3 Replies Latest reply on Dec 4, 2009 12:20 AM by Kumud malhotra
    QTP add-in support
    VExt0n
      This is the notes from Flex builder 3.0 release notes for Install and Configure Flex Automated Testing
      Is the Flex developer responsible for these steps?
      To use run-time automated testing (recommended):
      1. Open a command prompt.
      2. Navigate to the flex_builder_root/sdks/3.0.0/templates/automation-runtimeloading-files directory.
      3. Execute the build.bat file. This compiles the runtimeloading.mxml file into a SWF file.
      4. Copy the runtimeloading.swf and RunTimeLoading.html file to your web server. Copy the Flex application that you want to test to this server as well (the application need not be compiled with automation libraries).
      5. Request the RunTimeLoading.html file and pass your Flex application as the automationswfurl query string parameter; for example:
        http://localhost/RunTimeLoading.html?automationswfurl=MyApp.swf
      To compile your applications with static automation support:
      1. Start Flex Builder.
      2. Create a new Flex Project.
      3. Select your new Flex project in the Navigator.
      4. Select Project > Properties > Flex Compiler.
      5. In the "Additional compiler arguments" field, enter the following:
        -include-libraries "flex_builder_dir\sdks\3.0.0\frameworks\libs\automation.swc"
         "flex_builder_dir\sdks\3.0.0\frameworks\libs\automation_agent.swc"
         "flex_builder_dir\sdks\3.0.0\frameworks\libs\qtp.swc"
         "flex_builder_dir\sdks\3.0.0\frameworks\libs\automation_dmv.swc"
        The -include-libraries compiler option is relative to the Flex Builder installation directory; the default on Windows is "C:\Program Files\Adobe\Flex Builder 3\".
      6. Click the OK button to save your changes and OK to close the project Properties dialog box.
      7. Compile your Flex application.
      I installed a trial version of FlexBuilder 3.0 and I'm able to select the add-in from QTP
      From where can I download FlashPlayer Active X control
      I'm new to this and I need to automate the test pretty soon, so please help!
        • 1. Re: QTP add-in support
          paul.williams Level 4
          Testing with QTP is a pain, so don't expect to be able to do anything
          quickly. Your post lists two alternative approaches for getting going
          with QTP so you need to choose and follow one of them. In my experience
          the second approach ("static automation support") is easier to get
          working. Whichever approach you choose I would suggest starting out with
          a very basic Flex application (eg. a tab bar, a view stack, a few
          buttons ands labels) and try to get automation working with that, rather
          than attempting to dive in with whatever application you actually want
          to test. Note that if you do follow the "static automation support"
          approach you must recompile the application without the automation
          libraries to create a version suitable for release (ie. the version you
          build and use with QTP should not be released because it has lots of
          unnecessary automation junk compiled into it).
          The documentation below covers these setup steps and explains their
          differences in more detail. The "static automation support" approach is
          covered in "Compiling applications for testing":
          http://livedocs.adobe.com/flex/3/html/help.html?content=functest_components2_01.html
          The Flash Player ActiveX control is just a more specific name for the
          Flash Player for Internet Explorer. You should have that already. If you
          don't you can download it from here (get the debug version):
          http://www.adobe.com/support/flashplayer/downloads.html
          Once you've got a simple application automated with QTP (ie. you can
          record and run test scripts on the application), you can then repeat the
          same steps for your target application. You may need to make code
          changes to your target application in order to automate it fully and
          allow tests to run efficiently.
          If you are struggling with QTP (and you haven't bought it yet) then you
          may want to take a look at an alternative tool called RIATest, but post
          back any specific issues you hit and I may be able to help.
          • 2. Re: QTP add-in support
            VExt0n Level 1
            Thanks for the good tips and links. I will try my luck with a small application first, as you suggested. Thanks
            • 3. Re: QTP add-in support
              Kumud malhotra
              Hi All,
              We are currently trying to automate our test cases using QTP 10 for our hybrid application which uses java swings + Flex(New screens developed).
              We have decided to follow the runtimeloading approach for this purpose. Currently we are launching Java Applet which call a jsp which in turn calls our flex swf file.
              Now issue we are facing is that we are not able to apply runtime approach to our application. As jsp is calling application swf file.
              Can we modify this jsp somehow that it should call runtimeloading.html/runtimeloading.swf then runtimeloading.html or swf itself calls our application swf file. Which I think will be then recognized by QTP.
              I am attaching our jsp below for refrence. Application sqf is RatingShell.swf
