADFDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x9362e000 - 0x93642ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x93643000 - 0x93658fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x93659000 - 0x937fdfeb  libSystem.B.dylib ??? (???) <068CC3F2-F867-A231-A16C-CC01C29A9816> /usr/lib/libSystem.B.dylib
      0x9383e000 - 0x9383eff7  com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x9384f000 - 0x93892ff7  com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x93893000 - 0x93893ff7  com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x93894000 - 0x93943fe3  com.apple.QuickTimeImporters.component 7.6.3 (1584) <34BF4FBA-BFCD-9A47-4BA9-E2B155C5C881> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
      0x93944000 - 0x93977ff7  com.apple.AE 496 (496) <B638FDD4-7322-F0E4-ACEB-777D8A1399E1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x93978000 - 0x9399cff7  libJPEG.dylib ??? (???) <265DBF67-994E-E320-4CB1-9C3DE792C3B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x939d9000 - 0x941ba497  com.apple.CoreGraphics 1.535.5 (???) <0B93D29C-D957-AD00-10F3-94112D75D6D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x94675000 - 0x94887fff  com.apple.RawCamera.bundle 2.2.1 (477) <10937A0D-0856-1B69-AE27-43BC15B7DD21> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x94888000 - 0x94892ffb  com.apple.speech.recognition.framework 3.10.10 (3.10.10) <E106CC3A-7633-5587-0B29-64E19FCBC613> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x94bfd000 - 0x94c00ff7  libCoreVMClient.dylib ??? (???) <16BB2178-B32D-E57E-F1E4-D177F7754232> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x94c01000 - 0x94c11ff7  libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x94c39000 - 0x94c45ff7  libkxld.dylib ??? (???) <152C8DBB-0149-5827-3240-E57CA85CFE5F> /usr/lib/system/libkxld.dylib
      0x950f5000 - 0x95126ff3  libTrueTypeScaler.dylib ??? (???) <F326E053-7425-2F10-F883-CBD56A1E1B72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x95190000 - 0x9519afe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x9519b000 - 0x951ffffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x95200000 - 0x953bcfef  com.apple.ImageIO.framework 3.0.0 (3.0.0) <A37E541F-3D6A-2BE9-AB32-F60CCDE13608> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x953bd000 - 0x953bdff7  com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x953be000 - 0x954c7fe7  com.apple.CoreAUC 4.10.0 (4.10.0) <34606DCE-1257-8FB9-E633-AC56DD263EAB> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
      0x954c8000 - 0x95da4ff7  com.apple.AppKit 6.6 (1038) <25DDEBFC-8A2F-8434-1D97-AEC55B5205F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x95da5000 - 0x95de6ff7  libRIP.A.dylib ??? (???) <6DB158C6-A84D-98C9-1D48-868A3DB17D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x95de7000 - 0x95e94fe7  libobjc.A.dylib ??? (???) <410DD065-A18F-F054-0457-65525F4D1039> /usr/lib/libobjc.A.dylib
      0x95ec0000 - 0x95f11ff7  com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x95f12000 - 0x95f30ff7  com.apple.CoreVideo 1.6.0 (43.0) <3A853574-DD9E-08D8-FD2C-6221B55C3E08> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x95ff9000 - 0x9603dff3  com.apple.coreui 0.2 (112) <A810DFFD-6314-5E2B-93A4-D5626634B1EE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x96072000 - 0x96200fff  com.apple.JavaScriptCore 6531 (6531.5) <DDDCCE57-42D2-BAA1-63F1-F76458EE0927> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x9630f000 - 0x96312ff7  libCGXType.A.dylib ??? (???) <3FB5E457-EABF-B33E-E01B-C695FB2D72EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x96313000 - 0x96327fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
      0x96328000 - 0x9640bff7  com.apple.WebKit 6531 (6531.9) <991912FB-1484-A0B2-593F-A8722BC6AFE7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x9640c000 - 0x964beffb  libFontParser.dylib ??? (???) <EB089832-660F-0B34-3AC8-CCDA937987D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x964bf000 - 0x9659cff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x9659d000 - 0x9659fff7  com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x966b7000 - 0x966c1ff7  libCSync.A.dylib ??? (???) <A05BB12D-CD51-DE43-323B-3A3E99A3EED5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x966e4000 - 0x96731feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x96825000 - 0x96c5aff7  libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x96c5b000 - 0x96d4ffe7  libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
      0x96d50000 - 0x96d54ff7  libGFXShared.dylib ??? (???) <ED62E870-E219-C873-88AA-9CE08108F811> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x96d96000 - 0x96e88ff7  libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
      0x96e89000 - 0x9766efe7  com.apple.WebCore 6531 (6531.9) <F9A9848B-9EB0-B912-49F5-7E8010AF2CF1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
      0x9766f000 - 0x976c9ff7  com.apple.framework.IOKit 2.0 (???) <7618DDEC-2E3B-9C6E-FDC9-15169E24B4FB> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x97718000 - 0x97725ff7  com.apple.opengl 1.6.3 (1.6.3) <59D86286-B46F-B0E4-68F8-E5CDCADE393E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x97733000 - 0x97753fe7  libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
      0x97754000 - 0x97765ff7  com.apple.LangAnalysis 1.6.5 (1.6.5) <E77440D0-76EE-EB4C-3D00-9EDE417F13CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x97766000 - 0x9776dff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x9778d000 - 0x977cffe7  libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x977d0000 - 0x97be6ff7  libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x97c96000 - 0x97d8cff7  libGLProgrammability.dylib ??? (???) <B8E40851-3A01-7D01-2F96-537BF7FA63B5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x97d8d000 - 0x97e68fef  com.apple.DesktopServices 1.5.0 (1.5.0) <5295C246-805B-DBCD-BA61-1AE9A458CF73> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x97e69000 - 0x97e77fe7  libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
      0x97e78000 - 0x97ffafe7  libicucore.A.dylib ??? (???) <FBB66376-CBA9-8149-A1AA-10AB8578C3B3> /usr/lib/libicucore.A.dylib
      0x98034000 - 0x98068ff7  libcups.2.dylib ??? (???) <9078BA07-DEE1-6597-D15D-7BE3A20CB5A0> /usr/lib/libcups.2.dylib
      0x98109000 - 0x981a1fe7  edu.mit.Kerberos 6.5.8 (6.5.8) <BA9BD282-FF56-3BFD-E78C-7DBE73B48480> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x98239000 - 0x98299fe7  com.apple.CoreText 3.0.0 (???) <8F4FCAE2-8E6F-F0DE-A6AA-15D0228B7F13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x9829a000 - 0x9850affb  com.apple.Foundation 6.6 (751) <A61B645E-1A15-5BCA-3043-C8AB85C6AD30> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x9850b000 - 0x9850cff7  com.apple.TrustEvaluationAgent 1.0 (1) <71E2DA16-83EC-6056-FFEE-862A04B5599F> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x9850d000 - 0x9858dfeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x9858e000 - 0x985defe7  libGLU.dylib ??? (???) <55A69DCE-1237-341E-F239-CDFE1F5B19BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x985df000 - 0x9864eff7  libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x9885d000 - 0x9885dff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x9885e000 - 0x98a39ff3  libType1Scaler.dylib ??? (???) <BD3674DE-EAD9-C57A-0072-3C18970DCC1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
      0x98a3a000 - 0x98ad6fe7  com.apple.ApplicationServices.ATS 4.0 (???) <81700C90-2614-F7E2-CC6A-B01C24A2BD75> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x98ad7000 - 0x98b20fe7  libTIFF.dylib ??? (???) <6EF87001-6FB4-1405-C588-F6D8042D3534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x98b21000 - 0x98b21ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x98b22000 - 0x98e41fe7  com.apple.CoreServices.CarbonCore 859.1 (859.1) <2E72AF56-4BE6-294A-7372-19C360688B8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x98efe000 - 0x98f9bff3  com.apple.LaunchServices 360.3 (360.3) <C8590D53-E46A-F58A-7CF2-03A8159D8569> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x98f9c000 - 0x99055fe7  libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
      0x993a4000 - 0x993a4ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x993a5000 - 0x9940ffe7  libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x99410000 - 0x9942ffe7  com.apple.opencl 11 (11) <372A42E7-FB10-B74D-E1A0-980E94D07021> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate 1.3 (1.3.12) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba300000 - 0xba301fe7  libCyrillicConverter.dylib ??? (???) <7CF64AB7-ABFE-6F8F-8F50-C7460A5B3A92> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
      0xba500000 - 0xba501ff7  libGreekConverter.dylib ??? (???) <1AB8227F-468F-B285-B4B4-14B7D202ED36> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib ??? (???) <4FB5CEEB-8D3E-8C57-1718-81D7CAFBFE69> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib ??? (???) <A23F9980-5CC8-A44D-6FD6-DBFCBFF4FF28> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xbb500000 - 0xbb500ff7  libThaiConverter.dylib ??? (???) <5B51E9C4-40C4-26B7-5CA2-CD27D78CFA27> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <068CC3F2-F867-A231-A16C-CC01C29A9816> /usr/lib/libSystem.B.dylib
      Model: MacBookPro4,1, BootROM MBP41.00C1.B03, 2 processors, Intel Core 2 Duo, 2.5 GHz, 2 GB, SMC 1.27f2
      Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 512 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8C), Broadcom BCM43xx 1.0 (5.10.91.19)
      Bluetooth: Version 2.2.0f18, 2 service, 0 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Serial ATA Device: Hitachi HTS542525K9SA00, 232.89 GB
      Parallel ATA Device: HL-DT-ST DVDRW  GSA-S10N
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd400000
      USB Device: Hub, 0x05ac  (Apple Inc.), 0x911b, 0xfd100000
      USB Device: My Book, 0x1058  (Western Digital Technologies, Inc.), 0x1100, 0xfd110000
      USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfd130000
      USB Device: Microsoft® 2.4GHz Transceiver v5.0, 0x045e  (Microsoft Corporation), 0x074f, 0xfd133000
      USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0221, 0xfd132000
      USB Device: Apple Cinema Display, 0x05ac  (Apple Inc.), 0x921b, 0xfd120000
      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x1a100000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x820f, 0x1a110000
      USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0231, 0x5d200000
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000
      FireWire Device: unknown_device, Unknown
      Thank you in advance for any inputs/help.
