2 Replies Latest reply on Sep 11, 2009 2:20 PM by rul987
    Change States using Menu Bar
    rul987
      I am new to flex. The first website I made I used states for navigation. I made states for another small site I am working on.
      This is the problem I have, I need to change states using the MenuBar. I know I should listen for clickevents but I am not sure how to do the
      linking. Most online help and reference material I have use Navigation Containers. However I don't want to change the states.
      Just wondering if someone has some code which uses menu bar and states together.
        • 1. Re: Change States using Menu Bar
          Andrew Rosewarn Level 3
          Hi there
          Take a look at this example;
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="initCollections();" >
              <mx:states>
                  <mx:State name="state2">
                      <mx:RemoveChild target="{label1}"/>
                      <mx:AddChild position="lastChild">
                          <mx:Label text="THIS IS STATE 2"/>
                      </mx:AddChild>
                  </mx:State>
              </mx:states>
              <mx:Script>
                  <![CDATA[
                      import mx.events.MenuEvent;
                      import mx.controls.Alert;
                      import mx.collections.*;
                      [Bindable]
                      public var menuBarCollection:XMLListCollection;
                      private var menubarXML:XMLList =
                              <menuitem label="Menu1" data="top">
                                  <menuitem label="First State" data=""/>
                                  <menuitem label="Second State" data="state2"/>
                              </menuitem>
                    private function initCollections():void {
                          menuBarCollection = new XMLListCollection(menubarXML);
                      private function menuHandler(event:MenuEvent):void  {
                          currentState = event.item.@data;
              </mx:Script>
          <mx:MenuBar labelField="@label" itemClick="menuHandler(event);"
                  dataProvider="{menuBarCollection}" />
               <mx:Label text="THIS IS STATE 1 - DEFAULT" id="label1"/>
          </mx:Application>
          I hope this helps, make sure you call your states the same as the data attribute in the XML
          Andrew
          • 2. Re: Change States using Menu Bar
            rul987 Level 1
            Thanks Andrew, I am going to try this out and see if it works.
