0 Replies Latest reply on Sep 8, 2009 7:43 AM by Darrell Loverin
    [svn:fx-trunk] 10050: Per-Module Style Management: Create a style manager for each application/module.
    Darrell Loverin Level 4
      Revision: 10050
      Author:   dloverin@adobe.com
      Date:     2009-09-08 07:43:16 -0700 (Tue, 08 Sep 2009)
      Log Message:
      The singleton StyleManager is still the only style manager that is currently used.
      QE notes: None.
      Doc notes: None.
      Bugs:
      Reviewer: Alex
      Tests run: checkintests, Managers/StyleManager
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IFlexModuleFactory.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/Request.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ISystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/modules/IModuleInfo.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/modules/ModuleLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/modules/ModuleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/IStyleManager2.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
