6 Replies Latest reply on Feb 3, 2010 8:06 AM by Scott Brodersen
    Issue with Custom Render to PDF
    $Nith$ Level 4
      Jasmin or Anyone,
      I have customized the Default Render to PDF. The addition is i need to attach a document while rendering.
      The modified process is attached. When i try to render, i am getting an error. Error log also attached.
      It would be great if anyone can help me to solve this issue.
      Nith
        • 1. Re: Issue with Custom Render to PDF
          Jasmin Charbonneau Level 4
          When I looked at the Attachments property of the render step it says the following:
          "Files to add to the rendered form as attachments. Type: a map of document values.".
          Try to put your attachment in a map of documents as oppose to a list of documents.
          Jasmin
          • 2. Re: Issue with Custom Render to PDF
            $Nith$ Level 4
            thanks jasmin,
            I will try that.
            Nith
            • 3. Re: Issue with Custom Render to PDF
              $Nith$ Level 4
              There were few problems with the data import. After correcting that, it works.
              Nith
              • 4. Re: Issue with Custom Render to PDF
                Balaji Gurumurthy
                This is regarding RenderPDFForm in LC ES2:
                The start point of the ES2 workflow has List variable as the option for attachments. but in RenderPDFForm service a Map variable should be used so that it throws the following error:
                wsdescription="null" wscreatorid="A940AA22-6659-B046-1503-7B34BCBF8441" wsupdatedate="Wed Feb 03 14:07:37 GMT+05:30 2010" wsfilename="Adobe_LiveCycle_Workbench_ES2_InstallLog.log" wspermission="3"/></document>] of type: java.util.ArrayList to type: interface java.util.List
                at com.adobe.idp.dsc.util.CoercionUtil.toMap(CoercionUtil.java:1229)
                at com.adobe.idp.dsc.util.CoercionUtil.toType(CoercionUtil.java:1009)
                at com.adobe.workflow.datatype.CoercionUtil.toType(CoercionUtil.java:168)
                at com.adobe.workflow.engine.PEUtil.processMapping(PEUtil.java:1095)
                at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:798)
                at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:510 )
                at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:888)
                at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2797)
                at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncContinueBranchCommand(ProcessEngineBM TBean.java:2551)
                at sun.reflect.GeneratedMethodAccessor1519.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                at java.lang.reflect.Method.invoke(Method.java:597)
                at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
                at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
                at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
                at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
                at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
                at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
                at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
                at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
                at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
                at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
                at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
                at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
                at org.jboss.ejb.Container.invoke(Container.java:960)
                at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
                at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
                at $Proxy218.asyncContinueBranchCommand(Unknown Source)
                at com.adobe.idp.workflow.dsc.service.ProcessCommandExecutorService.continueBranch(ProcessCo mmandExecutorService.java:39)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
                at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:154)
                at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
                at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                It tells cannot convert to List to Map...
                Can anyone help me ..?
                thanx
                Balaji
                • 5. Re: Issue with Custom Render to PDF
                  You'll need to convert the list into a map.
                  You can build a loop in the process to do that or leverage the ExecuteScript service and do it through code.
                  Jasmin