      Kind regards from Switzerland
        • 1. Re: Snowleopard & Flash CS4 (Crash)
          dmvjs
          I have the same problem. I did not install rosetta with 10.6 but when I open a flash file and type a few characters into the actionscript pane I get a crash every time. I've been using CS4 on this machine (Macbook Pro 13" w 4GB Ram)  since June with only a few Flash crashes. I'm a Flash UI developer so this presents a real problem for me. Here's my crash repor:
          Process:         Adobe Flash CS4 [3044]
          Parent Process:  launchd [74]
          Date/Time:       2009-09-02 19:12:53.151 -0400
          Report Version:  6
          Interval Since Last Report:          3659 sec
          Crashes Since Last Report:           3
          Per-App Interval Since Last Report:  858 sec
          Per-App Crashes Since Last Report:   3
          Anonymous UUID:                      1F695E3B-CE83-4FDA-8362-98B366AAEC1A
          Exception Type:  EXC_CRASH (SIGABRT)
          Exception Codes: 0x0000000000000000, 0x0000000000000000
          abort() called
          0   libSystem.B.dylib                 0x9912d972 __kill + 10
          1   libSystem.B.dylib                 0x9912d964 kill$UNIX2003 + 32
          2   libSystem.B.dylib                 0x991c0ba5 raise + 26
          3   libSystem.B.dylib                 0x991d6c5c abort + 93
          4   libstdc++.6.dylib                 0x91206fda __gnu_cxx::__verbose_terminate_handler() + 433
          5   libstdc++.6.dylib                 0x9120517a __cxxabiv1::__terminate(void (*)()) + 10
          6   libstdc++.6.dylib                 0x912051ba __cxxabiv1::__unexpected(void (*)()) + 0
          7   libstdc++.6.dylib                 0x912052b8 __gxx_exception_cleanup(_Unwind_Reason_Code, _Unwind_Exception*) + 0
          8   com.adobe.flash-10.0              0x0068256b 0x1000 + 6821227
          9   com.adobe.flash-10.0              0x00cf93c4 0x1000 + 13599684
          10  com.adobe.flash-10.0              0x007c6519 0x1000 + 8148249
          11  com.adobe.flash-10.0              0x007c696f 0x1000 + 8149359
          12  com.adobe.flash-10.0              0x007c6f32 0x1000 + 8150834
          13  com.adobe.flash-10.0              0x007c7031 0x1000 + 8151089
          14  com.adobe.flash-10.0              0x007c2e75 0x1000 + 8134261
          15  com.adobe.flash-10.0              0x007c33b8 0x1000 + 8135608
          16  com.apple.HIToolbox               0x92b7b104 IdleTimerVector + 62
          17  com.apple.CoreFoundation          0x95999eee __CFRunLoopRun + 6846
          18  com.apple.CoreFoundation          0x95997d34 CFRunLoopRunSpecific + 452
          19  com.apple.CoreFoundation          0x95997b61 CFRunLoopRunInMode + 97
          20  com.apple.HIToolbox               0x92b26fec RunCurrentEventLoopInMode + 392
          21  com.apple.HIToolbox               0x92b26da3 ReceiveNextEventCommon + 354
          22  com.apple.HIToolbox               0x92caecde _AcquireNextEvent + 54
          23  com.apple.HIToolbox               0x92ca4a20 RunApplicationEventLoop + 228
          24  com.adobe.flash-10.0              0x00993fed 0x1000 + 10039277
          25  com.adobe.flash-10.0              0x0089ed33 0x1000 + 9035059
          26  com.adobe.flash-10.0              0x0089edde 0x1000 + 9035230
          27  com.adobe.flash-10.0              0x00003742 0x1000 + 10050
          28  com.adobe.flash-10.0              0x00003669 0x1000 + 9833
          0   libSystem.B.dylib                 0x990f310a kevent + 10
          1   libSystem.B.dylib                 0x990f3824 _dispatch_mgr_invoke + 215
          2   libSystem.B.dylib                 0x990f2ce1 _dispatch_queue_invoke + 163
          3   libSystem.B.dylib                 0x990f2a86 _dispatch_worker_thread2 + 234
          4   libSystem.B.dylib                 0x990f2511 _pthread_wqthread + 390
          5   libSystem.B.dylib                 0x990f2356 start_wqthread + 30
          Thread 2:
          0   libSystem.B.dylib                 0x990cc942 semaphore_wait_signal_trap + 10
          1   libSystem.B.dylib                 0x990fa480 _pthread_cond_wait + 1089
          2   libSystem.B.dylib                 0x99143743 pthread_cond_wait + 48
          3   com.adobe.amt.services            0x1e238552 AMTConditionLock::LockWhenCondition(int) + 46
          4   com.adobe.amt.services            0x1e233995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
          5   com.adobe.amt.services            0x1e2385b0 AMTThread::Worker(void*) + 20
          6   libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          7   libSystem.B.dylib                 0x990f9e66 thread_start + 34
          Thread 3:
          0   libSystem.B.dylib                 0x990cc8fa mach_msg_trap + 10
          1   libSystem.B.dylib                 0x990cd067 mach_msg + 68
          2   ...ple.CoreServices.CarbonCore    0x9541c2d8 TS_exception_listener_thread + 160
          3   libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          4   libSystem.B.dylib                 0x990f9e66 thread_start + 34
          Thread 4:
          0   libSystem.B.dylib                 0x990fa82a __semwait_signal + 10
          1   libSystem.B.dylib                 0x990fa4e6 _pthread_cond_wait + 1191
          2   libSystem.B.dylib                 0x990fc178 pthread_cond_wait$UNIX2003 + 73
          3   ...ple.CoreServices.CarbonCore    0x95389a2a TSWaitOnCondition + 126
          4   ...ple.CoreServices.CarbonCore    0x9537540d TSWaitOnConditionTimedRelative + 202
          5   ...ple.CoreServices.CarbonCore    0x95370d2f MPWaitOnQueue + 250
          8   ...ple.CoreServices.CarbonCore    0x953549fa PrivateMPEntryPoint + 68
          9   libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          10  libSystem.B.dylib                 0x990f9e66 thread_start + 34
          Thread 5:
          0   libSystem.B.dylib                 0x990ff5b9 syscall + 5
          1   com.apple.OpenTransport           0x2078a851 CarbonSelectThreadFunc + 257
          2   libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          3   libSystem.B.dylib                 0x990f9e66 thread_start + 34
          Thread 6:
          3   com.apple.OpenTransport           0x20786d73 CarbonOperationThreadFunc + 203
          4   libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          5   libSystem.B.dylib                 0x990f9e66 thread_start + 34
          2   libSystem.B.dylib                 0x99138818 mach_msg_server + 520
          3   libclient.dylib                   0x28110595 JNI_CreateJavaVM_Impl + 60869
          4   libclient.dylib                   0x2811053a JNI_CreateJavaVM_Impl + 60778
          5   libclient.dylib                   0x2810eaa3 JNI_CreateJavaVM_Impl + 53971
          2   libclient.dylib                   0x2810f693 JNI_CreateJavaVM_Impl + 57027
          3   libclient.dylib                   0x2810f51b JNI_CreateJavaVM_Impl + 56651
          4   libclient.dylib                   0x2810f098 JNI_CreateJavaVM_Impl + 55496
          5   libclient.dylib                   0x2810ecf8 JNI_CreateJavaVM_Impl + 54568
          6   libclient.dylib                   0x281250e1 jio_vsnprintf + 321
          7   libclient.dylib                   0x2812501a jio_vsnprintf + 122
          8   libclient.dylib                   0x2810eaa3 JNI_CreateJavaVM_Impl + 53971
          2   libclient.dylib                   0x2810f7a7 JNI_CreateJavaVM_Impl + 57303
          3   libclient.dylib                   0x2812c360 jio_vsnprintf + 29632
          4   libclient.dylib                   0x2810f127 JNI_CreateJavaVM_Impl + 55639
          6   libclient.dylib                   0x281e92cc JVM_Available + 29852
          7   libclient.dylib                   0x2812c142 jio_vsnprintf + 29090
          6   libclient.dylib                   0x281a46fb JVM_Lseek + 142747
          7   libclient.dylib                   0x281a443a JVM_Lseek + 142042
          4   libclient.dylib                   0x281b9435 JVM_MonitorWait + 5461
          5   libclient.dylib                   0x281b839e JVM_MonitorWait + 1214
          6   libclient.dylib                   0x281b801a JVM_MonitorWait + 314
          7   ???                               0x2990b839 0 + 697350201
          8   ???                               0x29903db1 0 + 697318833
          9   ???                               0x29903db1 0 + 697318833
          10  ???                               0x299012d3 0 + 697307859
          11  libclient.dylib                   0x281a5f70 JVM_Lseek + 149008
          12  libclient.dylib                   0x281a5d16 JVM_Lseek + 148406
          13  libclient.dylib                   0x281b78bb JVM_InternString + 2123
          14  libclient.dylib                   0x281b772a JVM_InternString + 1722
          15  libclient.dylib                   0x281b7514 JVM_InternString + 1188
          16  libclient.dylib                   0x281b6faf JVM_StartThread + 2175
          17  libclient.dylib                   0x2810eaa3 JNI_CreateJavaVM_Impl + 53971
          18  libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          19  libSystem.B.dylib                 0x990f9e66 thread_start + 34
          9   ???                               0x29903f17 0 + 697319191
          10  ???                               0x29903f17 0 + 697319191
          11  ???                               0x299012d3 0 + 697307859
          12  libclient.dylib                   0x281a5f70 JVM_Lseek + 149008
          13  libclient.dylib                   0x281a5d16 JVM_Lseek + 148406
          14  libclient.dylib                   0x281b78bb JVM_InternString + 2123
          15  libclient.dylib                   0x281b772a JVM_InternString + 1722
          16  libclient.dylib                   0x281b7514 JVM_InternString + 1188
          17  libclient.dylib                   0x281b6faf JVM_StartThread + 2175
          18  libclient.dylib                   0x2810eaa3 JNI_CreateJavaVM_Impl + 53971
          19  libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          20  libSystem.B.dylib                 0x990f9e66 thread_start + 34
          5   libclient.dylib                   0x2810ec19 JNI_CreateJavaVM_Impl + 54345
          6   libclient.dylib                   0x281ce817 JVM_IsPrimitiveClass + 7639
          7   libclient.dylib                   0x281ce391 JVM_IsPrimitiveClass + 6481
          8   libclient.dylib                   0x281b7514 JVM_InternString + 1188
          9   libclient.dylib                   0x281b6faf JVM_StartThread + 2175
          10  libclient.dylib                   0x2810eaa3 JNI_CreateJavaVM_Impl + 53971
          11  libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          12  libSystem.B.dylib                 0x990f9e66 thread_start + 34
          0   libSystem.B.dylib                 0x990cc936 semaphore_wait_trap + 10
          1   libclient.dylib                   0x281cf2de JVM_IsPrimitiveClass + 10398
          2   libclient.dylib                   0x281cf0ae JVM_IsPrimitiveClass + 9838
          3   libclient.dylib                   0x281b7514 JVM_InternString + 1188
          4   libclient.dylib                   0x281b6faf JVM_StartThread + 2175
          6   libclient.dylib                   0x281d0642 JVM_IsPrimitiveClass + 15362
          7   libclient.dylib                   0x281d041b JVM_IsPrimitiveClass + 14811
