5 Replies Latest reply on Oct 9, 2009 2:42 AM by flex_n00b
    Problems in HTTPService with PHP
    flex_n00b Level 1
      This is the Flex code that I have-
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="do_work()">
          <mx:HTTPService id="find_college" fault="errorhandler(event)"   result="resulthandler(event)" showBusyCursor="true" method="GET"  useProxy="false" >
          </mx:HTTPService>
          <mx:Script>
              <![CDATA[
              import mx.collections.ArrayCollection;
              import mx.rpc.events.ResultEvent;
              import mx.controls.Alert;
              import mx.rpc.events.FaultEvent;
              [Bindable]private var collegeData:ArrayCollection = new ArrayCollection();
              private function do_work():void
                  find_college.url="http://localhost/take2.php?name=pqr"
                              find_college.send();
                  private function errorhandler(e:FaultEvent):void
                  Alert.show(e.fault.message,"Server Error");
                  private function resulthandler(e:ResultEvent):void
                      collegeData = e.result.mydata;
          </mx:Script>
          <mx:ComboBox id="college_list" x="464" y="229" dataProvider="{collegeData}" labelField="name">
              </mx:ComboBox>
      </mx:Application>
      and the take2.php contains-
      echo("<mydata>".$_GET['name']."</mydata>");
      Problem is that the ComboBox does not fill with the value of the GET variable, it says transferring from localhost indefinitely.
        • 1. Re: Problems in HTTPService with PHP
          Madhav Subedi Level 4
          try changing your php code as:
          echo("<mydata><name>".$_GET['name']."</name></mydata>");
          right now, you are providing the labelfield as NAME but your collection doesnot contain the NAME field.
          • 2. Re: Problems in HTTPService with PHP
            flex_n00b Level 1
            I tried that, but same problem persists
            • 3. Re: Problems in HTTPService with PHP
              drillnaut Level 1
              Not sure I can help but here is how I do it when fighting working with xml.  First off , declare the resultFormat of the HTTPService to be "e4x".  Then make an xml list of the result , grab the name from the list objects , stuff that name into a new object , then finally stuff that object into the collegeData arraycollection.  It may be a little roundabout but it works for me ... sometimes.
              <mx:HTTPService id="find_college" resultFormat="e4x" fault="errorhandler(event)"   result="resulthandler(event)" showBusyCursor="true" method="GET"  useProxy="false" >
              </mx:HTTPService>
              <mx:Script>
                  <![CDATA[
                              var resultXML:XML = e.result as XML;
                              var nameList:XMLList = resultXML..name;
                              for each(var nameXML:XML in nameList)
              //                   var name:String = nameXML.name.toString();
              //                   or maybe its
                                  var name:String = nameXML.toString();
                                  var object:Object = new Object();
                                  object['name'] = name;
                                  collegeData.addItem(object);
                  </mx:Script>
                  <mx:ComboBox id="college_list" x="464" y="229" dataProvider="{collegeData}" labelField="name" />
              </mx:Application>
              Message was edited by: drillnaut Accidently hit enter , my bad.
              • 4. Re: Problems in HTTPService with PHP
                satoshi.ara Level 1
                     resultFormat="xml"
                     method="GET"
                     useProxy="false" >
                    </mx:HTTPService>
                    <mx:Script>
                        <![CDATA[
                        [Bindable]private var collegeData:XMLList = new XMLList();
                            find_college.url="http://localhost/take2php?name=pqr"
                          collegeData = XML(e.result).mydata;
                    </mx:Script>
                    </mx:ComboBox>
                </mx:Application>
                /* take2.php
                <?php
                $x  = "<?xml version=\"1.0\" encoding=\"utf-8\" ?>";
                $x .= "<xmlbody>";
                $x .= "<mydata>".$_GET['name']."</mydata>";
                $x .= "</xmlbody>";
                header("Content-Type: text/xml");
                header("Content-Length: ".strlen($x));
                print($x);
                • 5. Re: Problems in HTTPService with PHP
                  flex_n00b Level 1
                  Thanks for the last post, it worked
