1 Reply Latest reply on Sep 8, 2009 10:18 AM by Flex harUI
    how to mention the array index to the arraycollection
    sathiyabala
      hai
              Can any one help me for this problem, i need to mention the array index to the array collection for a slider move..
              i have done in this way, below is the code...
               i am not getting the solution by this code.
               Emergency pl
              Thanks in advance....
      private
      function sliderChangeEvent(event:SliderEvent):void
      var
      i:int;
      var
      selectedAuditSummaryRows:String = ""
      var
      selectedvalues:String = ""
      var
      parentnode:String = tree1.selectedItem.parent().@label.toString();
      var
      node:String = tree1.selectedItem.@label.toString();
      var
      selectedArray:Array = auditsummary.selectedItems;
      var
      orderDefaultSummary:ArrayCollection = new
      ArrayCollection();
      for
      (i=0; i<selectedArray.length; i++){
      if(selectedArray[i].Audit == "HIGH"
      orderDefaultSummary.addItemAt(selectedArray[i].Audit+
      +selectedArray[i].Count, 0);
      else if(selectedArray[i].Audit == "MEDIUM"
      +selectedArray[i].Count, 1);
      else if(selectedArray[i].Audit == "LOW"
      orderDefaultSummary.addItemAt(selectedArray[i].Audit+"="+selectedArray[i].Count, 2);
      if
      (orderDefaultSummary.length > 0){
      selectedAuditSummaryRows = orderDefaultSummary.getItemAt(0)+
      ","+orderDefaultSummary.getItemAt(1)+","+orderDefaultSummary.getItemAt(2) as
      String
      if
      (selectedArray.length == 0){
      nodata.visible =
      true
      datecomp.visible =
      false
      complianceQuery = ComplianceDisplaySubmit();
      var
      sliderval:int = (dayslider.value);
      var parameters:Object = {selectedvalues:complianceQuery, parentNode:parentnode, folderID:node, displayDate:sliderval, selectedauditRow:selectedAuditSummaryRows, FlexActionType:"DRAGSLIDER"
      treeListClick.send(parameters);
      CursorManager.setBusyCursor();
