1 Reply Latest reply on Sep 8, 2009 10:32 PM by sstanleyau
    Get preflight Working Profile as AS variable
    sgleasonil2
      Syntax, syntax, syntax.
      I have a list of thirty or so different document sizes maintained in a FileMaker database. It works great to pass variables through to build InDesign files. My designers would also like placeholder Photoshop files, but I'd rather not have them taking up disk space unless the files are absolutely needed. And the specs change often, so I'd like as much as possible to be data driven. So, I'd like to have a script that pulls page height and width and resolution requirements to Photoshop.
      I'm having no trouble with the
      We use preflight profiles that are named with the proper required image resolution ("72", "150", 300" etc.) and they are properly embedded in the InDesign file.
      Does anyone know the syntax for getting the name of the embedded preflight Working Profile to pass through in a script?
      tell application "Adobe InDesign CS4"
      set myDocument to active document
      set horizontal measurement units of view preferences to inches
      set vertical measurement units of view preferences to inches
      tell document preferences of myDocument
      set myPageWidth to page width
      set myPageHeight to page height
      set myProfile to preflight Working Profile
      end tell
      end tell
      tell application "Adobe Photoshop CS4"
      set myDocument to make new document with properties {width:myPageWidth, height:myPageHeight}
      tell myDocument
      resize image resolution myProfile
      end tell
      end tell