          6   libclient.dylib                   0x281d45b2 JVM_IsPrimitiveClass + 31602
          7   libclient.dylib                   0x281b7514 JVM_InternString + 1188
          8   libclient.dylib                   0x281b6faf JVM_StartThread + 2175
          9   libclient.dylib                   0x2810eaa3 JNI_CreateJavaVM_Impl + 53971
          10  libSystem.B.dylib                 0x990f9fe1 _pthread_start + 345
          11  libSystem.B.dylib                 0x990f9e66 thread_start + 34
          3   libclient.dylib                   0x281d588d JVM_IsPrimitiveClass + 36429
          4   libclient.dylib                   0x281d5433 JVM_IsPrimitiveClass + 35315
          Thread 19:
          0   libSystem.B.dylib                 0x990cca0e mach_wait_until + 10
          1   libSystem.B.dylib                 0x99154c05 nanosleep + 345
          2   com.adobe.flash.flbridge          0x216bd3e9 ScObjects::Thread::sleep(unsigned int) + 143
          3   com.adobe.flash.flbridge          0x216bd449 ScObjects::Thread::wait(unsigned int) + 23
          4   com.adobe.flash.flbridge          0x216ae20a ScObjects::BridgeTalkThread::run() + 332
          5   com.adobe.flash.flbridge          0x216bd70b ScObjects::Thread::go(void*) + 239
          Thread 20:
          2   ...ia.Flash Player.authplaylib    0x3899ad84 ExternalPlayer_Initialize + 2117252
          Thread 21:
          3   ...ia.Flash Player.authplaylib    0x3878927f 0x38485000 + 3162751
          4   ...ia.Flash Player.authplaylib    0x387ad2ff ExternalPlayer_Initialize + 95231
          5   ...ia.Flash Player.authplaylib    0x3878972f 0x38485000 + 3163951
          Thread 22:
          Thread 23:
          0   libSystem.B.dylib                 0x990cc95a semaphore_timedwait_signal_trap + 10
          1   libSystem.B.dylib                 0x990fa469 _pthread_cond_wait + 1066
          2   libSystem.B.dylib                 0x99129268 pthread_cond_timedwait_relative_np + 47
          3   ...ple.CoreServices.CarbonCore    0x95375435 TSWaitOnConditionTimedRelative + 242
          4   ...ple.CoreServices.CarbonCore    0x95375173 TSWaitOnSemaphoreCommon + 511
          5   ...ple.CoreServices.CarbonCore    0x9539931b TimerThread + 97
            eax: 0x00000000  ebx: 0x991d6c0b  ecx: 0xbfffeb8c  edx: 0x9912d972
            edi: 0xa0b87b10  esi: 0x09287814  ebp: 0xbfffeba8  esp: 0xbfffeb8c
             ss: 0x0000001f  efl: 0x00000286  eip: 0x9912d972   cs: 0x00000007
            cr2: 0x991c0b8b
          Binary Images:
          0x8feb000 -  0x8fecff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
          0x8ffa000 -  0x8ffaff7  libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
          0xa7e3000 -  0xa7f0ff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
          0x1e218000 - 0x1e2b9fc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
          0x1e397000 - 0x1e3defc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
          0x1e974000 - 0x1e975ff7  ATSHI.dylib ??? (???) <251A0D44-8909-BC8C-49DF-477BA8304FDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
          0x1e97a000 - 0x1e988fe7  libSimplifiedChineseConverter.dylib ??? (???) <4C9CC2D9-2F13-4465-5447-2516FCD9255B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
          0x1e9b9000 - 0x1ea2bfff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
          0x1eafd000 - 0x1eb0fff7  libTraditionalChineseConverter.dylib ??? (???) <C4E0D62B-4D1A-8DAD-D10B-2C055AA0479C> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
          0x1ecc1000 - 0x1eceafef  com.apple.audio.CoreAudioKit 1.6 (1.6) <E9D5679D-0F3A-EE19-76F9-559F42E5DF8C> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
          0x1ed46000 - 0x1ed69ff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
          0x1ee79000 - 0x1ee7affc +com.yourcompany.ct_loader ??? (1.0.2.7) <EE2BE682-2821-E749-4A51-41216763456C> /Library/InputManagers/CTLoader/ct_loader.bundle/Contents/MacOS/ct_loader
          0x1eec0000 - 0x1f342fe3 +AdobeLM_libFNP.dylib ??? (???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/AdobeLM_libFNP.dylib
          0x1f684000 - 0x1f6b5fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/registration.framework/Versions/A/registration
          0x1f6ee000 - 0x1f74aff2 +AdobeUpdater ??? (???) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/A/AdobeUpdater
          0x20783000 - 0x2079eff7  com.apple.OpenTransport 10.6.0 (10.6.0) <ECA6FEC6-5ECD-51BA-162F-CFC43899196A> /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
          0x207af000 - 0x207c702f +com.macromedia.Flash.FLAir 10.0.0 (10.0.0 d544) <33151461-3D89-4331-936C-4737D11C97F1> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLAir1_1.bundle/Contents/MacOS/FLAir1_1
          0x207d3000 - 0x207eafff +com.macromedia.Flash.FLAir 10.0.1 (10.0.1 d156) <88E2D410-7BBD-46EC-BF99-21E2ED7BF9E9> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLAir1_5.bundle/Contents/MacOS/FLAir1_5
          0x207f7000 - 0x207f9fff +com.macromedia.Flash.FLfile 10.0.0.544 (10.0.0) <A983B337-B19A-4DC7-B46A-2AE8F683B3B8> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
          0x2090d000 - 0x2090dfff +com.macromedia.Flash.flastoragelib 9.0 (9.0) <4A09437D-BEFE-48C6-A7B5-5C094044AA9E> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
          0x20a36000 - 0x20a99feb +com.yourcompany.Brush ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
          0x20b08000 - 0x20b10ff7  libverify.dylib ??? (???) <0B49EBEC-AC21-9771-4616-D7507CDA7B4D> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
          0x2159f000 - 0x2161bff7 +com.yourcompany.Collision ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
          0x2168d000 - 0x216d1fe3 +com.adobe.flash.flbridge 10.0.0.544 (10.0.0) <E556D6D9-DA9B-435F-93D5-D10A357EC120> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
          0x21703000 - 0x21718ff7 +com.yourcompany.PointGrid ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
          0x21755000 - 0x2175cff7  JavaNativeFoundation ??? (???) <41C861E0-F76F-9EEE-9BB4-F924CDF763DD> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
          0x2176c000 - 0x21778ff7  libzip.jnilib ??? (???) <34AB8700-84F9-168C-0B27-BFA9607D2C7E> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
          0x223ec000 - 0x22409ff7  libjava.jnilib ??? (???) <C134666B-0870-1793-EF20-0A4510394309> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
          0x25b00000 - 0x25bcffcb  com.apple.carbonbundletemplate 1.0 (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FlashIK.bundle/Contents/MacOS/FlashIK
          0x28100000 - 0x284f6ff7  libclient.dylib ??? (???) <84358FE1-AD10-6876-1539-4B09901E17E1> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
          0x38485000 - 0x38b2cfef +com.macromedia.Flash Player.authplaylib 10.0.22.91 (1.0.1d333) <E1ED442D-0B91-D633-DA20-E6615B1D479B> /Applications/Adobe Flash CS4/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
          0x90003000 - 0x90094fe3  com.apple.print.framework.PrintCore 6.0 (312) <C588530A-0F2C-DD72-E308-3B8735125189> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x90095000 - 0x9009eff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x9009f000 - 0x9009fff7  com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x900a0000 - 0x900aaff7  libGL.dylib ??? (???) <B375A3B6-2983-A4E4-50FB-9087FD606FD6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x900ab000 - 0x900aeff7  libCoreVMClient.dylib ??? (???) <16BB2178-B32D-E57E-F1E4-D177F7754232> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x900af000 - 0x90113ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
          0x90114000 - 0x90117ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x90118000 - 0x901c7ff3  com.apple.ink.framework 1.3 (104) <8526D880-D367-3EF9-DBFD-9A6AB240F57A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x901cd000 - 0x901e9fe3  com.apple.openscripting 1.3 (???) <D2FF4419-FD71-5D4A-F397-B03E82085232> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x901ea000 - 0x90291fe7  com.apple.CFNetwork 454.4 (454.4) <7C563385-9893-3B48-8607-5BC81DA2C4CF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x90292000 - 0x90363ff3  ColorSyncDeprecated.dylib ??? (???) <AFD6DAC8-12EF-B2A0-5322-E902D5B48B0A> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
          0x90395000 - 0x904bdfe7  com.apple.CoreData 102 (246) <E7E6CE39-9B51-13C8-FE31-8FE57CF7BDE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x9086f000 - 0x9086fff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x90870000 - 0x90870ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x90871000 - 0x9087dff7  libkxld.dylib ??? (???) <152C8DBB-0149-5827-3240-E57CA85CFE5F> /usr/lib/system/libkxld.dylib
          0x90886000 - 0x908a8ff3  com.apple.DirectoryService.Framework 3.6 (621) <61569C79-6567-BE8F-4F76-BAC04E5FBF79> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x908a9000 - 0x90951ff7  com.apple.QD 3.31 (???) <40FCAC85-4E4F-2290-90D4-F66D550ADFDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x90952000 - 0x9095fff7  com.apple.NetFS 3.2 (3.2) <E6FD80B0-0238-0C42-A3EC-EBDEC107A1C3> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x90960000 - 0x90b72fff  com.apple.RawCamera.bundle 2.2.1 (477) <10937A0D-0856-1B69-AE27-43BC15B7DD21> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x90ba8000 - 0x90bacff7  IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x90bba000 - 0x90c52fe7  edu.mit.Kerberos 6.5.8 (6.5.8) <BA9BD282-FF56-3BFD-E78C-7DBE73B48480> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x90d2e000 - 0x90d43fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x90d7c000 - 0x90d7ffe7  libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
          0x90d99000 - 0x90e36ff3  com.apple.LaunchServices 360.3 (360.3) <C8590D53-E46A-F58A-7CF2-03A8159D8569> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x90e3f000 - 0x90e69ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x90e6a000 - 0x90ec4ff7  com.apple.framework.IOKit 2.0 (???) <7618DDEC-2E3B-9C6E-FDC9-15169E24B4FB> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x91107000 - 0x91119ff7  com.apple.MultitouchSupport.framework 200.20 (200.20) <1D7EE15B-ADDD-1F57-F1FB-FB5252910D5A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x9111a000 - 0x91150fff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
          0x91171000 - 0x911bafe7  libTIFF.dylib ??? (???) <6EF87001-6FB4-1405-C588-F6D8042D3534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x911bb000 - 0x91225fe7  libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
          0x91280000 - 0x9140efff  com.apple.JavaScriptCore 6531 (6531.5) <DDDCCE57-42D2-BAA1-63F1-F76458EE0927> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x91479000 - 0x914caff7  com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x914cb000 - 0x91567fe7  com.apple.ApplicationServices.ATS 4.0 (???) <81700C90-2614-F7E2-CC6A-B01C24A2BD75> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x915a1000 - 0x915a1ff7  com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x915aa000 - 0x91687ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x91688000 - 0x916e8fe7  com.apple.CoreText 3.0.0 (???) <8F4FCAE2-8E6F-F0DE-A6AA-15D0228B7F13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x916e9000 - 0x91798fef  com.apple.ColorSync 4.6.0 (4.6.0) <66ABAE86-B0EC-D641-913D-08ACA965F9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x91799000 - 0x9188fff7  libGLProgrammability.dylib ??? (???) <B8E40851-3A01-7D01-2F96-537BF7FA63B5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x91977000 - 0x91979ff7  libRadiance.dylib ??? (???) <0E03CF64-0931-7B9A-F617-4387B809D6D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x91b71000 - 0x91c72fe7  libxml2.2.dylib ??? (???) <C242A74D-280A-90C3-3F79-891624AA45D2> /usr/lib/libxml2.2.dylib
