7 Replies Latest reply on Sep 7, 2009 7:32 PM by Nadia-P
    browser issues!
    mediastream13
      this site displays perfect in ie8, safari, and firefox, but won't display in ie7/6 and aol, why? thanks
        • 1. Re: browser issues!
          mediastream13 Level 1
          the site is www.bryantaafe.com/rg
          • 2. Re: browser issues!
            Nadia-P Level 5
            You don't mention what the problem is, however, viewing in IE7, I notice that menu items are not sitting inside the navbar.
            You have quite a few errors on the page that need fixing..  when you create an ID, do not use spaces in the name:
            eg::
            id="boardman rotary"
            should al be one word or separated with an underscore of hyphen
            eg:  boardman-rotary
            Validation errors here:
            http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.bryantaafe.com%2Frg%2F
            fix those errors first and then see where the page stands.
            You may need to give IE a conditional comment for the placement of the menu links..
            • 3. Re: browser issues!
              hey nadia, the problem is that the spacing is not correct in aol and ie 6/7. if you take a look at it in ie8 and firefox you'll notice the spacing and the placement of the list items. i don't know what you are referring to when you say spaces in the id's. how would i apply a conditional comment for the other browsers? =) thanks a lot for your help
              • 4. Re: browser issues!
                90% of browser problems start with malformed code.
                Start by fixing the code validation errors described below:
                FYI: Div  names cannot contain spaces.  But they can contain hyphens or underscores.
                Example:
                Wrong: #division name
                Acceptable:  #division-name or  #division_name or  #divisionName
                Nancy O.
                Alt-Web Design & Publishing
                Web | Graphics | Print | Media  Specialists
                www.alt-web.com/
                www.twitter.com/altweb
                www.alt-web.blogspot.com
                • 5. Re: browser issues!
                  ok, i think i fixed the errors, but the navigation list is still displaying incorrectly, and there is no space between the nav bar and the H2 headings. can i fix this with a .css trick? thanks
                  • 6. Re: browser issues!
                    Nadia-P Level 5
                    During testing in IE 6 an 7 the menu items are not sitting correctly.  IE8 look the same as FFox.
                    This means you need to use a conditional comment to feed a different placement style to IE6 and IE7
                    This was a very quick test, so you may need refine it a little, but copy and paste the following just before the closing <./head> tag. I tested this on the index page.  If it works, you can either copy and paste the CC on every page  or feed a special stylesheet for IE only.
                    As you can see from the line in red I changed the bottom position from -8 for the other browsers to 6px for IE6 and 7.  It worked for me using IETester.
                    See if it works for you in the 2 versions of IE.
                    <!--[if gte IE 7]>
                    <style>
                    #header ul {
                        list-style: none;
                        float: left;
                        position: absolute;
                        right: 0px;
                       bottom: 6px;
                        margin-left: 0px;
                        left: -5px;
                    </style>
                    <![endif]-->
                    • 7. Re: browser issues!
                      Nadia-P Level 5
                      This may help you as a reference point regarding Conditional Comments:
                      http://reference.sitepoint.com/css/conditionalcomments
