0 Replies Latest reply on Sep 3, 2009 3:35 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 10007: Checking in on behalf of Deepa.
    Evtim Georgiev (Adobe) Level 2
      Revision: 10007
      Author:   egeorgie@adobe.com
      Date:     2009-09-03 15:35:19 -0700 (Thu, 03 Sep 2009)
      Log Message:
      Checking in on behalf of Deepa. BlendMode changes: the default blendMode is now "auto". Auto means that the blend mode of the underlying display object will be "normal" if alpha is 0 or 1, and it will be "layer" if alpha is between 0 and 1.
      Additionally the skins have been updated, removing explicit blend mode for disabled state, and specifying a blend mode "normal" for some skins.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Evtim
      Tests run: checkintests, basictests
      Is noteworthy for integration: Yes, blendMode behavior affects Catalyst
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarDownButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarUpButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperDecrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperIncrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DropDownListSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarSkin.mxm l
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericStepperSkin .mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/RadioButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ToggleButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarSkin.mxm l
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderSkin.mxml