          0x91c73000 - 0x91c97ff7  libJPEG.dylib ??? (???) <265DBF67-994E-E320-4CB1-9C3DE792C3B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x91d08000 - 0x91d0efff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x91d0f000 - 0x91d23fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
          0x91d24000 - 0x91e07ff7  com.apple.WebKit 6531 (6531.9) <991912FB-1484-A0B2-593F-A8722BC6AFE7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x91e08000 - 0x91e0cff7  libGFXShared.dylib ??? (???) <ED62E870-E219-C873-88AA-9CE08108F811> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x91fa8000 - 0x91fa9ff7  com.apple.TrustEvaluationAgent 1.0 (1) <71E2DA16-83EC-6056-FFEE-862A04B5599F> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x9220a000 - 0x92214ff7  libCSync.A.dylib ??? (???) <A05BB12D-CD51-DE43-323B-3A3E99A3EED5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x92215000 - 0x92259fe7  com.apple.Metadata 10.6.0 (507.1) <CBD1B22B-5F10-C784-03A2-35106B97DF3F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x9225a000 - 0x92278ff7  com.apple.CoreVideo 1.6.0 (43.0) <3A853574-DD9E-08D8-FD2C-6221B55C3E08> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x92279000 - 0x92279ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x92285000 - 0x922abfff  com.apple.DictionaryServices 1.1 (1.1) <07694B30-56A9-5C98-B8BC-DA0628715FA8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x922ac000 - 0x922f9feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
          0x922fa000 - 0x9256affb  com.apple.Foundation 6.6 (751) <A61B645E-1A15-5BCA-3043-C8AB85C6AD30> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x9256b000 - 0x9259cff7  libGLImage.dylib ??? (???) <0FB347C7-A579-4E51-4733-39AB28064554> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x9259d000 - 0x925a1ff7  libGIF.dylib ??? (???) <51848EBF-27D4-0F85-C22A-D1AE10D328F3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x925a2000 - 0x925a7ff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x925a8000 - 0x925a9ff7  com.apple.audio.units.AudioUnit 1.6 (1.6) <68180B96-381C-A09D-5576-606A134FD953> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x9261b000 - 0x92694ff3  com.apple.audio.CoreAudio 3.2.0 (3.2) <91AE891E-6015-AABE-3512-2D5EBCA0937B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x92695000 - 0x92aabff7  libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x92aee000 - 0x92af1ff7  libCGXType.A.dylib ??? (???) <3FB5E457-EABF-B33E-E01B-C695FB2D72EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
          0x92af2000 - 0x92e15fef  com.apple.HIToolbox 1.6.0 (???) <6F95AF67-678A-D8BC-FFC2-029C9AA2F44A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x92e16000 - 0x92e2eff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x92e2f000 - 0x92ef9fef  com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x930a6000 - 0x930adff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
          0x93176000 - 0x931a7ff3  libTrueTypeScaler.dylib ??? (???) <F326E053-7425-2F10-F883-CBD56A1E1B72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x931a8000 - 0x931b6fe7  libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
          0x9320e000 - 0x93254ff7  libauto.dylib ??? (???) <FAB17F30-A28B-E33D-6E21-C7119C9C83ED> /usr/lib/libauto.dylib
          0x93255000 - 0x93330fef  com.apple.DesktopServices 1.5.0 (1.5.0) <5295C246-805B-DBCD-BA61-1AE9A458CF73> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x93410000 - 0x93774ff7  com.apple.QuartzCore 1.6.0 (226.0) <7E29DD09-BE04-AA06-5C81-5C093F16901B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x93c90000 - 0x93c9aff7  com.apple.HelpData 2.0.3 (33) <AD60F037-CE57-C93A-F865-2CEEE3F08F31> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x93c9b000 - 0x93cbbfe7  libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
          0x93cbc000 - 0x93e3efe7  libicucore.A.dylib ??? (???) <FBB66376-CBA9-8149-A1AA-10AB8578C3B3> /usr/lib/libicucore.A.dylib
          0x93e3f000 - 0x93e53ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x93e54000 - 0x93e54ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
          0x93e5c000 - 0x93e84ff7  libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
          0x93e85000 - 0x94761ff7  com.apple.AppKit 6.6 (1038) <25DDEBFC-8A2F-8434-1D97-AEC55B5205F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x94930000 - 0x94a39fe7  com.apple.CoreAUC 4.10.0 (4.10.0) <34606DCE-1257-8FB9-E633-AC56DD263EAB> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x94a95000 - 0x94b47ffb  libFontParser.dylib ??? (???) <EB089832-660F-0B34-3AC8-CCDA937987D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x94b48000 - 0x9532dfe7  com.apple.WebCore 6531 (6531.9) <F9A9848B-9EB0-B912-49F5-7E8010AF2CF1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x9532e000 - 0x9564dfe7  com.apple.CoreServices.CarbonCore 859.1 (859.1) <2E72AF56-4BE6-294A-7372-19C360688B8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x9564e000 - 0x9569efe7  libGLU.dylib ??? (???) <55A69DCE-1237-341E-F239-CDFE1F5B19BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x956b2000 - 0x9575ffe7  libobjc.A.dylib ??? (???) <410DD065-A18F-F054-0457-65525F4D1039> /usr/lib/libobjc.A.dylib
          0x9579f000 - 0x9595bfef  com.apple.ImageIO.framework 3.0.0 (3.0.0) <A37E541F-3D6A-2BE9-AB32-F60CCDE13608> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x9595c000 - 0x95ad3fef  com.apple.CoreFoundation 6.6 (550) <193E33D6-2E92-3452-773B-60A1A9CCC573> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x95b05000 - 0x95b38ff7  com.apple.AE 496 (496) <B638FDD4-7322-F0E4-ACEB-777D8A1399E1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x95b58000 - 0x95c4cfe7  libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
          0x95cc5000 - 0x95d08ff7  com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
          0x95d09000 - 0x964ea497  com.apple.CoreGraphics 1.535.5 (???) <0B93D29C-D957-AD00-10F3-94112D75D6D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x964eb000 - 0x97479ff7  com.apple.QuickTimeComponents.component 7.6.3 (1584) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
          0x974bf000 - 0x9750fff7  com.apple.framework.familycontrols 2.0 (2.0) <50617342-E578-4C1C-938A-19A37ECA91CA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x97510000 - 0x9757fff7  libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x97583000 - 0x9763cfe7  libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
          0x9774b000 - 0x9777fff7  libcups.2.dylib ??? (???) <9078BA07-DEE1-6597-D15D-7BE3A20CB5A0> /usr/lib/libcups.2.dylib
          0x977c1000 - 0x977c8fff  com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x977c9000 - 0x97ac2fef  com.apple.QuickTime 7.6.3 (1584) <687233E1-F428-5224-08D5-5874BEA2300D> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
          0x97b24000 - 0x97b3fff7  libPng.dylib ??? (???) <38DD4AA1-0643-85A0-F2F5-EE9269729975> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x97e18000 - 0x97e52fe7  libFontRegistry.dylib ??? (???) <EE633CF6-8827-EF05-10A4-5F2937120227> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x97e53000 - 0x97e95fe7  libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x97e96000 - 0x97ed7ff7  libRIP.A.dylib ??? (???) <6DB158C6-A84D-98C9-1D48-868A3DB17D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x97ed8000 - 0x97ee5ff7  com.apple.opengl 1.6.3 (1.6.3) <59D86286-B46F-B0E4-68F8-E5CDCADE393E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x980c7000 - 0x982a2ff3  libType1Scaler.dylib ??? (???) <BD3674DE-EAD9-C57A-0072-3C18970DCC1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
          0x982a3000 - 0x982a3ff7  com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x982a4000 - 0x982a4ff7  com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x982a5000 - 0x98327ffb  SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x98328000 - 0x98332fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
          0x98390000 - 0x985f2ff3  com.apple.security 6.0 (36910) <F045B57C-054F-F06F-EF7E-EABEC2700274> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x988e7000 - 0x98906fe7  com.apple.opencl 11 (11) <372A42E7-FB10-B74D-E1A0-980E94D07021> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x98943000 - 0x9894dffb  com.apple.speech.recognition.framework 3.10.10 (3.10.10) <E106CC3A-7633-5587-0B29-64E19FCBC613> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x9894e000 - 0x9895fff7  com.apple.LangAnalysis 1.6.5 (1.6.5) <E77440D0-76EE-EB4C-3D00-9EDE417F13CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x98962000 - 0x9899fff7  com.apple.SystemConfiguration 1.10 (1.10) <897AEEAF-CF5D-2843-C33B-31A0A7C98A6A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x989a0000 - 0x989b0ff7  libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
          0x989b1000 - 0x989b3ff7  com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x98a2f000 - 0x98a73ff3  com.apple.coreui 0.2 (112) <A810DFFD-6314-5E2B-93A4-D5626634B1EE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x98a74000 - 0x98b23fe3  com.apple.QuickTimeImporters.component 7.6.3 (1584) <34BF4FBA-BFCD-9A47-4BA9-E2B155C5C881> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
          0x98b24000 - 0x98f59ff7  libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x98fa2000 - 0x990cbfe7  com.apple.audio.toolbox.AudioToolbox 1.6 (1.6) <62BEEBE6-68FC-4A48-91CF-39DA2BD793F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x990cc000 - 0x99270feb  libSystem.B.dylib ??? (???) <068CC3F2-F867-A231-A16C-CC01C29A9816> /usr/lib/libSystem.B.dylib
          0x99274000 - 0x992f4feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x9933d000 - 0x9942fff7  libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
          Model: MacBookPro5,5, BootROM MBP55.00AC.B03, 2 processors, Intel Core 2 Duo, 2.26 GHz, 4 GB, SMC 1.47f2
          Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
          AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.19)
          Network Service: AirPort, AirPort, en1
          Serial ATA Device: Hitachi HTS545025B9SA02, 232.89 GB
          Serial ATA Device: HL-DT-ST DVDRW  GS23N
          USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0x24400000
          USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0x26500000
          USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0236, 0x04600000
          USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
          USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
          USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8213, 0x06110000
          • 2. Re: Snowleopard & Flash CS4 (Crash)
            damonlee3
            Yup,  Flash CS4 is crashing on me as well.  Just like you said, around 4 seconds after I choose to create a new file (AS3)
            • 3. Re: Snowleopard & Flash CS4 (Crash)
              MadRichard
              Same exact problem here (on late '08 MacBook Pro). Flash CS4 quits after a few seconds, every time, no matter what. Lost a day of work troubleshooting, re-installing, scouring the Internet for answers, etc. Ultimately, the only solution was to revert back to OS 10.5.8.
