6 Replies Latest reply on Sep 7, 2009 9:41 AM by Whitetimer
    Custom Event Help
    Whitetimer Level 1
      Hi All
      I have a simple custom MenuBar Component that dispatches a CustomEvent
                  // COMPONENT METHODS
                  private function menuClickHandler(event:MenuEvent):void
                      var menuEvtObj:MenuEvent = new MenuEvent("MenuClickHandler");
                      dispatchEvent(menuEvtObj);
      I instantiate the Custom Component at the Application Level and have an event listener and method
                    private function initAPP():void
                     applicationMenu.addEventListener(MenuEvent.ITEM_CLICK, menuClickItemHandler);
                    private function menuClickItemHandler(event:MenuEvent):void
                     var menuSelected:Container;
                     menuSelected == event.item.@id;
                     appVS.selectedChild = menuSelected;
      What i am trying to do is to set the Viewstack selectedChild for the id property of the menuBar itemClick
      What am i doing wrong ?
      Many Thanks
        • 1. Re: Custom Event Help
          Andrew Rosewarn Level 3
          Hi there.
          The first thing you need to do is create a custm event that extends the event classs like the one below;
          package
              import flash.events.Event;
              public class CustomEvent extends Event
                  public var childIndex:int;
                  public function CustomEvent(type:String, childIndex:int, bubbles:Boolean=false, cancelable:Boolean=false)
                      super(type, bubbles, cancelable);
                      this.childIndex = childIndex;
          This event now contains a new propery called childIndex.
          Now in your custom menu component you need to dispatch the custom event with the child index you wish to view in the viewstack
          My Menu Comp
          <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="400" height="300" creationComplete="initCollections();">
            <mx:Script>
                  <![CDATA[
                      import mx.events.MenuEvent;
                      import mx.controls.Alert;
                      import mx.collections.*;
                      [Bindable]
                      public var menuBarCollection:XMLListCollection;
                      private var menubarXML:XMLList =
                              <menuitem label="Menu1" data="top">
                                  <menuitem label="Child 1" data="0"/>
                                  <menuitem label="Child 2" data="1"/>
                              </menuitem>
                      // Event handler to initialize the MenuBar control.
                      private function initCollections():void {
                          menuBarCollection = new XMLListCollection(menubarXML);
                      // Event handler for the MenuBar control's itemClick event.
                      private function menuHandler(event:MenuEvent):void  {
                         var custEvent:CustomEvent = new CustomEvent('menuClick',event.item.@data);
                          dispatchEvent(custEvent);
              </mx:Script>
                  <mx:MenuBar labelField="@label" itemClick="menuHandler(event);"
                      dataProvider="{menuBarCollection}" />
          </mx:Canvas>
          You can see in my menu comp I store the indexes of the viewstack components in the data of the menu.  And then when I dispatch the event after a click I put data propert (index) into the clildIndex property of the component.  I give the event the name 'menuClick'
          Now in my app I add my component, and a listener for the menuClick.  And in the event handler I set the index of the viewstack to that of the events childIndex property.
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"   xmlns:ns1="*" creationComplete="addListener()">
              <mx:Script>
                  <![CDATA[
                      private function addListener():void {
                          myMenu.addEventListener('menuClick', handleMenuClick);
                      private function handleMenuClick(event:CustomEvent):void {
                          viewstack1.selectedIndex = event.childIndex;
              </mx:Script>
              <ns1:MenuBarComp id="myMenu" width="514" height="54">
              </ns1:MenuBarComp>
              <mx:ViewStack id="viewstack1" width="200" height="200">
                  <mx:Canvas label="View 1" width="100%" height="100%">
                      <mx:Label x="10" y="10" text="Child 1"/>
                  </mx:Canvas>
                      <mx:Label x="10" y="10" text="Child 2"/>
                  </mx:Canvas>
              </mx:ViewStack>
          </mx:Application>
          I hope this helps.
