2 Replies Latest reply: Sep 9, 2009 7:21 PM by John.Kordas RSS
    JS CS3 copy, paste and transform
    John.Kordas Community Member
      I have a script that allows the user to select objects on a page (in this case text frames) and create a new page user defined and then paste the selection on the page and make it fit the page size.
      I'm having a slight problem where the text frames in the group are not showing the text (get text overflow) after the resize. If I comment out the myGroup.geometricBounds = [0,0,38,38]; line in the script below and manually resize the group to the document height and width (38,38) the text frames in the group are all ok.
      var myNewGroup = new Array;
      for (i=app.selection.length-1; i>=0; i--) {
      myNewGroup.push (app.selection[i]);
      var myGroup = app.activeDocument.groups.add(myNewGroup);
      myGroup.move(Array(0,0) )
      If anyone has any suggetions it would be greatly appreciated.
      John.
        • 1. Re: JS CS3 copy, paste and transform
          I've attached an indesign doc as an example. If I select the group and use the following line:
          app.selection[0].geometricBounds = [0,0,38,38];
          The group frame is resized but the content is not and all the text frames overflow.  Is there a way to resize the frame and also affect the content, the same way you would manually hold Ctrl and resize the frame?
          John.
          • 2. Re: JS CS3 copy, paste and transform
            This seems to be working. I went with the transform() in the end. If anyone has a better way please let  me know.
                 //make group
                   //get size of group
              var mySelSize = myGroup.geometricBounds;
                     //get size of document
                var myDocHSize = app.activeDocument.documentPreferences.pageHeight;
                var myDocWSize = app.activeDocument.documentPreferences.pageWidth;
                     //get scale value
                var myScalH = myDocHSize/mySelSize[2];
                var myScalW = myDocWSize/mySelSize[3];
                     //apply transform scale
                var myScaleMatrix = app.transformationMatrices.add({horizontalScaleFactor:myScalW, verticalScaleFactor:myScalH});
                myGroup.transform(CoordinateSpaces.pasteboardCoordinates,AnchorPoint.topLeftAnchor, myScaleMatrix);