              I would be profoundly grateful to whomever sorts this out!!!
              • 4. Re: Snowleopard & Flash CS4 (Crash)
                axxxo Level 1
                Same here. I searched all over the web. No feedback from Adobe, nothing from Apple. Quite frustrating.
                I'll downgrade my whole system tonight. Snowleopard is just a mess.
                • 5. Re: Snowleopard & Flash CS4 (Crash)
                  BIG!GFX Level 1
                  I can create a new AS3 project without a problem but I cannot publish any project without a crash. Last night was the first time I opened Flash since my SL install on Friday. I was able to publish a project a few times with no problem but when I went to work on another it would hang up in the middle of exporting the swf for a few seconds and then crash. I went back to my previous project that I had just exported and it would crash too.
                  I am using a MacBook Pro 15" with SL 10.6
                  All my other Adobe apps seem to work fine
                  • 6. Re: Snowleopard & Flash CS4 (Crash)
                    damonlee3 Level 1
                    hey guys,
                    try running the adobe updater then re-boot.  That seems to have fixed any crashes
                    • 7. Re: Snowleopard & Flash CS4 (Crash)
                      unchartedrealms
                      install snow leopard upgrade 10.6.1
                        start flash
                         flash crashes after a few seconds
                         over and over and over
                      macbook pro
                      2.5Ghz intel core 2 duo
                      • 8. Re: Snowleopard & Flash CS4 (Crash)
                        dmvjs Level 1
                        i did a clean reinstall (erased my hd and installed 10.6) of snow leopard and then installed cs4 works much faster and better...amazing!
                        • 9. Re: Snowleopard & Flash CS4 (Crash)
                          kevinis
                          I had the same problem with Flash CS4 crashing as soon as I tried to open a file or start a new one. Adobe has a new TechNote about fonts http://kb2.adobe.com/cps/327/327791.html. I followed step 7 and removed all fonts then put them back a few at a time. I narrowed it down to one font: Franklin Gothic Book Regular. Once I removed this font (mine was in Users/Library/Fonts), Flash CS4 seems to be working fine. Fingers crossed it keeps working! There was also a website that Flash player crashed in Safari. That's seems to be working now too. Still crashes in Firefox though. Good luck!
                          • 10. Re: Snowleopard & Flash CS4 (Crash)
                            unchartedrealms Level 1
                            wow.  I have that font in my library too. and Flash began working again the other day after I went to my font book and verified all fonts and erased a fonts with errors.  so far flash has not crashed again. and Im still in snow leopard.  I thought I would have to go back to leopard.  Good news it seams spaces on my mac now works fine with CS4..
                            • 11. Re: Snowleopard & Flash CS4 (Crash)
                              dmckdesign
                              yep it seems like its the font issue, had a same problem, flash cs4 would crash everytime, few seconds after opening a file ... removing all fonts and adding them in groups until you find the one that causes flash to crash, helped. cheers guys, you saved me lots of whinging.
                              • 12. Updated: all's well
                                MadRichard Level 1
                                Yes, it was a font issue. Wiping my hard drive, installing Snow Leopard and re-installing CS4 suite did the trick.
                                Thanks, all.
                                • 13. Re: Snowleopard & Flash CS4 (Crash)
                                  foriaa82
                                  hey guy I tried to delete that font but I get the same problem still.
                                  How I can do someone can help me please?
                                  I have to deliver one project in the end of this weekend and after the update to snow leopard I can't work.
                                  this is my crash report:
                                  Process:         Adobe Flash CS4 [234]
                                  Path:            /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/Adobe Flash CS4
                                  Identifier:      com.adobe.flash-10.0
                                  Version:         10.0.0.544 (10.0.0)
                                  Code Type:       X86 (Native)
                                  Parent Process:  launchd [159]
                                  Date/Time:       2009-10-13 19:21:03.479 +0200
                                  OS Version:      Mac OS X 10.6.1 (10B504)
                                  Report Version:  6
                                  Interval Since Last Report:          186815 sec
                                  Crashes Since Last Report:           4
                                  Per-App Interval Since Last Report:  529 sec
                                  Anonymous UUID:                      E47C9194-625F-46CA-85F7-E30E91C1DEE8
                                  Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
                                  Exception Codes: KERN_INVALID_ADDRESS at 0x00000000fffff01a
                                  Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                  Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
                                  0   ???                               0x0a206610 _XHNDL_trapback_instruction + 0
                                  1   libFontParser.dylib               0x0cfc6ae9 TcmapUnicodeTable::Map(unsigned short const*, unsigned short*, unsigned int&) const + 269
                                  2   libFontParser.dylib               0x0cfc5ea7 TSFNTFont::GetGlyphsPerCharacters(unsigned short const*, unsigned short*, unsigned int&, bool) const + 69
                                  3   libTrueTypeScaler.dylib           0x1da66557 TTGetStrikeSpecs + 352
                                  4   ...ple.ApplicationServices.ATS    0x0bed02d5 HandleOFAScalerMessage + 1165
                                  5   ...ple.ApplicationServices.ATS    0x0becfdde SendStrikeMessage + 162
                                  6   ...ple.ApplicationServices.ATS    0x0bed30e4 _eOFAGetStrikeSpecs + 471
                                  7   ...ple.ApplicationServices.ATS    0x0becdc47 _eGetGlyphVectorIndex + 994
                                  8   ...ple.ApplicationServices.ATS    0x0becd0ef OldGlyphsCacheStrike(TStrike*, void (*)(StrikeSpecs const*, void const*), void*) + 136
                                  9   ...ple.ApplicationServices.ATS    0x0beccd3d _eGCGetStrikeMetrics + 65
                                  10  ...ple.ApplicationServices.ATS    0x0becb9e3 _eATSFontGetHorizontalMetrics + 173
                                  11  ...ple.ApplicationServices.ATS    0x0becb91c ATSFontGetHorizontalMetrics + 76
                                  12  com.adobe.flash-10.0              0x007bf5c1 0x1000 + 8119745
                                  13  com.adobe.flash-10.0              0x007c151f 0x1000 + 8127775
                                  14  com.adobe.flash-10.0              0x007c15f1 0x1000 + 8127985
                                  15  com.adobe.flash-10.0              0x007bd479 0x1000 + 8111225
                                  16  com.adobe.flash-10.0              0x007bd9bc 0x1000 + 8112572
                                  17  com.apple.HIToolbox               0x0a925104 IdleTimerVector + 62
                                  18  com.apple.CoreFoundation          0x03300eee __CFRunLoopRun + 6846
                                  19  com.apple.CoreFoundation          0x032fed34 CFRunLoopRunSpecific + 452
                                  20  com.apple.CoreFoundation          0x032feb61 CFRunLoopRunInMode + 97
                                  21  com.apple.HIToolbox               0x0a8d0fec RunCurrentEventLoopInMode + 392
                                  22  com.apple.HIToolbox               0x0a8d0da3 ReceiveNextEventCommon + 354
                                  23  com.apple.HIToolbox               0x0aa58cde _AcquireNextEvent + 54
                                  24  com.apple.HIToolbox               0x0aa4ea20 RunApplicationEventLoop + 228
                                  25  com.adobe.flash-10.0              0x0098dd31 0x1000 + 10014001
                                  26  com.adobe.flash-10.0              0x0089895f 0x1000 + 9009503
                                  27  com.adobe.flash-10.0              0x00898a0a 0x1000 + 9009674
                                  28  com.adobe.flash-10.0              0x00002f2a 0x1000 + 7978
                                  29  com.adobe.flash-10.0              0x00002e51 0x1000 + 7761
                                  Thread 1:  Dispatch queue: com.apple.libdispatch-manager
                                  0   libSystem.B.dylib                 0x099cd03a kevent + 10
                                  1   libSystem.B.dylib                 0x099cd768 _dispatch_mgr_invoke + 215
                                  2   libSystem.B.dylib                 0x099ccbf9 _dispatch_queue_invoke + 183
                                  3   libSystem.B.dylib                 0x099cc98a _dispatch_worker_thread2 + 234
                                  4   libSystem.B.dylib                 0x099cc401 _pthread_wqthread + 390
                                  5   libSystem.B.dylib                 0x099cc246 start_wqthread + 30
                                  Thread 2:
                                  0   libSystem.B.dylib                 0x099a6822 semaphore_wait_signal_trap + 10
                                  1   libSystem.B.dylib                 0x099d43d8 _pthread_cond_wait + 1089
                                  2   libSystem.B.dylib                 0x09a1d70f pthread_cond_wait + 48
                                  3   com.adobe.amt.services            0x1d09c552 AMTConditionLock::LockWhenCondition(int) + 46
                                  4   com.adobe.amt.services            0x1d097995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
                                  5   com.adobe.amt.services            0x1d09c5b0 AMTThread::Worker(void*) + 20
                                  6   libSystem.B.dylib                 0x099d3f39 _pthread_start + 345
                                  7   libSystem.B.dylib                 0x099d3dbe thread_start + 34
                                  Thread 3:
                                  0   libSystem.B.dylib                 0x099a67da mach_msg_trap + 10
                                  1   libSystem.B.dylib                 0x099a6f47 mach_msg + 68
                                  2   ...ple.CoreServices.CarbonCore    0x09fca2d8 TS_exception_listener_thread + 160
                                  3   libSystem.B.dylib                 0x099d3f39 _pthread_start + 345
                                  4   libSystem.B.dylib                 0x099d3dbe thread_start + 34
                                  Thread 4:
                                  0   libSystem.B.dylib                 0x099d4782 __semwait_signal + 10
                                  1   libSystem.B.dylib                 0x099d443e _pthread_cond_wait + 1191
                                  2   libSystem.B.dylib                 0x099d60d8 pthread_cond_wait$UNIX2003 + 73
                                  3   ...ple.CoreServices.CarbonCore    0x09f37a2a TSWaitOnCondition + 126
                                  4   ...ple.CoreServices.CarbonCore    0x09f2340d TSWaitOnConditionTimedRelative + 202
                                  5   ...ple.CoreServices.CarbonCore    0x09f1ed2f MPWaitOnQueue + 250
                                  6   AdobeACE                          0x056af38d 0x567e000 + 201613
                                  7   AdobeACE                          0x056aed85 0x567e000 + 200069
                                  8   ...ple.CoreServices.CarbonCore    0x09f029fa PrivateMPEntryPoint + 68
