4 Replies Latest reply on Sep 10, 2009 5:11 AM by GArlington
    CFC Error on QoQ
    emmim44 Level 1
      Error:
      Error casting an object of type to an incompatible type. This usually indicates a programming error in Java, although it could also mean you have tried to use a foreign object in a different way than it was designed.
      The error occurred in C:\Inetpub\wwwroot\RMS\Untitled-3.cfm: line 15
      13 :                     <cfloop from="1" to ="#listlen(application.Sql_SC)#" index="i">
      14 :                     union
      15 :                          <cfquery name="GetZone#i#" datasource="#i#">
      16 :                          SELECT ccflocationID, Location_Name
      17 :                          FROM ccflocation
      <cfcomponent hint="This cfc goes to Scorecard environment and grabs some stuff">
      <cffunction name="Zone" access="public" returntype="Query">
      <cfset myLoc = QueryNew("ccflocationID,Location_Name", "Integer,VarChar")>
      <cfargument name="DSN" required="true" type="string">
      <cfquery dbtype="query" name="GetZone">
      select ccflocationID, Location_Name from myLoc
      <cfloop from="1" to ="#listlen(arguments.DSN)#" index="i">
        union
         FROM ccflocation
        </cfquery>
      </cfloop>
      </cfquery>
      <cfreturn GetZone>
      </cffunction>
      </cfcomponent>
        • 1. Re: CFC Error on QoQ
          Dan Bracuk Level 5
          You are trying to ignoring what I told you in the other thread and attempting to combine Q of Q and database queries.  You have to do them separately.
          • 2. Re: CFC Error on QoQ
            emmim44 Level 1
            I am not ignoring you Dan, I followed your recipe and ends up here... what else not in place???
            • 3. Re: CFC Error on QoQ
              Adam Cameron. Level 5
              See my reply in the other thread you raised about this problem.
              Adam
              • 4. Re: CFC Error on QoQ
                GArlington Level 1
                You can NOT mix QoQ and DB queries together...
                this is QoQ
                this is DB query
                You will need to run your DB queries first (outside QoQ)
                and then run the loop again to UNION all results...
                    FROM ccflocation
                   </cfquery>
                </cfloop>
                  union
                select ccflocationID, Location_Name from GetZone#i#
                </cfloop>
                </cfquery>
