10 Replies Latest reply on Sep 9, 2009 2:09 AM by Anitha Selvaraj
    How to duplicate pages effectively
    Anitha Selvaraj Level 2
      Hi all,
      we want to create 1000 page document from a single page template, hence we create pages using duplication.
      "for (var i=1; i<noOfPages; i++){
              myDocument.pages.item(0).duplicate(LocationOptions.AT_END,myFirstPage);
      During debugging we found the page creation time increases linearliy with increase in page
      ie creation of page is as following
      1st - 1sec
      2nd - 1sec
      3rd - 1sec
      10th - 3sec
      100th-40sec.
      Is there an alternate approach to acheive the above work ?
        • 1. Re: How to duplicate pages effectively
          Harbs. Level 6
          First of all, it should be:
          myDocument.pages.item(0).duplicate(LocationOptions.AFTER,myFirstPage);
          About your problem:
          You need to clear the undo stack. Doing a "save as" every once in a
          while does the trick.
          Harbs
          • 2. Re: How to duplicate pages effectively
            Thanks Harbs,
            But hw to disable Undo ?
            • 3. Re: How to duplicate pages effectively
              Harbs. Level 6
              You can't disable it. Doing a "save-as" clears it.
              Harbs
              • 4. Re: How to duplicate pages effectively
                Iam trying to create a document dynamically with n number of pages using
                The above code loops through till all the empty pages are created.
                The execution time for each duplication takes around 2-3 sec at the very beginning and increases linearly.
                So if there are 500 pages... then the server response is very bad.. is this because of the undo/redo stack?
                • 5. Re: How to duplicate pages effectively
                  Harbs. Level 6
                  Use doc.documentPreferences.pagesPerDocument = yourNumber
                  Harbs
                  • 6. Re: How to duplicate pages effectively
                    Still the performance is same ...
                    • 7. Re: How to duplicate pages effectively
                      Harbs. Level 6
                      Huh?
                      That should add all the pages at once. There should not be any
                      performance problems at all.
                      Harbs
                      • 8. Re: How to duplicate pages effectively
                        Thanks for all your quick responses.
                        We feel are creating the pages in the following way
                        function createPages(noOfPages){
                            myDocument.documentPreferences.pagesPerDocument = noOfPages;
                                alert ("--page number "+ i);
                        Is this the correct way of creation or we missing something ?
                        • 9. Re: How to duplicate pages effectively
                          Harbs. Level 6
                          No. You are creating the pages twice (i.e. double your desired number
                          of pages.
                          Once you set the number of pages using pagesPerDocument, you don't
                          need your loop at all.
                          Harbs
                          • 10. Re: How to duplicate pages effectively
                            // Main Script
                            try{
                                            // We have template with one page
                                            var myDocument = app.open (templateName, true);
                                            // Read a xml file of fetches the values which are substituted into the template like text and images
                            createPages(noOfPages); // We have found the number pages to be generated
                                            placePageFooterElements(noOfPages);
                                            // Finally export  the document into pdf format
                            catch(e){
                                            logError(e + ": ERROR" );
                                            throw(e);
                                            Scenario 1:
                                            // If I create document using the below script I get error during [pageTextFrames.itemByName("pageNo").associatedXMLElement.xmlElements as undefined - placePageFooterElements(noOfPages)]
                            function placePageFooterElements(noOfPages){
                                            for (var pageNo=0; pageNo<noOfPages; pageNo++){
                                                            //Assigning labels for all imageFrames and textFrames - label will be same as that of markupTagName
                                                            //for imageFrames
                                                            alert ("---pageNo---"+pageNo);
                                                            var pageImageFrames = myDocument.pages.item(pageNo).rectangles;
                                                            for(var l=0;l<pageImageFrames.length;l++) {
        try {
        pageImageFrames.item(l).label = pageImageFrames.item(l).associatedXMLElement.markupTag.name;
        }catch(e) {
                                                            }//end of pageimageFrames loop
                                                            //for textFrames
                                                            var pageTextFrames = myDocument.pages.item(pageNo).textFrames;
                                                            for(var l=0;l<pageTextFrames.length;l++) {
        try {
        pageTextFrames.item(l).label = pageTextFrames.item(l).associatedXMLElement.markupTag.name;
        }catch(e) {
                                                            }//end of pageTextFrames loop
                                                            //placing pageFooter elements
        pageTextFrames.itemByName("pageNo").associatedXMLElement.xmlElements.item("currentPage").c ontents = String(pageNo +1);
                                                            pageTextFrames.itemByName("pageNo").associatedXMLElement.xmlElements.item("totalPages").co ntents = String(noOfPages);
                                                            pageTextFrames.itemByName("userId").contents = userName;
                                                            pageTextFrames.itemByName("printedDate").associatedXMLElement.xmlElements.item("dateCreate d").contents
        = String(date.getMonth() + 1) + "-" + String(date.getDate()) + "-" + String(date.getFullYear());
                                                            pageTextFrames.itemByName("pageBody").strokeWeight = 1;
                                                            pageTextFrames.itemByName("pageBody").strokeColor = myDocument.swatches.item("c0m0y0k80");
                                                            pageTextFrames.itemByName("pageHeader").strokeWeight = 1;
                                                            pageTextFrames.itemByName("pageHeader").strokeColor = myDocument.swatches.item("c0m0y0k80");
                                                            pageTextFrames.itemByName("pageFooter").strokeWeight = 1;
                                                            pageTextFrames.itemByName("pageFooter").strokeColor = myDocument.swatches.item("c0m0y0k80");