                                  9   libSystem.B.dylib                 0x099d3f39 _pthread_start + 345
                                  10  libSystem.B.dylib                 0x099d3dbe thread_start + 34
                                  Thread 5:
                                  0   libSystem.B.dylib                 0x099d9519 syscall + 5
                                  1   com.apple.OpenTransport           0x1f804851 CarbonSelectThreadFunc + 257
                                  2   libSystem.B.dylib                 0x099d3f39 _pthread_start + 345
                                  3   libSystem.B.dylib                 0x099d3dbe thread_start + 34
                                  Thread 6:
                                  3   com.apple.OpenTransport           0x1f800d73 CarbonOperationThreadFunc + 203
                                  4   libSystem.B.dylib                 0x099d3f39 _pthread_start + 345
                                  5   libSystem.B.dylib                 0x099d3dbe thread_start + 34
                                  Thread 7:
                                  0   libSystem.B.dylib                 0x099a68ee mach_wait_until + 10
                                  1   libSystem.B.dylib                 0x09a2ebe5 nanosleep + 345
                                  2   com.adobe.flash.flbridge          0x213a33e9 ScObjects::Thread::sleep(unsigned int) + 143
                                  3   com.adobe.flash.flbridge          0x213a3449 ScObjects::Thread::wait(unsigned int) + 23
                                  4   com.adobe.flash.flbridge          0x2139420a ScObjects::BridgeTalkThread::run() + 332
                                  5   com.adobe.flash.flbridge          0x213a370b ScObjects::Thread::go(void*) + 239
                                  Thread 8:
                                  2   ...ia.Flash Player.authplaylib    0x1e78435e ExternalPlayer_Initialize + 1867954
                                  Thread 9:
                                  3   ...ia.Flash Player.authplaylib    0x1e5aff92 0x1e2c8000 + 3047314
                                  4   ...ia.Flash Player.authplaylib    0x1e5d2375 ExternalPlayer_Initialize + 90313
                                  5   ...ia.Flash Player.authplaylib    0x1e5b0384 0x1e2c8000 + 3048324
                                  Thread 10:
                                  Thread 11:
                                  0   libSystem.B.dylib                 0x099c5756 select$DARWIN_EXTSN + 10
                                  1   com.apple.CoreFoundation          0x0333f04d __CFSocketManager + 1085
                                  Thread 12:
                                  0   libSystem.B.dylib                 0x099cc092 __workq_kernreturn + 10
                                  1   libSystem.B.dylib                 0x099cc628 _pthread_wqthread + 941
                                  2   libSystem.B.dylib                 0x099cc246 start_wqthread + 30
                                  Thread 0 crashed with X86 Thread State (32-bit):
                                    eax: 0x00000000  ebx: 0x0000001a  ecx: 0x00000000  edx: 0xbfffb1a8
                                    edi: 0xfffff01a  esi: 0x0d06eb90  ebp: 0xbfffb3c8  esp: 0xbf800f70
                                     ss: 0x0000001f  efl: 0x00010246  eip: 0x0a206610   cs: 0x00000017
                                     ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
                                    cr2: 0xfffff01a
                                  Binary Images:
                                      0x1000 -  0x1237048 +com.adobe.flash-10.0 10.0.0.544 (10.0.0) <915BD60E-E704-40AE-960F-EFD8A49EDDC5> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/Adobe Flash CS4
                                  0x1720000 -  0x17f2fe7 +AdobeAXEDOMCore ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                  0x18a6000 -  0x19332cb +libicucnv.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
                                  0x1960000 -  0x1a2f23b +libicui18n.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
                                  0x1ad8000 -  0x1bacdb7 +libicuuc.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
                                  0x1c0d000 -  0x25bd57f +libicudata.dylib.36.0 ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
                                  0x25c0000 -  0x25cffc3 +libChar16.dylib ??? (???) <B97A174D-CCAC-40FD-A8D1-2A3891CC5CDD> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/libChar16.dylib
                                  0x25d8000 -  0x25f0fc0 +libCoreTypes.dylib ??? (???) <7EEBDBBF-181B-4706-8A5D-10266B36304F> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/MacOS/libCoreTypes.dylib
                                  0x2613000 -  0x2622fef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/frameworks/ZLib.dylib
                                  0x2627000 -  0x283bfef  com.apple.carbonframeworktemplate 1.0 (1.0) <AC98929C-640F-4C7E-8737-9928CF7B8CD4> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
                                  0x2b84000 -  0x2e7dfef  com.apple.QuickTime 7.6.3 (1584) <687233E1-F428-5224-08D5-5874BEA2300D> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                                  0x2f29000 -  0x2f66ff7  com.apple.SystemConfiguration 1.10 (1.10) <897AEEAF-CF5D-2843-C33B-31A0A7C98A6A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                  0x2f83000 -  0x31e5ff3  com.apple.security 6.0 (36910) <F045B57C-054F-F06F-EF7E-EABEC2700274> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                  0x32c0000 -  0x32c0ff7  com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                  0x32c3000 -  0x343afef  com.apple.CoreFoundation 6.6 (550) <193E33D6-2E92-3452-773B-60A1A9CCC573> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                  0x3532000 -  0x3532ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                  0x353a000 -  0x361dff7  com.apple.WebKit 6531 (6531.9) <991912FB-1484-A0B2-593F-A8722BC6AFE7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                                  0x36a4000 -  0x36a4ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                  0x36a7000 -  0x36aeff7  com.apple.JavaVM 13.0.0 (13.0.0) <73B4CB4C-7C91-D148-E6DD-CFD578055BF7> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
                                  0x36b6000 -  0x4373fdf +com.adobe.illustrator 338 (14.0.0) <D8621BED-6312-45E6-89E1-F49896F3E87E> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
                                  0x546c000 -  0x54bcfff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <9B4C73DE-716B-4787-BB01-E1DDDC6DEA53> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
                                  0x5555000 -  0x55a4ff3 +FilterPort ??? (???) <66918FA0-9135-4C31-81DA-D4B5F8FDB798> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
                                  0x5643000 -  0x5644027 +SPBasic ??? (???) <9121C50E-FA52-4FA2-B299-AF180C3A1316> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
                                  0x5648000 -  0x5664ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                                  0x567e000 -  0x578bfff +AdobeACE ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                  0x57a9000 -  0x5cb1fff +AdobeAGM ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                  0x5e21000 -  0x5e60ff7 +AdobeARE ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                                  0x5e6a000 -  0x5e83fff +AdobeBIB ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                  0x5e8d000 -  0x5eaeff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                  0x5ebb000 -  0x6157fef +AdobeCoolType ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                  0x61e2000 -  0x65acfef +AdobeMPS ??? (???) <4E366E06-A4EB-4717-9639-0443743F5104> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                  0x663b000 -  0x6723fdf +AdobePDFPort ??? (???) <F54A25D1-5E7A-472E-83D1-10D187434C85> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                                  0x6768000 -  0x6d60fdf +AdobePDFL ??? (???) <D2996BF8-17D2-4801-93F7-2F227538DCD8> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                                  0x6ea4000 -  0x6ec8ff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                                  0x6edb000 -  0x6efdfed +AdobeAXE16SharedExpat ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
                                  0x6f18000 -  0x6f78fc7 +AdobeXMP ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                  0x6f87000 -  0x705cfdd +FileInfo ??? (???) <F0932F89-FC98-4BA9-B4F2-C58D0E71D3C1> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                                  0x708d000 -  0x70a0fff +com.adobe.AdobeSFL AdobeSFL 1.1 (1.1.0.12) <6B1D574E-0F4A-4B80-82F6-7DF7AA9C50CD> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
                                  0x70a7000 -  0x72a1fef +AdobeOwl ??? (???) <466BD72B-E2A5-447A-9384-B6DC9AD3AE0C> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                  0x731c000 -  0x804efff +com.adobe.psl AdobePSL 11.0.0.1724 (11.0.0.1724) <6BE27A60-E0F9-4483-8E57-2A7A5227D878> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                                  0x8382000 -  0x83dcff7  com.apple.framework.IOKit 2.0 (???) <7618DDEC-2E3B-9C6E-FDC9-15169E24B4FB> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                  0x83fb000 -  0x87d501f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                                  0x8889000 -  0x888ffff +com.adobe.AdobeCrashReporter 2.5 (2.5.02272007) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                  0x8896000 -  0x88b2fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
                                  0x88bd000 -  0x89befe7  libxml2.2.dylib ??? (???) <C242A74D-280A-90C3-3F79-891624AA45D2> /usr/lib/libxml2.2.dylib
                                  0x89e2000 -  0x8c2afc7 +dvaui ??? (???) <6B82E781-8BA9-4287-89F1-339854AC1D32> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                                  0x8f14000 -  0x9077ff4 +dvacore ??? (???) <98D9BE6F-6D5E-4070-AD40-332F83CAC417> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                  0x9211000 -  0x933afe7  com.apple.audio.toolbox.AudioToolbox 1.6 (1.6) <62BEEBE6-68FC-4A48-91CF-39DA2BD793F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                  0x93a0000 -  0x9556ff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <CB2EC3BF-6771-4DAB-BF29-6775FB6F9608> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                  0x958d000 -  0x95bcff7 +com.adobe.headlights.LogSessionFramework ??? (2.0.0.06112008) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                  0x95e4000 -  0x95f5ffb +LogTransport2 ??? (???) <835B7B84-5A67-370B-AB39-8E448AA81FA0> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogTransport2.framework/Versions/A/LogTransport2
                                  0x95ff000 -  0x9605fff +com.adobe.pip ??? (1.0.0.220) <2CA89939-DFA7-4686-8536-8A1F1107CAF1> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
                                  0x960b000 -  0x969bfc3 +WRServices ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                  0x981d000 -  0x9880027 +com.adobe.PlugPlug 1.0.0.71 (1.0.0.71) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                                  0x98e1000 -  0x994bfe7  libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
                                  0x99a6000 -  0x9b4afeb  libSystem.B.dylib ??? (???) <E58B649F-FFDC-AB09-2028-8B706BEF7C0F> /usr/lib/libSystem.B.dylib
                                  0x9bca000 -  0x9c10ff7  libauto.dylib ??? (???) <FAB17F30-A28B-E33D-6E21-C7119C9C83ED> /usr/lib/libauto.dylib
                                  0x9c1d000 -  0x9d9ffe7  libicucore.A.dylib ??? (???) <FBB66376-CBA9-8149-A1AA-10AB8578C3B3> /usr/lib/libicucore.A.dylib
                                  0x9e01000 -  0x9eaefe7  libobjc.A.dylib ??? (???) <410DD065-A18F-F054-0457-65525F4D1039> /usr/lib/libobjc.A.dylib
                                  0x9ec3000 -  0x9ed1fe7  libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
