6 Replies Latest reply on Sep 10, 2009 11:16 AM by Joann Chuang Anderson
    Background Color on Application tag not showing...
    wicket971 Level 1
      I just recently upgraded to the nightly build version # 4.0.0.10045 and the backgroundColor property on the main application tag is no longer rendering the background color. I noticed a new ApplicationSkin.mxml in the spark skins with the following:
              A rectangle with a solid color fill that forms the background of the application.
              The color of the fill is set to the Application's backgroundColor property.
          <s:Rect id="backgroundRect" left="0" right="0" top="0" bottom="0"  >
              <s:fill>
                  <s:SolidColor color="{getStyle('backgroundColor')}" />
              </s:fill>
          </s:Rect>
      However adding a backgroundColor property to the Application tag or in the CSS has not given any results.
        • 1. Re: Background Color on Application tag not showing...
          Joann Chuang Anderson Level 1
          I just tried in 4.0.0.10071 and it works for me:
                         xmlns:mx="library://ns.adobe.com/flex/halo"
                         xmlns:local="*" backgroundColor="0x000000">
          </s:Application>
          If you're in FlashBuilder, you may want to clean your project and rebuild.
          Joann
          • 2. Re: Background Color on Application tag not showing...
            I should add that backgroundColor is now a style not a property on Application, so things like myApp.backgroundColor = 'red' won't work, you'd have to do myApp.setStyle('backgroundColor', 'red').  For example:
                <fx:Script>
                    <![CDATA[
                        import mx.core.FlexGlobals;
                </fx:Script>
                <s:Button click="FlexGlobals.topLevelApplication.setStyle('backgroundColor', 'red')"/>
            </s:Application>
            Clicking on the button will cause the backgroundColor to be red at runtime.
            • 3. Re: Background Color on Application tag not showing...
              wicket971 Level 1
              Ok it turns out it is not the application tag causing problems, but the halo VBoxes, HBoxes and Viewstacks. It seems I can no longer apply background colors to them at all.
              Here's an example:
              <mx:VBox id="footerVBox" horizontalAlign="center" verticalGap="-5" paddingBottom="5" paddingTop="0" backgroundColor="0xFF0000" width="600">
                   <mx:HBox horizontalGap="1" verticalAlign="middle">
                        <mx:Label text="{copyrightSymbol} 2009 SearchIgnite" fontSize="12" color="#003366" />
                        <mx:VRule height="12" strokeColor="#003366"/>
                        <mx:Label text="{'Version ' + version}" fontSize="12" color="#003366"/>
                        <mx:Label text="Customer Service 888-744-6483" fontSize="12" color="#003366" />
                   </mx:HBox>
              </mx:VBox>
              Is rendering with a white background behind it, obsucring the background color of my application. The backgroundColor style property is not getting applied at all.
              Upon rewriting this group as:
              <s:Group id="footerVBox" width="100%">
                   <s:layout>
                        <s:VerticalLayout horizontalAlign="center" paddingBottom="5" paddingTop="5"  />
                   </s:layout>
                   <s:Group>
                        <s:layout>
                             <s:HorizontalLayout verticalAlign="middle" />
                        </s:layout>
                       <s:Label text="{copyrightSymbol} 2009 SearchIgnite" fontSize="12" color="#003366" />
                       <s:Label text="{'Version ' + version}" fontSize="12" color="#003366"/>
                       <s:Label text="Customer Service 888-744-6483" fontSize="12" color="#003366" />
              </s:Group>
              </s:Group>
              I am able to get the background color of the app to show through. Again I am using build version 4.0.0.10045 and this was not an issue in the previous builds.
              • 4. Re: Background Color on Application tag not showing...
                Unfortunately 10045 is an in between build where this wasn't working.  If you get something after 4.0.0.10064 your original code should work as expected.
                Joann
                • 5. Re: Background Color on Application tag not showing...
                  wicket971 Level 1
                  Doh!  =)  Thanks for the response back. I can now move on in my project.
                  • 6. Re: Background Color on Application tag not showing...
                    No problem.  Please do continue to post if you do see issues though, we've only just started testing it.
