0 Replies Latest reply on Sep 3, 2009 1:17 PM by Jason Szeto
    [svn:fx-trunk] 10002: Gradient matrix transform fix
    Jason Szeto Level 3
      Revision: 10002
      Author:   jszeto@adobe.com
      Date:     2009-09-03 13:17:09 -0700 (Thu, 03 Sep 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22928 - Gradient matrix transform applying incorrect transforms
      Previously, the logic transformed the gradient to fill the shape bounds and then combined the matrix transform. Now using the same values for the discreet transform properties versus the matrix properties should result in the same appearance.
      These changes are applied to LinearGradient, RadialGradient, LinearGradientStroke and RadialGradientStroke.
      QE notes: Matrix transform behavior has changed
      Doc notes: Need info on matrix behavior
      Bugs: SDK-22928
      Reviewer: Glenn
      Tests run: spark/primitives
      Is noteworthy for integration: Yes
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradientStroke.as