                                  0x9ed6000 -  0x9ed9fe7  libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
                                  0x9edc000 -  0xa1fbfe7  com.apple.CoreServices.CarbonCore 859.1 (859.1) <2E72AF56-4BE6-294A-7372-19C360688B8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                  0xa26f000 -  0xa316fe7  com.apple.CFNetwork 454.4 (454.4) <7C563385-9893-3B48-8607-5BC81DA2C4CF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                                  0xa378000 -  0xa3bcfe7  com.apple.Metadata 10.6.0 (507.1) <CBD1B22B-5F10-C784-03A2-35106B97DF3F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                  0xa3e3000 -  0xa4adfef  com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                  0xa50c000 -  0xa58cfeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                  0xa5c0000 -  0xa5f3ff7  com.apple.AE 496 (496) <B638FDD4-7322-F0E4-ACEB-777D8A1399E1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                  0xa60b000 -  0xa6a8ff3  com.apple.LaunchServices 360.3 (360.3) <C8590D53-E46A-F58A-7CF2-03A8159D8569> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                  0xa6e7000 -  0xa70dfff  com.apple.DictionaryServices 1.1 (1.1) <07694B30-56A9-5C98-B8BC-DA0628715FA8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                  0xa724000 -  0xa72dff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                  0xa737000 -  0xa74bfe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
                                  0xa754000 -  0xa761ff7  com.apple.NetFS 3.2 (3.2) <E6FD80B0-0238-0C42-A3EC-EBDEC107A1C3> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                  0xa76a000 -  0xa776ff7  libkxld.dylib ??? (???) <152C8DBB-0149-5827-3240-E57CA85CFE5F> /usr/lib/system/libkxld.dylib
                                  0xa77a000 -  0xa833fe7  libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
                                  0xa841000 -  0xa869ff7  libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
                                  0xa874000 -  0xa87efe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                                  0xa886000 -  0xa88cfff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                  0xa894000 -  0xa897ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                  0xa89c000 -  0xabbffef  com.apple.HIToolbox 1.6.0 (???) <6F95AF67-678A-D8BC-FFC2-029C9AA2F44A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                  0xacfe000 -  0xad62ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                                  0xad84000 -  0xad99fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                  0xadaf000 -  0xae5eff3  com.apple.ink.framework 1.3 (104) <8526D880-D367-3EF9-DBFD-9A6AB240F57A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                  0xae88000 -  0xaecbff7  com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                                  0xaef4000 -  0xaf10fe3  com.apple.openscripting 1.3 (???) <D2FF4419-FD71-5D4A-F397-B03E82085232> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                  0xaf20000 -  0xaf22ff7  com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                  0xaf27000 -  0xaf31ffb  com.apple.speech.recognition.framework 3.10.10 (3.10.10) <E106CC3A-7633-5587-0B29-64E19FCBC613> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                  0xaf3a000 -  0xaf3aff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                  0xaf42000 -  0xafbbff3  com.apple.audio.CoreAudio 3.2.0 (3.2) <91AE891E-6015-AABE-3512-2D5EBCA0937B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                  0xafed000 -  0xb25dffb  com.apple.Foundation 6.6 (751) <A61B645E-1A15-5BCA-3043-C8AB85C6AD30> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                  0xb36c000 -  0xbb4d497  com.apple.CoreGraphics 1.535.5 (???) <0B93D29C-D957-AD00-10F3-94112D75D6D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                  0xbc14000 -  0xbdd0fef  com.apple.ImageIO.framework 3.0.0 (3.0.0) <A37E541F-3D6A-2BE9-AB32-F60CCDE13608> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                                  0xbe2a000 -  0xbe8afe7  com.apple.CoreText 3.0.0 (???) <8F4FCAE2-8E6F-F0DE-A6AA-15D0228B7F13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                                  0xbec2000 -  0xbf5efe7  com.apple.ApplicationServices.ATS 4.0 (???) <81700C90-2614-F7E2-CC6A-B01C24A2BD75> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                  0xbf85000 -  0xc034fef  com.apple.ColorSync 4.6.0 (4.6.0) <66ABAE86-B0EC-D641-913D-08ACA965F9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                  0xc06b000 -  0xc0bcff7  com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                  0xc0e6000 -  0xc0f7ff7  com.apple.LangAnalysis 1.6.5 (1.6.5) <E77440D0-76EE-EB4C-3D00-9EDE417F13CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                  0xc104000 -  0xc1acff7  com.apple.QD 3.31 (???) <40FCAC85-4E4F-2290-90D4-F66D550ADFDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                  0xc1d8000 -  0xc1ecffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                  0xc1fa000 -  0xc1faff7  com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                  0xc1fd000 -  0xc246fe7  libTIFF.dylib ??? (???) <6EF87001-6FB4-1405-C588-F6D8042D3534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                                  0xc251000 -  0xc255ff7  libGIF.dylib ??? (???) <51848EBF-27D4-0F85-C22A-D1AE10D328F3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                                  0xc25a000 -  0xc275ff7  libPng.dylib ??? (???) <38DD4AA1-0643-85A0-F2F5-EE9269729975> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                                  0xc27c000 -  0xc27eff7  libRadiance.dylib ??? (???) <0E03CF64-0931-7B9A-F617-4387B809D6D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                                  0xc282000 -  0xc2a6ff7  libJPEG.dylib ??? (???) <265DBF67-994E-E320-4CB1-9C3DE792C3B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                                  0xc2ad000 -  0xc38aff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                  0xc398000 -  0xc398ff7  com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                  0xc39b000 -  0xc3ddfe7  libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                  0xc3e6000 -  0xc455ff7  libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                  0xc45e000 -  0xc874ff7  libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                  0xc8b6000 -  0xccebff7  libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                  0xce71000 -  0xcf63ff7  libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
                                  0xcfb5000 -  0xcfb6ff7  com.apple.TrustEvaluationAgent 1.0 (1) <71E2DA16-83EC-6056-FFEE-862A04B5599F> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                  0xcfba000 -  0xd06cffb  libFontParser.dylib ??? (???) <EB089832-660F-0B34-3AC8-CCDA937987D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                  0xd0fb000 -  0xd12fff7  libcups.2.dylib ??? (???) <9078BA07-DEE1-6597-D15D-7BE3A20CB5A0> /usr/lib/libcups.2.dylib
                                  0xd13c000 -  0xd15cfe7  libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
                                  0xd166000 -  0xd1aaff3  com.apple.coreui 0.2 (112) <A810DFFD-6314-5E2B-93A4-D5626634B1EE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                  0xd1c9000 -  0xd52dff7  com.apple.QuartzCore 1.6.0 (226.0) <7E29DD09-BE04-AA06-5C81-5C093F16901B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                  0xd5fc000 -  0xd6d6fff  com.apple.DesktopServices 1.5.1 (1.5.1) <D9C18268-699B-A996-1035-4EA3695F4074> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                  0xd721000 -  0xd771ff7  com.apple.framework.familycontrols 2.0 (2.0) <50617342-E578-4C1C-938A-19A37ECA91CA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                  0xd788000 -  0xd79aff7  com.apple.MultitouchSupport.framework 200.20 (200.20) <1D7EE15B-ADDD-1F57-F1FB-FB5252910D5A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                  0xd7a7000 -  0xd7c5ff7  com.apple.CoreVideo 1.6.0 (43.0) <3A853574-DD9E-08D8-FD2C-6221B55C3E08> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                  0xd7dc000 -  0xd7e9ff7  com.apple.opengl 1.6.3 (1.6.3) <59D86286-B46F-B0E4-68F8-E5CDCADE393E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                  0xd7f0000 -  0xd821ff7  libGLImage.dylib ??? (???) <0FB347C7-A579-4E51-4733-39AB28064554> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                  0xd828000 -  0xd847fe7  com.apple.opencl 11 (11) <372A42E7-FB10-B74D-E1A0-980E94D07021> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                  0xd850000 -  0xd854ff7  IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                  0xd85c000 -  0xd8acfe7  libGLU.dylib ??? (???) <55A69DCE-1237-341E-F239-CDFE1F5B19BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                  0xd8bf000 -  0xd8c9ff7  libGL.dylib ??? (???) <B375A3B6-2983-A4E4-50FB-9087FD606FD6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                  0xd8d8000 -  0xd9ceff7  libGLProgrammability.dylib ??? (???) <B8E40851-3A01-7D01-2F96-537BF7FA63B5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                  0xd9ef000 -  0xd9f2ff7  libCoreVMClient.dylib ??? (???) <16BB2178-B32D-E57E-F1E4-D177F7754232> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                  0xd9f7000 -  0xd9fbff7  libGFXShared.dylib ??? (???) <ED62E870-E219-C873-88AA-9CE08108F811> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                  0xda00000 -  0xda01ff7  com.apple.audio.units.AudioUnit 1.6 (1.6) <68180B96-381C-A09D-5576-606A134FD953> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                  0xda06000 -  0xda06ff7  com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                  0xda09000 -  0xda8bffb  SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                  0xdac2000 -  0xdac7ff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                  0xdacf000 -  0xdae7ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                  0xdaf8000 -  0xdb45feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
                                  0xdb61000 -  0xdb83ff3  com.apple.DirectoryService.Framework 3.6 (621) <61569C79-6567-BE8F-4F76-BAC04E5FBF79> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                  0xdb8d000 -  0xdb9dff7  libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
                                  0xdba4000 -  0xdcccfe7  com.apple.CoreData 102 (246) <E7E6CE39-9B51-13C8-FE31-8FE57CF7BDE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                  0xdd2e000 -  0xdebcfff  com.apple.JavaScriptCore 6531 (6531.5) <DDDCCE57-42D2-BAA1-63F1-F76458EE0927> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                  0xdf0b000 -  0xe6f0fe7  com.apple.WebCore 6531 (6531.9) <F9A9848B-9EB0-B912-49F5-7E8010AF2CF1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                                  0xeb75000 -  0xf452ff7  com.apple.AppKit 6.6.1 (1038.2) <27C304F6-0045-160B-7591-E57ECF19BDDB> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                  0xf8ea000 -  0xf8eaff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
                                  0xf8ee000 -  0xf9e2fe7  libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
                                  0xf9e8000 -  0xfa28ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                                  0xfa41000 -  0xfaf6fe7  libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
                                  0xfb3c000 -  0xfb43ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                  0xff98000 -  0xff99ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                  0xffd8000 -  0xffe5ff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/asneu.framework/asneu
                                  0xfff3000 -  0xfff3ff7  libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
