0 Replies Latest reply on Sep 2, 2009 1:52 PM by Paul Reilly
    [svn:fx-trunk] 9936: * Defer CSS Embed(), ClassReference(), and PropertyReference()
    Paul Reilly Level 1
      Revision: 9936
      Author:   preilly@adobe.com
      Date:     2009-09-02 13:52:24 -0700 (Wed, 02 Sep 2009)
      Log Message:
      • Defer CSS Embed(), ClassReference(), and PropertyReference()
        handling until code generation time, so that we only process styles
        after overrides have been applied.
      QE notes: existing tests should pass
      Doc notes: N/A
      Bugs: SDK-22659
      Reviewer: Corey
      Tests run: "mxunit atembed"
      Is noteworthy for integration: Yes, needed for the MX-only feature
      Code-level description of changes:
        flex2/tools/PreLink.java
          Modified backgroundColor and styleName handling by wrapping it
          with a check for a value of type String.
        flex2/compiler/css/StyleModule.java
          Modified getAtEmbeds() to return the atEmbeds from each StyleDef.
        flex2/compiler/css/StyleDef.java
          Removed atEmbeds and imports.
          Modified getAtEmbeds() and getImports() to collect the result from
          the StyleProperties dynamically.
          Removed addAtEmbed() and processEmbed().
          Modified processPropertyValue() to return an Object instead of a
          String.
        flex2/compiler/mxml/rep/AtEmbed.java
          Added equals(), hashCode(), and toString().
        flex2/compiler/mxml/rep/MxmlDocument.java
          Modified getAtEmbeds() to add the atEmbeds from the
          StylesContainer dynamically to the result.
        flash/css/StyleProperty.java
          Changed value from a String to an Object, so we can support
          String, AtEmbed, and Reference.
        flex2/compiler/css/Reference.java
          Initial checkin.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22659
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleProperty.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Reference.java
