0 Replies Latest reply on Sep 3, 2009 12:58 PM by rfrishbe
    [svn:fx-trunk] 10000: Fixing up RichText for use in the FXG compiler case.
    rfrishbe Level 3
      Revision: 10000
      Author:   rfrishbe@adobe.com
      Date:     2009-09-03 12:58:06 -0700 (Thu, 03 Sep 2009)
      Log Message:
      Fixing up RichText for use in the FXG compiler case.  This was a fallout from yesterday's checkin moving around spark text components and re-base-classing them.  UIComponents need a parent and a nestLevel for validateXXX() calls to work where as graphic element's don't.
      QE notes:-
      Doc notes:-
      Bugs: SDK-22981
      Reviewer: Glenn, Corey
      Tests run: checkintests, test case with bug
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22981
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
