0 Replies Latest reply on Sep 2, 2009 7:45 PM by rfrishbe
    [svn:fx-trunk] 9948: Spark Primitive Text Changes.
    rfrishbe Level 3
      Revision: 9948
      Author:   rfrishbe@adobe.com
      Date:     2009-09-02 19:44:59 -0700 (Wed, 02 Sep 2009)
      Log Message:
      Spark Primitive Text Changes.  See http://opensource.adobe.com/wiki/display/flexsdk/SparkTextPrimitives+Decision for the full information and reasoning for the decision.  The main changes are:
      • Replace SimpleText with Label, a UIComponent version of the same component
      • Instead of extending GraphicElement, RichText will extend UIComponent (like Label will)
      • All of the spark text components will move to spark.components.*, so there will be spark.components.Label, spark.components.RichText, and spark.components.RichEditableText
      • The base class for SimpleText and RichText, spark.primitives.supportClasses.TextGraphicElement, will now extend UIComponent (instead of GraphicElement) and be moved and renamed to spark.components.supportClasses.TextBase. All of our text skin parts will now be typed as TextBase instead of TextGraphicElement
      • For now, RichEditableText and RichText will co-exist. Performance numbers showed that it may be possible to collapse them, but we don't have the time right now to do this. We will revisit this later on, time permitting.
      QE notes: Jody and Brian have been helping out coordinate this change
      Doc notes: I updated some ASDoc examples, but more work needs to be done here
      Bugs: -
      Reviewer: Gordon
      Tests run: checkintests, Jody and Brian have been running tests
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/SkinTest.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/Window.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/WindowedApplication. as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/windowClasses/TitleB ar.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowed ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/WindowedApplication Skin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacTit leBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/TitleB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/ButtonBarE xample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/CheckBoxEx ample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/DataGroupV irtualizationExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/DropDownLi stExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/GroupExamp le.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/HSliderExa mple.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/ListExampl e.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/NumericSte pperExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/PanelExamp le.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/ToggleButt onExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/VSliderExa mple.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/examples/AnimateColorE ffectExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/examples/AnimateTransi tionShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/examples/CrossFadeExam ple.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/examples/WipeExample.m xml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/DescendantSele ctorExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/IDSelectorExam ple.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/PseudoSelector Example.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/TypeClassSelec torExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextArea.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextInput.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/VolumeBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ItemRenderer .as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/CSSTextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarMiddleButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultItemRenderer.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Sc rubBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarFirstButt onSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarLastButto nSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarMiddleBut tonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DefaultButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DropDownListSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/RadioButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ToggleButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerSkin.mx ml
          flex/sdk/trunk/frameworks/spark-manifest.xml
          flex/sdk/trunk/frameworks/tests/basicTests/halo/views/AccordionTests.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TabNavigatorTests.mxml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/mustella/mustella.swc
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/LabelExamp le.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/RichEditab leTextExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/RichTextEx ample.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Label.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Label.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichText.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/RichEditable TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/RichEditable TextEditManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/RichEditab leTextExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/RichTextEx ample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/SimpleText Example.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichEditableText.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichText.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/SimpleText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/SimpleText.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/RichEditable TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/RichEditable TextEditManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/TextGraphicE lement.as
