1 Reply Latest reply on Sep 3, 2009 8:55 PM by babo_ya
    unable to set effects in loaded application
    ZenForHire
      Hi All,
      I'm ABLE to get UIComponents from loaded app and set their properties. It's loaded as a child in same domain.
      I'm UNABLE to set any effects like Rotate or Glow on the same UIComponent.
      I have mxml definitions of the effect i need in the parent app.
      Have tried several ways to try to get it to work.
      glowPulse.target = [eventTarget];
      glowPulse.play
      // TypeError: Error #1006: dispatchEvent is not a function
      eventTarget.setStyle("showEffect", rotate );
      // no effect
      Is it possible or are you stuck with just setting simple properties and using functions defined in sub app like a  remote object service call?
      Thanks in advance,
      Kevin
        • 1. Re: unable to set effects in loaded application
          babo_ya Level 3
          I don't quiet understand your question .. but, try this..
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute>
              <mx:Script>
                  <![CDATA[
                  import mx.controls.Button;
                  import src.SharingComp;
                      import mx.controls.Alert;
                     import mx.managers.PopUpManager;
                     private function createPopUp(event:MouseEvent):void {
                          var button:Button = Button(event.currentTarget);
                          button.setStyle("showEffect", "Fade");
                          button.visible = false;
                          button.visible = true;
              </mx:Script>
              <mx:Button x="31" y="56" label="Button" click="createPopUp(event)"/>
          </mx:Application>
          Hope this helps,
          BaBo,
