7 Replies Latest reply on Sep 26, 2009 10:27 AM by Ned Murphy
    randomize mp3 player
    andib311 Level 1
      Hi
      I'm using this code I obtained from a tutorial to run an mp3 player that reads an .xml playlist. Could someone please tell me what I'd need to add/change to the code so that it plays the tracks in a random order each time the player loads - I'm not concerned about omitting repeats. I've tried adding a "random" command to the Array that holds the tracks but this didn't work.
      //Setup sound object
      var s:Sound=new Sound();
      s.onSoundComplete=playSong;
      s.setVolume(75);
      //Array of songs
      var sa:Array = new Array();
      //Currently playing song
      var cps:Number=-1;
      //Position of music
      var pos:Number;
      //Load the songs XML
      var xml:XML = new XML();
      xml.ignoreWhite = true;
      xml.onLoad = function()
      var nodes:Array = this.firstChild.childNodes;
      for(var i=0;i<nodes.length;i++)
      sa.push(new Song(nodes[i].attributes.url,nodes[i].attributes.artist,nodes[i].attributes.track));
      playSong();
      xml.load("/playlist.xml");
      //Play the MP3 File
      function playSong():Void
      s=new Sound();
      if(cps==sa.length-1)
      {cps=0;
      s.loadSound(sa[cps].earl,true);
      else
      s.loadSound(sa[++cps].earl, true);
      trackInfo.text=sa[cps].artist+' - '+sa[cps].track;
      playPause.gotoAndStop('pause');
      //Pause the music
      function pauseIt():Void
      pos=s.position;
      s.stop();
      //Unpause the music
      function unPauseIt():Void
      s.start(pos/1000);
      //Music Controls
      //PlayPause toggle
      playPause.onRollOver=function()
      if(this._currentframe==1)this.gotoAndStop('pauseOver');
      else this.gotoAndStop('playOver');
      playPause.onRollOut=playPause.onReleaseOutside=function()
      if(this._currentframe==10)this.gotoAndStop('pause');
      else this.gotoAndStop('play');
      playPause.onRelease=function()
        this._parent.pauseIt();
      else
        this._parent.unPauseIt();
      //Next Button
      next.onRollOver=function()
      this.gotoAndStop('nextOver');
      next.onRollOut=next.onReleaseOutside=function()
      this.gotoAndStop('next');
      next.onRelease=function()
      this._parent.playSong();
        • 1. Re: randomize mp3 player
          What you can do is shuffle the array once it has been assembled.  Hve a call to a separate shuffling function just after you push all the elements onto the array...
          // your line....
          sa.push(new Song(nodes[i].attributes.url,nodes[i].attributes.artist,nodes[i].attributes.tra ck));
          // shuffle the array
          sa = shuffle(sa);
          // and the function....
          function shuffle(a) {
          var len = a.length-1;
          for (i=len; i>=0; i--) {
                 var p = Math.floor(Math.random()*(i+1));
                 var t = a[i];
                 a[i] = a[p];
                 a[p] = t;
          return a;
          • 2. Re: randomize mp3 player
            andib311 Level 1
            Ok, here is what I've added in bold (section shows the //Array to //Play mp3 portion of the whole code)
            //Array of songs
            var cps:Number=-1;
            //Position of music
            var pos:Number;
            sa = shuffle(sa);
            playSong();
                   var t = a[i];
                   a[i] = a[p];
                   a[p] = t;
            return a;
            //Play the MP3 File
            s=new Sound();
            {cps=0;
            else
            These additions seem to have made no effect - the player continues to play the tracks in the order as they appear in the xml file. I've tried altering the lines
            sa = shuffle(sa);
            to
            sa = shuffle(a);
            as if I'm understanding it correctly, the function is defined as function shuffle(a) but this also does not work. Have I missed something? I appreciate your help
            • 3. Re: randomize mp3 player
              The call to the shuffle function should be outside the loop...  What you should do is place a trace before and after the call to the shuffle function...
              trace(sa);
              sa = shuffle(sa);
              trace(sa);
              to confirm whether or not the array has been shuffled.  Hopefully I didn't mess up translating it from what would have been a more AS3 compatible version.
              • 4. Re: randomize mp3 player
                andib311 Level 1
                Sorry but I still seem to be having difficulty with this. The Array just doesn't want to shuffle.
                I moved both the function and call to it after the command to load the xml.playlist.
                I've moved the function and call around a few other points in the code too but all to no avail...
                • 5. Re: randomize mp3 player
                  I can't be sure where you are with the code at the moment, but...
                       trace(sa); // before shuffle
                       // shuffle the array after it is created
                       sa = shuffle(sa);
                       trace(sa); // after shuffle
                       playSong();
                  • 6. Re: randomize mp3 player
                    andib311 Level 1
                    Thanks for all your help Ned.
                    Your last message matches how I had set out my code, and still it did not work. THEN, when uploading the site to the server via Dreamweaver's FTP, I selected yes rather than no to "upload independant files" along with all the pages and .as files, and now the mp3 player does seem to play a different track upon load. I'm not sure why this has had an affect - I usually select no so that I don't have to sit by and watch all the .swf and .flv files that link from the pages upload as well.
                    So I guess it's all working now....
                    Thanks again!
                    • 7. Re: randomize mp3 player
                      You're welcome
