4 Replies Latest reply on Sep 4, 2009 6:43 AM by Rueberm
    AE error in Premiere
    Rueberm Level 1
      I am using After Effects to create animated keys for a Premier Project.  Each AE project contains multiple comps with keys in it.  When I import the files into Premier the frames in the keys jump between the comps... Example- a key that says John Doe will appear correctly for a frame and then the next frame it will flip to Tom Doe and then after a few frames it will flip back to John Doe.  Any ideas? I am in no rush for an answer... obviously there are workarounds. This is happening on 4 different systems.  2 xp, 1 xp 64,  1 windows 7C.  I am using CS4.  Standard DV settings.  Doesn't happen if AE is open and I refresh the comps.
      Only respond to this thread if you:
      -have the same problem
      -have a fix for the problem
      -or need additional information (please be specific)