          Andrew
          • 2. Re: Custom Event Help
            Whitetimer Level 1
            Hi Andrew
            Thanks for the reply, but i do have another question.  Instead of using the property childIndex:int in the custom event, i would prefer to use a selectedChild:String which would reference the ID attribute on the XMLList.  Thereby the XMLList ID would equal the Viewstack selectedChild
            Many thanks
            • 3. Re: Custom Event Help
              Yes same sort of thing
              Custom event
              package
                      public var childId:String;
                      public function CustomEvent(type:String, childId:String, bubbles:Boolean=false, cancelable:Boolean=false)
                          this.childId = childId;
              Menu Comp
                <mx:Script>
                      <![CDATA[
                          [Bindable]
                                      <menuitem label="Child 1" data="child1"/>
                                      <menuitem label="Child 2" data="child2"/>
                                  </menuitem>
                  </mx:Script>
              </mx:Canvas>
              Main app
                  <mx:Script>
                      <![CDATA[
                          import mx.core.Container;
                              for each (var cont:Container in viewstack1.getChildren()) {
                                  if (cont.id == event.childId) {
                                      viewstack1.selectedChild = cont;
                                      break;
                  </mx:Script>
                  </ns1:MenuBarComp>
                      <mx:Canvas id="child1" label="View 1" width="100%" height="100%">
                      </mx:Canvas>
                      <mx:Canvas id="child2" label="View 1" width="100%" height="100%">
                      </mx:Canvas>
                  </mx:ViewStack>
              </mx:Application>
              Andrew
              • 4. Re: Custom Event Help
                Whitetimer Level 1
                Hi Andrew ..
                Ok thanks, have tried your suggestion and now i have an error at the Application level
                Access of possibly undefined property selectedChildId through a reference with static type UWTH.Events:MenuClickEvent
                THIS IS MY CUSTOM EVENT
                package UWTH.Events
                    public class MenuClickEvent extends Event
                        public var selectedChildID:String;
                        public function MenuClickEvent(type:String, selectedChildID:String)
                            super(type);
                            this.selectedChildID = selectedChildID;
                THIS IS MY CUSTOM MENUBAR
                <mx:MenuBar
                    width="800" dataProvider="{menuBarCollection}"
                    labelField="@label"
                    itemClick="menuHandler(event)"
                    <mx:Script>
                        <![CDATA[
                            // COMPONENT IMPORTS
                            import UWTH.Events.MenuClickEvent;
                            import mx.collections.XMLListCollection;
                            // COMPONENT VARIABLES
                            [Bindable]
                                menuBarCollection = new XMLListCollection(appMenuData);
                                var custEventObj:MenuClickEvent = new MenuClickEvent('menuClick',event.item.@id);
                                dispatchEvent(custEventObj);
                    </mx:Script>
                    <mx:XMLList id="appMenuData">
                        <menuitem label="Home">
                            <submenu label="Home" id="vHome" />
                        </menuitem>
                THIS IS MY APPLICATION
                    initialize="initAPP()">
                    <mx:Script>
                        <![CDATA[
                            // APPLICATION IMPORTS
                            import UWTH.components.ApplicationMenuBar;
                            // APPLICATION VARIABLES
                            [Bindable]
                            private var applicationLabelText:String;
                            [Bindable]
                            // APPLICATION METHODS
                                applicationMenu.addEventListener('menuClick', handleMenuClick);
                            private function handleMenuClick(event:MenuClickEvent):void {
                                for each (var cont:Container in appVS.getChildren()) {
                                    if (cont.id == event.selectedChildId) {
                                        appVS.selectedChild = cont;
                                        break;
                    </mx:Script>
                    <mx:Style source="Assets/CSS/app.css" />
                    <Comp:ApplicationMenuBar id="applicationMenu" />
                    <mx:Spacer height="150" />
                    <mx:Label id="appLabel" width="800" text="[ {appVS.selectedChild.label} ]" fontSize="18" />
                    <mx:ViewStack id="appVS">
                        <Views:V_VHome id="vHome" />
                        <Views:V_About id="vAboutUs" />
                    </mx:ViewStack>
                Many Thanks
                Whitetimer
                • 5. Re: Custom Event Help
                  TheFlexGuy
                  It's case sensitive.  You have a lower-case 'd' in selectedChildId that should be upper-case
                                 break;
                  -Marty [ http://www.theflexguy.com ]
                  Helpful/Answered? Please mark it as such.
                  • 6. Re: Custom Event Help
                    Whitetimer Level 1
                    Hi FlexGuy
                    I just spotted that, duh, after all it is Monday ... haha
                    Anyway, thanks for pointing it out..
                    Whitetimer
