2 Replies Latest reply on Sep 15, 2009 7:25 PM by 372KE
    Issues aligning Check Boxes in a table in LiveCycle Forms
    372KE
      Hi, I've created a form in LiveCycle which includes a table.  In the table I want to insert two columns of tick boxes and center align them.  I've managed to insert them ok but don't seem to be able to control the alignment at all (they just stay right aligned).  I've tried setting the column alignment to centered and also tried a couple of basic commands in the xml source, but without any success.  Has anyone got any ideas?  Ta
        • 1. Re: Issues aligning Check Boxes in a table in LiveCycle Forms
          SForrest96 Level 4
          I was able to centre a checkbox object in a table cell by adjusting the margin settings of the checkbox.  I inserted a checkbox into a table cell, then set the caption position property to "None" (Layout palette), and the Right Margin to "0.5 in" (Layout palette) to centre the checkbox.
          See attached sample form.
          Regards
          Steve
          • 2. Re: Issues aligning Check Boxes in a table in LiveCycle Forms
            372KE Level 1
            Excellent, thanks - just need to do a few adjustment in the measurements
            of the margins and it works perfectly.
            This e-mail is confidential and may contain information subject to legal
            privilege.  If you are not the intended recipient please advise us of our
            error by return e-mail then delete this e-mail and any attached files.
            You may not copy, disclose or use the contents in any way.
            The views expressed in this e-mail may not be those of Gallagher Group
            Ltd or subsidiary companies thereof.
