0 Replies Latest reply on Sep 3, 2009 4:35 PM by viatropos
    Layout Effects, infinite loop.
    viatropos Level 1
      Hey,
      I'm trying to do very simple effects in a layout (move and rotate in 3D, using AnimateTransform), and it's forcing update of the layout when the animation starts and when it completes, which I don't want.
      Here's the gist of the effect, where "targets" are all the GroupBase's children:
           effect.end();
           // capture start values from the targets
           effect.targets = targets;
           if (effect is Animate) //
                (effect as Animate).disableLayout = true;
                (effect as AnimateTransform).applyChangesPostLayout = true;
           (effect as Effect).propertyChangesArray = (effect as Effect).captureValues(null, true);
           var n:int = (effect as Effect).propertyChangesArray.length;
           for (var i:int = 0; i < n; i++)
                (effect as Effect).propertyChangesArray[i].end = properties[i]
           effect.play();
      If I set "disableLayout" to true, when the animation is complete, it sets "autoLayout" to true on the parent, which causes the layout to run again.  If I set "disableLayout" to false, then it updates the layout every time a property changes.
      How do I get around this?
      I did my own custom "capture start" "capture end" functions to avoid the LayoutManager.getInstance().validateNow() calls in the Effect.as class.
      Thanks!
      Lance
