0 Replies Latest reply on Sep 3, 2009 3:04 PM by Glenn Ruehle
    [svn:fx-trunk] 10006: Initial checkin of the "More styles for Spark skins" feature.
    Glenn Ruehle Adobe Employee
      Revision: 10006
      Author:   gruehle@adobe.com
      Date:     2009-09-03 15:04:47 -0700 (Thu, 03 Sep 2009)
      Log Message:
      Initial checkin of the "More styles for Spark skins" feature. Details here:
      http://opensource.adobe.com/wiki/display/flexsdk/MoreStylesforSparkSkins
      There are some known issues:
      • Panel bottom corners not rounded correctly when the panel has a control bar
      • cornerRadius on Tab and DateChooser non functional
      • cornerRadius values > 4 have drawing artifacts in the "down" state of Button and button-like components
      • TextInput/TextArea incorrectly list lineBreak and verticalAlign as valid styles
      This checkin also includes a couple minor unrelated bug fixes:
      • Remove MiniDebugTarget. This is a logging target that used MiniDebug, which hasn't worked since Flex 1.5
      • Fix RTEs when setting focusSkin to null
      • Optimization: don't measure skins if the host component has explicit sizes
      QE notes: Yes, many baseline images will need to be regenerated
      Doc notes: New ASDoc comments should be scrubbed
      Bugs: SDK-22931, SDK-22798, SDK-22217, SDK-19358
      Reviewer: Jason
      Tests run: checkintests, cyclone
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22931
          http://bugs.adobe.com/jira/browse/SDK-22798
          http://bugs.adobe.com/jira/browse/SDK-22217
          http://bugs.adobe.com/jira/browse/SDK-19358
      Modified Paths:
          flex/sdk/trunk/frameworks/halo-manifest.xml
          flex/sdk/trunk/frameworks/mxml-manifest.xml
          flex/sdk/trunk/frameworks/projects/airframework/defaults.css
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/Window.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/WindowedApplication. as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowed ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/WindowedApplication Skin.mxml
          flex/sdk/trunk/frameworks/projects/framework/defaults.css
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NumericStepper.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IDeferredContentOwner.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatorContent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ScrollControlBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/BorderStyles.as
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Application.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/NumericStepper.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Spinner.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Skin.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RectangularDropShadow.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/SparkSkin.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FocusSkin.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperTextInputSki n.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerDecrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerIncrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/BorderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarFirstButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarLastButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/EditableComboBoxSkin.mxm l
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PanelBorderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PopUpButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SparkSkinForHalo.as
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperDecrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperIncrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TextInputBorderSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ApplicationSkin.mx ml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.css
          flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/BorderTestScript.mxml
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/logging/targets/MiniDebugTarget.as
