2 Replies Latest reply on Sep 7, 2009 7:00 AM by beermatt
    offset expression
    beermatt Level 1
      Hi, If I link an effect (say blur) to another (say scale) via an expression using the pick whip, can I offset the link?  That is: if the scale paramaters go from 50% to 100% can I have the blur start at 0% and go to 50%?  If not can I have some kind of "invisible effect" that has no effect but to which I can link other effects?
      You can probably tell I am very new at this.
      Regards, Matt.
        • 1. Re: offset expression
          yenaphe Adobe Community Professional
          Yes you can. in your expression field after you pick whipped your scale property you should have something like that:
          this.comp.layer("your layer").transform.scale
          and you just have to add a -50 to offset it:
          this.comp.layer("your layer").transform.scale-50
          You can do math operation as long as the expression values are numbers:
          this.comp.layer("your layer").transform.scale*2
          even between two linked properties
          this.comp.layer("your layer").transform.scale / this.comp.layer("your layer").transform.rotation
          etc...
          Hope that helps
          • 2. Re: offset expression
            beermatt Level 1
            Hi Sebastien.  Many thanks.  One more thing, how do I edit the expression field afterwards.  i.e. I have put in a -50 offset but would like to change it to a -40 offset.
            Many thanks, Matt.
            Edited... Doh!  I worked it out.
