6 Replies Latest reply on Sep 3, 2009 5:11 AM by David_F57
    Why is my hslider invisible
    ron71nl
      Hi all,
      I'm trying to instantiate a HSlider programmatically and place it on the stage.
      Whatever I do, it remains invisible... I'm just wondering if I miss a skin library or something.
      If I replace the HSlider with the old fl.controls.Slider, it all works fine (But I want the HSlider because I want tick labels).
      var _slider:HSlider = new HSlider();
      _slider.x = 10;
      _slider.y = 10;
      _slider.width = 200;
      _slider.height = 30;
      _slider.value = 0;
      _slider.snapInterval = 0.01;
      _slider.minimum = 0;
      _slider.maximum = 10;
      _slider.tickInterval = 1;
      _slider.allowTrackClick = true;
      _slider.visible = true;
      stage.addChild(_slider)
      See the attachment for the libs/swc's I've incorporated in my project.
      Anyone any clues?
      Ronaldo
      PS: It's really hard to find out what libs/swc's you need when there's a class that cannot be found. Is there any overview of the swc's content or a library finder utility for a specific class? Now it's just trial and error.
        • 1. Re: Why is my hslider invisible
          David_F57 Level 5
          use this.addElement instead of stage.addchild, this should fix your problem.
          David
          • 2. Re: Why is my hslider invisible
            ron71nl Level 1
            Hmm. Thanks for the reply.
            I'm adding the HSlider to a Sprite, and the Sprite doesn't have the addElement method...
            Seems like I also use an older version of the flash.display.Sprite...
            Even though I can see the flash.display.Sprite is in the /Applications/Adobe Flash Builder Beta/sdks/4.0.0/frameworks/libs/player/10/playerglobal.swc lib.
            Ronaldo
            • 3. Re: Why is my hslider invisible
              David_F57 Level 5
              try placing a group into the sprite and then add the slider to the group, you need to load the slider as a visualelement.
              David
              [edit] also make sure your sprite is being displayed with both a width and height, do you need a sprite ?
              • 4. Re: Why is my hslider invisible
                ron71nl Level 1
                Ok, I used a Group and used the addElement method to add the HSlider,
                but it seems like I need to investigate http://livedocs.adobe.com/flex/gumbo/html/WS2db454920e96a9e51e63e3d11c0bf69084-7f8c.html,
                as I have no syles according to the following error:
                Error: No class registered for interface 'mx.styles::IStyleManager2'.
                at mx.core::Singleton$/getInstance()[E:\dev\beta1\frameworks\projects\framework\src\mx\core\ Singleton.as:111]
                at mx.styles::StyleManager$/get impl()[E:\dev\beta1\frameworks\projects\framework\src\mx\styles\StyleManager.as:92]
                at mx.styles::StyleManager$/get b....
                Thank you so far for replying.
                • 5. Re: Why is my hslider invisible
                  David_F57 Level 5
                  Without more info on what you are trying to do (i.e. are you creating the sprite as well, are you using a separate class..) i am not sure what your problem is, the following code programatically adds a group and a slider to the application (no sprite)without a problem.
                                 xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="1024" minHeight="768"
                                 creationComplete="application1_creationCompleteHandler(event)">
                  <fx:Script>
                  <![CDATA[
                    import mx.events.FlexEvent;
                    import spark.components.HSlider;
                    import spark.components.Group;
                    private var myGroup :Group = new Group();
                    private var mySlider:HSlider = new HSlider();
                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                     myGroup.width=300;
                     myGroup.height=400;
                     myGroup.x=0;
                     myGroup.y=0;
                     this.addElement(myGroup);
                     mySlider.width=300;
                     mySlider.height=25;
                     myGroup.addElement(mySlider);
                  </fx:Script>
                  </s:Application>
                  [Edit] i just realised you are not using the spark hslider but the mx one, i will look at the problem again.
                  • 6. Re: Why is my hslider invisible
                    David_F57 Level 5
                    xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="1024" minHeight="768" creationComplete="application1_creationCompleteHandler(event)">
                    <fx:Script>
                    <![CDATA[
                    import mx.controls.HSlider;
                    private var aSlide:mx.controls.HSlider= new mx.controls.HSlider(); <----- mx hslider that supports ticks
                    myGroup.width=300;
                    myGroup.height=400;
                    myGroup.x=0;
                    myGroup.y=0;
                    aSlide.width=300;
                    aSlide.height=25;
                    aSlide.tickInterval=5;
                    myGroup.addElement(aSlide);
                    </fx:Script>
                    </s:Application>
