1 Reply Latest reply on Sep 8, 2009 9:13 AM by RobRZDZ
    setProcessDataListValue causes Jboss to use 100% CPU
    RobRZDZ Level 1
      Hello everybody.
      This is LCES 8.2.1 SP2 running on Windows 2003 server (turnkey).
      Today I gave the executeScript a try but it seems the setProcessDataListValue causes Jboss to use 100% of the available CPU cycles and has to be stopped.
      Here's the script I'm using:
      === cut here === 8<===
      import java.util.List;
      import java.util.Iterator;
      import com.adobe.idp.Document;
      List attachList = patExecContext.getProcessDataListValue("/process_data/doclist");
      List newList = patExecContext.getProcessDataListValue("/process_data/doclisttask");
      newList.clear();
      Iterator it = attachList.iterator();
      while(it.hasNext()) {
              Document attDoc = (Document) it.next();
              String name = (String) attDoc.getAttribute("name");
              attDoc.setAttribute("wsfilename",name);
              newList.add(attDoc);
      attachList.clear();
      patExecContext.setProcessDataListValue("/process_data/doclisttask",newList);
      In WorkBench, both doclist and doclisttask have Type=list and SubType=document.
      By putting some System.out.println into the above script I've been able to verify that the process seems to hang while executing the patExecContext.setProcessDataListValue("/process_data/doclisttask",newList); before getting to the last line, I've been also able to check that "name" (String) is set correctly and that newList.add(attDoc) does return true (doclist has 2 document).
      At this point, Jboss does consume all the available CPU and I have to manually stop it; I checked against Jboss log file but no error messages and or exceptions are reported.
      What am I missing?
      Rob
        • 1. Re: setProcessDataListValue causes Jboss to use 100% CPU - SOLVED
          RobRZDZ Level 1
          Problem solved.
          It turned out that you do not need to "import" a LCES variable if you plan to initialize it into the script.
          At the benefit of future posters/seekers, here's the script which works:
          === cut here === 8< ===
          List newList = new ArrayList();
                  if (newList.add((Document)attDoc) != true) {
                          System.out.println("Error while inserting!");
          Cheers,
          Rob
