1 Reply Latest reply on Nov 6, 2009 1:31 PM by icarus313
    Flex/Net Connection and the Proper way to do things
    EMelville Level 1
      Hello, I just have a question regarding flex and FMS.
      My application uses Chat, Video, and Image Sharing. (Over a Flash Media Streaming Server)
      However, currently each of those little attributes uses a seperate "Net Connection": nc1, nc2, nc3.
      Is this the best practice or should I consolidate it all into just "One" net connection? Maybe using a class to accomplish this. Or is it a good idea to keep them seperate?
      Let me know you thoughts.
        • 1. Re: Flex/Net Connection and the Proper way to do things
          icarus313
          EMelville,
          I know it has been a number of months... but did you ever get a reasonable answer?
          I'm working thru a similar problem, and am trying to find out the best solution.
          I'm no longer using the latst FLVPlayback Component, because i needed the flexibility of the NetStream.
          Now I'm trying to conserve connections, by having a single NetConnection handle
          Playing a live/recorded stream,
          publishing a recorded stream,
          and accessing a chat room.
          thanks drew