                                  0x115d1000 - 0x115dbff7  libCSync.A.dylib ??? (???) <A05BB12D-CD51-DE43-323B-3A3E99A3EED5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                  0x117fa000 - 0x117fbff7  ATSHI.dylib ??? (???) <251A0D44-8909-BC8C-49DF-477BA8304FDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                                  0x1d07c000 - 0x1d11dfc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtservices.framework/amtservices
                                  0x1d1fb000 - 0x1d242fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                                  0x1d77f000 - 0x1d7c0ff7  libRIP.A.dylib ??? (???) <6DB158C6-A84D-98C9-1D48-868A3DB17D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                  0x1d830000 - 0x1d83efe7  libSimplifiedChineseConverter.dylib ??? (???) <4C9CC2D9-2F13-4465-5447-2516FCD9255B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                  0x1d842000 - 0x1d854ff7  libTraditionalChineseConverter.dylib ??? (???) <C4E0D62B-4D1A-8DAD-D10B-2C055AA0479C> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                  0x1d858000 - 0x1d892fe7  libFontRegistry.dylib ??? (???) <EE633CF6-8827-EF05-10A4-5F2937120227> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistry.dylib
                                  0x1d8ad000 - 0x1d8b0ff7  libCGXType.A.dylib ??? (???) <3FB5E457-EABF-B33E-E01B-C695FB2D72EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                  0x1da65000 - 0x1da96ff3  libTrueTypeScaler.dylib ??? (???) <F326E053-7425-2F10-F883-CBD56A1E1B72> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libTrueTypeScaler.dylib
                                  0x1dac3000 - 0x1df45fe3 +AdobeLM_libFNP.dylib ??? (???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/AdobeLM_libFNP.dylib
                                  0x1e28e000 - 0x1e2b7fef  com.apple.audio.CoreAudioKit 1.6 (1.6) <E9D5679D-0F3A-EE19-76F9-559F42E5DF8C> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                                  0x1e2c8000 - 0x1e96bfeb +com.macromedia.Flash Player.authplaylib 10.0.2.54 (1.0.1d333) <E06A7C9F-F663-4958-B8E1-D5EACF07F0E3> /Applications/Adobe Flash CS4/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
                                  0x1f02f000 - 0x1f04bfd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/LogTransport.framework/LogTransport
                                  0x1f4ad000 - 0x1f4affff +com.macromedia.Flash.FLfile 10.0.0.544 (10.0.0) <A983B337-B19A-4DC7-B46A-2AE8F683B3B8> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
                                  0x1f4cd000 - 0x1f50bfd4 +com.adobe.emlaunch 1.1 (1.0) /Library/Application Support/Adobe/EMLaunch.bundle/Contents/MacOS/EMLaunch
                                  0x1f556000 - 0x1f559fcf +libwchar.dylib ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/libwchar.dylib
                                  0x1f6a2000 - 0x1f6a2fff +com.macromedia.Flash.flastoragelib 9.0 (9.0) <4A09437D-BEFE-48C6-A7B5-5C094044AA9E> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
                                  0x1f7cb000 - 0x1f7eeff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
                                  0x1f7fd000 - 0x1f818ff7  com.apple.OpenTransport 10.6.0 (10.6.0) <ECA6FEC6-5ECD-51BA-162F-CFC43899196A> /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
                                  0x1f829000 - 0x1f84102f +com.macromedia.Flash.FLAir 10.0.0 (10.0.0 d544) <33151461-3D89-4331-936C-4737D11C97F1> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLAir1_1.bundle/Contents/MacOS/FLAir1_1
                                  0x1f8bd000 - 0x1f8d2ff7 +com.yourcompany.PointGrid ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
                                  0x20000000 - 0x20098fe7  edu.mit.Kerberos 6.5.8 (6.5.8) <BA9BD282-FF56-3BFD-E78C-7DBE73B48480> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                  0x20fb9000 - 0x21194ff3  libType1Scaler.dylib ??? (???) <BD3674DE-EAD9-C57A-0072-3C18970DCC1C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libType1Scaler.dylib
                                  0x21373000 - 0x213b7fe3 +com.adobe.flash.flbridge 10.0.0.544 (10.0.0) <E556D6D9-DA9B-435F-93D5-D10A357EC120> /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
                                  0x21661000 - 0x216bdff2 +com.adobe.ESD.AdobeUpdaterLibFramework AdobeUpdater 6.0.0.1452 (6.0.0.1452) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeUpdater.framework/AdobeUpdater
                                  0x21800000 - 0x21863feb +com.yourcompany.Brush ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
                                  0x22f00000 - 0x22f7cff7 +com.yourcompany.Collision ??? (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
                                  0x23800000 - 0x238cffcb  com.apple.carbonbundletemplate 1.0 (1.0) /Applications/Adobe Flash CS4/Common/Configuration/External Libraries/FlashIK.bundle/Contents/MacOS/FlashIK
                                  0x23e00000 - 0x24012fff  com.apple.RawCamera.bundle 2.2.1 (477) <10937A0D-0856-1B69-AE27-43BC15B7DD21> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                  0x245f5000 - 0x246c6ff3  ColorSyncDeprecated.dylib ??? (???) <AFD6DAC8-12EF-B2A0-5322-E902D5B48B0A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                                  0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                                  0x64b00000 - 0x64b07fff  com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                  0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
                                  0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate 1.3 (1.3.12) /Applications/Adobe Flash CS4/Adobe Flash CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                  0xba300000 - 0xba301fe7  libCyrillicConverter.dylib ??? (???) <7CF64AB7-ABFE-6F8F-8F50-C7460A5B3A92> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                                  0xba500000 - 0xba501ff7  libGreekConverter.dylib ??? (???) <1AB8227F-468F-B285-B4B4-14B7D202ED36> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
                                  0xba900000 - 0xba916ff7  libJapaneseConverter.dylib ??? (???) <4FB5CEEB-8D3E-8C57-1718-81D7CAFBFE69> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                  0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib ??? (???) <A23F9980-5CC8-A44D-6FD6-DBFCBFF4FF28> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                  0xbb500000 - 0xbb500ff7  libThaiConverter.dylib ??? (???) <5B51E9C4-40C4-26B7-5CA2-CD27D78CFA27> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
                                  0xfa100000 - 0xfa191fe3  com.apple.print.framework.PrintCore 6.0 (312) <C588530A-0F2C-DD72-E308-3B8735125189> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                  0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <E58B649F-FFDC-AB09-2028-8B706BEF7C0F> /usr/lib/libSystem.B.dylib
                                  Model: MacBookPro3,1, BootROM MBP31.0070.B07, 2 processors, Intel Core 2 Duo, 2.2 GHz, 4 GB, SMC 1.16f11
                                  Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 128 MB
                                  Memory Module: global_name
                                  AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.0.19.4
                                  Bluetooth: Version 2.2.1f7, 2 service, 1 devices, 1 incoming serial ports
                                  Network Service: Ethernet, Ethernet, en0
                                  Network Service: Parallels Shared Networking Adapter, Ethernet, en4
                                  Network Service: Parallels Host-Only Networking Adapter, Ethernet, en5
                                  PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5
                                  Serial ATA Device: FUJITSU MHY2120BH, 111,79 GB
                                  Parallel ATA Device: HL-DT-ST DVDRW  GSA-S10N
                                  USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd400000
                                  USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x021b, 0x5d200000
                                  USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000
                                  USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8205, 0x1a100000
                                  • 14. Re: Snowleopard & Flash CS4 (Crash)
                                    daniel.cantor
                                    Well, i used to had the same problem, i moved all the fonts folder in macintoshd/library/fonts to another place, and then i restarted, and it works, in my case the font with error was accyr_souvenyr.ttf, so you have to check moving all the fonts, not only the franklingothic, because maybe in your case the font with errors could be another one.  Now i erase that font, and everything works like a charm.
                                    PD: my english is not the best, but maybe you could understand what i said.
                                    • 15. Re: Snowleopard & Flash CS4 (Crash)
                                      Matt@Innove
                                      We found and tried these two solutions.
                                      They work for us and hope that helps someone else.
                                      At the beginning was frustrating that we couldn't work with the brand new CS4 on my mac.
                                      Back then I work again.
                                      Here is the link:http://life.innove.it/?p=217
                                      Bye, Matt
                                      • 16. Re: Snowleopard & Flash CS4 (Crash)
                                        foriaa82 Level 1
                                        thanks to botth for your help.
                                        I tried matt's solution but It doesn't work still.
                                        now I'll try with the other one but I have one questions:
                                        but after the moving I have to reinstall one by one? or I can move again the font folder in the original folder after the execution of flash?
                                        thanks a lot
                                        • 17. Re: Snowleopard & Flash CS4 (Crash)
                                          realurbancowboy
                                          May the good Lord bless you for figuring out that it's Franklin Gothic Regular. From here to eternity, I will never use this font. Over a month of scratching head. Shame on Adobe for not recognizing & fixing this.
                                          • 18. Re: Snowleopard & Flash CS4 (Crash)
                                            OddB Level 1
                                            Un-mother-f-ing believable this is even an issue.  One font.  One f-ing font.
                                            kevinis THANK YOU! You are a damned genius.
                                            Adobe. What the f---? This BS cost me $400 worth of my time and the joy of explaining to my client that I couldn't change a file I built only last week.  Thanks Adobe. Thanks a bunch.
                                            • 19. Re: Snowleopard & Flash CS4 (Crash)
                                              RKeldorff
                                              Just had the same problem and I resolved it, not only by turning off Franklin Gothic, but every font I had in my system which showed the yellow warning sign. I had not been aware of this before. That did it.
                                              • 20. Re: Snowleopard & Flash CS4 (Crash)
                                                djkencloud Level 1
                                                The problem happened for me when I installed the java 10.6 update...
                                                I verified all my fonts and then I used solution A provided here... http://life.innove.it/?p=217
                                                It seems to have fixed my problem.
                                                K.
