1 Reply Latest reply on Sep 4, 2009 7:17 AM by Jasmin Charbonneau
    possible to listen to render and print events??
    tgsoft
      Hi LC people
      Is it possible to setup events for at process for these scenarios?
      LC Forms > when form is rendered a fragment cannot be found (eg. not access to folder or network error)
      LC Output > When LC Output is printing is it possible to cast event if printer is not accessible or printer errors occur
      Hope you have some clever ideas
      /Thomas Groenbaek, Jyske Bank Denmark
        • 1. Re: possible to listen to render and print events??
          Jasmin Charbonneau Level 4
          With LC, there's two ways you can catch exceptions:
          1- Use the lightning bolt on the bottom right corner of the service.
          Pros:
          - You can catch a specific exception.
          - You can route to a specific step in the same process (from lightning bolt to where ever).
          Cons:
          - You can't get the exception object/details.
          2- Use the Exception event to get all exceptions from all the processes.
          Pros:
          - You get an exception object with exception fault, source, message.
          - You can have a generic process to catch all exceptions from all processes
          Cons:
          - Can't tell from which process it's coming from.
          Jasmin
