0 Replies Latest reply on Sep 8, 2009 2:24 AM by marekplichta
    Custom Keyboard Shortcuts mixing up
    marekplichta
      In Flash Cs 4 my custom made shortcuts mixing up after a while. A command is 'stealing' the shortcut of another command. So that two F-keys trigger the same command. This happens after a while of using flash or after startup. It occurs everytime. I then have to manually switch back the shortcuts which is very annoying. It happens always to the same shortcuts.
      I had this problem earlier but in flash only.
      I attached the .MFX file where the shortcuts are stored.
      Any help?
      –Marek
