3 Replies Latest reply on Sep 18, 2009 8:16 AM by RosieGp
    Flex - autoSize
    RosieGp Level 1
      I have textArea component that resizes from default size as the user keep on adding text in it.
      But as the textArea grows i'm unable to see anything after that textArea. How can I push whatever is after the text Area down as TextArea grows...
      <mx:Canvas
      xmlns:mx=http://www.adobe.com/2006/mxml width="656" backgroundColor="0xFFFFFF">
      <mx:Script>
      <![CDATA[
      import mx.events.FlexEvent;
      public function update():
      void
      if
      (txt.textHeight<30){
      else
      txt.explicitHeight = txt.textHeight + 10;
      </mx:Script>
      <mx:TextArea id="txt" x="33.5" y="130" width="598.5" height="42" text="Description" change="update()"
      <mx:Button x="33.5" y="145" label="Add New Report" fontWeight="bold" width="105"
      <mx:Label x="33.5" y="155" text="GM-Chevy"
      <mx:Label x="33.5" y="165" text="GM-Saturn" fontWeight="bold"
      <mx:Label x="33.5" y="110" text="GM - Cars in Stock" fontWeight="bold"
      <mx:Button x="218" y="300" label="Submit"
      <mx:Button x="347" y="300" label="Clear"
        • 1. Re: Flex - autoSize
          Andrew Rosewarn Level 3
          I guess the most simplistic way to hande this is to put your text area in a VBOX with the other controls in a continer inside the VBOX.  That way as your textArea grows the Vbox will automatically layout the children and push the others down.
          Andrew
          • 2. Re: Flex - autoSize
            Example for you
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                <mx:Script>
                    <![CDATA[
                        private function handleChange():void {
                            ta.height = ta.textHeight + 10;
                </mx:Script>
                <mx:VBox x="41" y="49" height="228" width="263">
                    <mx:TextArea id="ta" width="100%" change="handleChange()"/>
                    <mx:HBox width="100%">
                        <mx:Button label="Button"/>
                    </mx:HBox>
                </mx:VBox>
            </mx:Application>
            Hope that helps
            Andrew
            • 3. Re: Flex - autoSize
              RosieGp Level 1
              Hi Andrew,
              I used VBox and it does work. The inside container that i'm using is HBox. But the problem is no matter where I want to copy a new button it always paste horizontally. Is there any other container that I can use... Like a canvas, Form or panel inside a Vbox. here is what I have
                  <mx:Script>
                      <![CDATA[
                  </mx:Script>
                          <mx:Label text="Happy Birthday " width="115"/>
                          <mx:Label text="Click Me" fontWeight="bold" width="46"/>
                          <mx:TextArea id="txtClickMe" height="21" change="updateClickMe()" width="160"/>
                      </mx:HBox>
                  </mx:VBox>
              </mx:Application>
