2 Replies Latest reply on Sep 8, 2009 8:53 AM by bk843746
    Data grouping
    bk843746
      Hi
      Is there an easy way to convert variable one into variable two?
      var one:ArrayCollection = new ArrayCollection([
        {type:"1", name:"a", value:"test1"},
        {type:"1", name:"b", value:"test2"},
        {type:"2", name:"a", value:"test3"},
        {type:"3", name:"a", value:"test4"}
      var two:ArrayCollection = new ArrayCollection([
        {name: "1", children: [
          {name:"a", value:"test1"},
          {name:"b", value:"test2"}
        {name: "2", children: [
          {name:"a", value:"test3"}
        {name: "3", children: [
          {name:"a", value:"test4"}
      It's fine if variable two still has the type method in the child records.
        • 1. Re: Data grouping
          Andrew Rosewarn Level 3
          Hi
          Well unless anyone else knows of some functions....  This works
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="makeNewArray();">
              <mx:Script>
                  <![CDATA[
                      import mx.collections.ArrayCollection;
                      private var groupList:Array;
                      private var one:ArrayCollection = new ArrayCollection([
                      private function createGroupList():void {
                          groupList = new Array();
                          var alreadyAdded:Boolean;
                          groupList.push(one.getItemAt(0).type);
                          for (var i:int = 1; i<one.length; i++) {
                              alreadyAdded = false;
                              var type:String = one.getItemAt(i).type;
                              for (var j:int = 0; j<groupList.length; j++) {
                                  if (groupList[j] == type) {
                                      alreadyAdded = true;
                                      break;
                              if (!alreadyAdded) {groupList.push(type)};
                      private function makeNewArray():void {
                          // Create a unique group list
                          createGroupList();
                          // Create new arrayCollection
                          var two:ArrayCollection = new ArrayCollection();
                          // Loop through unique group list
                          for (var i:int =0; i<groupList.length; i++) {
                              var type:Object = new Object();
                              type.name = groupList[i];
                              // Loop through the orginial one array
                              var children:Array = new Array();
                              for each (var obj:Object in one) {
                                  trace (groupList[i] + ' : ' + obj.type)
                                  if (groupList[i].toString() == obj.type.toString()) {
                                      var child:Object = new Object();
                                      child.name = obj.name;
                                      child.value = obj.value;
                                      children.push(child);
                              type.children = children;
                              two.addItem(type);
              </mx:Script>
          </mx:Application>
          Hope it helps
          Andrew
          • 2. Re: Data grouping
            bk843746 Level 1
            Hi
            I was looking at the GroupingCollection but I couldn't get it to work correctly. Would this class or any other classes in the mx.collections namespace do the job?
