6 Replies Latest reply on Jul 24, 2006 5:31 AM by TzK2
    List Problem
    InclusiveCEO
      Hello all,
      I have a problem I could use some help with, I would appreciate any help you guys could give me. I would like to make a list of the 50 US states, when someone clicks on one I would like to get a 1 thru 50 value. Can you help me do this?
        • 1. Re: List Problem
          Level 7
          This will bevahior when attached to a text sprite should do what you need
          property spriteNum
          on mouseUp me
          lineClicked = sprite(spriteNum).pointToLine(the mouseLoc)
          end
          • 2. Re: List Problem
            InclusiveCEO Level 1
            Thanks for all the help Dave, I really appreciate it.
            • 3. Re: List Problem
              howik Level 1
              Quastion :Hello all,
              this?
              ANSWER :
              you should make markers for each menu you want to make(50 US states)
              then make a field on your stage and then make the Dropdown List behavior for it (Library > controls > Dropdown list ) (Drag the Dropdown List to the fild and then in the dropdown List window from Contents of list ,choose " Markers in this movie " ,click OK .
              then Rewind & Play the movie and click on the field .
              • 4. Re: List Problem
                TzK2
                I'm trying something similar with dropdown menus. Is there an easy way to define which markers appear in the list, rather than 'all markers'? In other words, I only want the user to be able to jump to certain markers.
                Many thanks,
                TzK.
                • 5. Re: List Problem
                  Level 7
                  Hi there,
                  U may try to get the return of which item u selected in the drop-menu.
                  Step 1: create a field with 50 names in it
                  Step 2: applied DropDown List behavior to it: setting as : "Current content
                  in field" & "return the selected item ..."
                  Step 3: Add 1 custom behavior to the drop-menu:
                  on mouseUp
                  set a = the item of (sendAllSprites (#DropList_Selection))
                  case (a) of
                  1: do something
                  2: do something
                  etc.
                  end case
                  end mouseUp
                  Wish this may help. Good luck.
                  Athena
                  in article e9q68g$sui$1@forums.macromedia.com, TzK2 at
                  webforumsuser@macromedia.com wrote on 7/21/06 5:20 PM:
                  > Hi,
                  > Many thanks,
                  > TzK.
                  • 6. Re: List Problem
                    TzK2 Level 1
                    Many thanks Athena, that works fine.
