2 Replies Latest reply on Sep 6, 2009 4:26 PM by gkaiseril
    Change link properties (Rename file name)
    sudar1983_14 Level 2
      Hi All,
      As usual, I am new to Acrobat Scripting, but I have a good knowledge in InDesign Scripting.
      I have project about changing the link attribute.
      What i want to do is, I have a book along with chapters, Now i want to rename all the chapter names. If i rename the file name then i want to change the pdf link also. The following code will work almost, but onething i want to rectify.
      var numLinks=0;
      var desFile='D:\\1.pdf';
      var b = this.getPageBox("Crop", 0);
      var l = this.getLinks(0, b);
      l[0].setAction("app.openDoc('" + desFile + "')", this);
      If you run this code using javascript, you get a link but the property is set as javascript. Here i want to set as open a file.
      If you know the solution, please reply.
      Sudar.
