Hi, I am using Captivate 4.0.0 Build 1596 on WIn XP Pro SP2. The SWF files I am using are screen recordings from BB Flashback Pro 2.6.3 Build 1205(http://www.bbsoftware.co.uk)
The SWF files are 1280 x 1024 and when I export them they have the following settings:
Full Frame Rate (14 FPS)
SWF Format
Lossless Compression
No Audio
Exporting frames 0 - 420
HERE IS THE PROBLEM:
In Internet Explorer 7 the SWF files loads just fine and takes 30 seconds to play from beginning to end. (420/14 = 30 seconds)
When I load it into Captivate 4.0.0 it is now only 14.1 seconds long and there are 422 frames?
If I export it at 30 fps I get a file that imports into Captivate that is 30 seconds in length but is now 901 frames?
Seeing as how you can only have 16000 frames I am now limited to roughly 8.5 min for my SWF file.
Why is Captivate modifying the play time?
I am very new to Captivate and this has been the only real problem I have had so far. If I could get this problem resolved then I would be a very happy camper. Thanks!
Hi there
I've been advised recently by the Captivate development team that the 16,000 frame limitation does not apply to things created using Captivate. Apparently it has something to do with the manner in which they structure the content.
So if that's not an issue the only thing left to worry with is the frame rate mismatch. If you create something that runs at 14 FPS, you need to configure Captivate to run at 14 FPS when you use the same content so there is no mismatch. Or, bump your creation up
...Copy link to clipboard
Hi there
So if that's not an issue the only thing left to worry with is the frame rate mismatch. If you create something that runs at 14 FPS, you need to configure Captivate to run at 14 FPS when you use the same content so there is no mismatch. Or, bump your creation up to 30 FPS to match that of Captivate.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Thank you! I found the publish settings frame rate in the preferences. It was at 30 so I set it to 14 then imported my 14 fps file and it shows as being 30 seconds in length. Just what I was looking for.
It is nice to know that there is no limits on things created with captivate but all my video was made with BB Flashback Pro and it follows those limitations.
Thanks again!
