2 Replies Latest reply on Sep 4, 2009 2:44 PM by Andrew Rosewarn
    Using buttons as images
    Marlene
      I have 5 flex symbols that I am using as buttons in Flex. Is there a system (kinda like the button toggle) that allows me to click on one button and have the other four symbols alpha change to .5? I know how to code it but it seems extremely redundant.
      public function buttonManager():void {
           button1.alpha=.5;
          button2.alpha=.5;
          button3.alpha=.5;
          button4.alpha=.5;
          button5.alpha=.5;
           event.currentTarget.alpha=1;
      Can I put the names of the symbols in an Array and then use a for loop.               `
        • 1. Re: Using buttons as images
          Andrew Rosewarn
          Hi Marlene
          Yea you;d wanna do something like this.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
          <mx:Script>
          <![CDATA[
          import mx.controls.Button;
          private var buttons:Array;
          private function init():void {
          buttons = new Array(btn1,btn2,btn3,btn4,btn5)
          private function buttonManager(event:MouseEvent):void {
          for each (var button:Button in buttons) {
          button.alpha = .5;
          event.target.alpha = 1;
          </mx:Script>
          <mx:Button id="btn1" x="59" y="161" label="Button" click="buttonManager(event)"/>
          <mx:Button id="btn2"  x="132" y="161" label="Button" click="buttonManager(event)"/>
          <mx:Button id="btn3" x="205" y="161" label="Button" click="buttonManager(event)"/>
          <mx:Button id="btn4" x="278" y="161" label="Button" click="buttonManager(event)"/>
          <mx:Button id="btn5" x="351" y="161" label="Button" click="buttonManager(event)"/>
          </mx:Application>
          It would probably be better if you could put your buttons into a container and the when looping use the containers .getChildren() method.  That way you wouldn;t have to create and array and would work as you added more and more buttons.
          I think this would be better
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" >
          <mx:Script>
          <![CDATA[
          for each (var button:Button in hBox.getChildren()) {
          button.alpha = .5;
          </mx:Script>
          <mx:HBox x="59" y="233" width="100%" id="hBox">
          <mx:Button  label="Button" click="buttonManager(event)"/>
          </mx:HBox>
          </mx:Application>
          Andrew
          • 2. Re: Using buttons as images
            Andrew Rosewarn Level 3
            And then to finish it off you should really create a custom component with this functionallity inside it which would be much more reusable
            Andrew
