7 Replies Latest reply on Sep 2, 2009 2:41 PM by ilssac
    CFHTTP/PayPal SetExpressCheckout Api
    ACS LLC Level 1
      I am slowly but surely getting to grips with PayPal integration. I am trying to connect to their SetExpressCheckout API
      I have a CFHTTP set up as a GET (also tried post)
      It manages to authenticate me, but as soon as I give the CFHTTP a NAME="test_paypal" for example along with DELIMITER="&", it gives me a problem.
      It says that the first variable returned which is TOKEN is an invalid name, it looks like this is a reserved name in CF?
      I see this and a few other variables that I need using CFHTTP.FILECONTENT
      Is there another way to correctly read all the variables returned without running into this issue?
      Btw Any developers out there interested in working on this for me please let me know, I'll be on this for a lifetime at this rate!
      Mark
        • 1. Re: CFHTTP/PayPal SetExpressCheckout Api
          ilssac Level 5
          What does the code look the that is throwing the error?
          If it is, as I suspect, when you try to reference the variable and you are using 'dot' notation.  This can almost always be resovled by using 'array' notation.
          I.E. if you are using something like payPal.token and it is throwing an error, you can get to the same data with payPal["token"].
          • 2. Re: CFHTTP/PayPal SetExpressCheckout Api
            ACS LLC Level 1
            Hi Ian,
            Here is the code, and the server response that I get. If I try to use NAME= , it just goes into invalid variable for TOKEN
            <CFHTTP URL="#serverURL#" METHOD="post" THROWONERROR="YES" delimiter="&" >
            <CFHTTPPARAM NAME="METHOD" VALUE="SetExpressCheckout" TYPE="FormField"
            ENCODED="YES">
            <CFHTTPPARAM NAME="USER" VALUE="#APIUserName#" TYPE="FormField" ENCODED="YES">
            <CFHTTPPARAM NAME="PWD" VALUE="#APIPassword#" TYPE="FormField" ENCODED="YES">
            <CFHTTPPARAM NAME="SIGNATURE" VALUE="#APISignature#" TYPE="FormField"
            ENCODED="YES">
            <CFHTTPPARAM NAME="VERSION" VALUE="#version#" TYPE="FormField" ENCODED="YES">
            <CFHTTPPARAM NAME="AMT" VALUE="1.00" TYPE="FormField" ENCODED="YES">
            <CFHTTPPARAM NAME="RETURNURL" VALUE="http://www.xxxxxxxxxxx.com/buy.cfm"
            <CFHTTPPARAM NAME="CANCELURL" VALUE="http://www.xxxxxxxxxxxxxx.com"
            </CFHTTP>
            <CFOUTPUT>
            #cfhttp.fileContent#
            </CFOUTPUT>
            server gives
            TOKEN=EC%2d5HNxxxxxxxxxxxxxT&TIMESTAMP=2009%2d09%2d02T20%3a50%3a33Z&CORRELATIONID=52f09a09 72424&ACK=Success&VERSION=59%2e0&BUILD=000000
            Now if I add the NAME, I get
            The web site you are  accessing has experienced an unexpected error.
            Please contact the website  administrator.
            The following information is meant for the website developer for  debugging purposes.
            Error Occurred While Processing Request
            The column  name TOKEN=EC%2d5T01xxxxxxxxxx42G is invalid.
            Column names must be valid variable  names. They must start with a letter and can only include letters, numbers, and  underscores.
            The  error occurred in D:\ACS\paypal\index.cfm: line 27
            25 : <CFHTTPPARAM NAME="RETURNURL" VALUE="http://www.xxxxxxxxxxx.com/buy.cfm" TYPE="FormField" ENCODED="YES">
            26 :
            27 : <CFHTTPPARAM NAME="CANCELURL" VALUE="http://www.xxxxxxxxxxx.com" TYPE="FormField" ENCODED="YES">
            28 :
            29 :
            • 3. Re: CFHTTP/PayPal SetExpressCheckout Api
              ilssac Level 5
              What do you mean by "Add Name"
              Where are you adding a Name property and how are you trying to use it?
              • 4. Re: CFHTTP/PayPal SetExpressCheckout Api
                ACS LLC Level 1
                I add a name to the CFHTTP so that I can treat it as a query, but that looks like the wrong approach for sure, that's when it throws the error
                There is a CFC with the paypal example codes, but I can't run CFOBJECT on godaddy so that would be a problem, besides, can't get it to work right anyway (on local system)
                • 5. Re: CFHTTP/PayPal SetExpressCheckout Api
                  ilssac Level 5
                  I see and it looks like CF does not want to build a query record set with "result" as a column name.
                  I admit I have never ran into that, but it is possible.
                  It should not be to hard to manually parse that data into a record set or some other data construciton with a loop.
                  <cfset payPalStruct = structNew()>
                  <cfloop list="#cfhttp.fileContent#" index="elem" delimiter="&">
                  <cfset payPalStruct[listFirst(elem,"=")] = listLast(elem,"=")>
                  </cfloop>
                  <cfdump var="#payPalStruct#">
                  • 6. Re: CFHTTP/PayPal SetExpressCheckout Api
                    ACS LLC Level 1
                    great, it works
                    Below are the results (btw I had to change delimiter to delimiterS, plural.
                    I used #paypalstruct.token# and it did the trick.
                    that's great, I've been killing myself for way too many hours over this.
                    (Out of interest do you do sub work incase I need further assistance on this or other CF projects that I am involved in)
                    struct
                    ACKSuccess
                    BUILD000000
                    CORRELATIONID6b80xxxxxxxx3be
                    TIMESTAMP2009%2d09%2d02T21%3a29%3a30Z
                    TOKENEC%2d1Rxxxxxxxxxxxxx7001B
                    VERSION59%2e0
                    • 7. Re: CFHTTP/PayPal SetExpressCheckout Api
                      ilssac Level 5
                      great, it works
                      Glad to hear it.
                      Yes, it is always prudent to double check syntax.
                      Occasionally, but I am not available for much for the next few weeks.
                      http://www.ilsweb.com
