4 Replies Latest reply on Sep 10, 2009 10:24 AM by Flex harUI
    Double click on Datagrid cell
    Ferrari_hunk
      I'm developing an application where I'm using a datagrid that shows some information from an xml. Every cell in the grid is of the form
      <itemRenderer>
      <compoment>
      <Vbox>
      <HBox>
      <Text/> //some text goes within this block
      </Hbox>
      </VBox>
      </component>
      </itemRenderer>
      I have set a function call for the datagrid on ItemDoubleClick event; and this even gets triggered only when i double click on any TEXT that is on the cell; and NOT on any part of the cell. However, I would like to have this triggered when the user clicks anywhere in the cell.
      Sombody please help,
      Thanks!!
        • 1. Re: Double click on Datagrid cell
          Flex harUI Adobe Employee
          Not sure I understand, but try setting backgroundColor="0xffffff" backgroundAlpha="0" on the HBox.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Double click on Datagrid cell
            Ferrari_hunk Level 1
            Thanks for the suggestion. Maybe I wasn't clear in explaining the issue here. Let me throw some light now, My code is somewhat like this
            <mx:VBox opaqueBackground="{myxml.@data>10 ?  '0xA2FEA2' : '0xFEA2A2' }" width="100%" height="100%" verticalScrollPolicy="off">
                 <mx:Box width="100%" height="100%">
                      <mx:Text id="txt1" text="Available" width="100%"/>
                       <mx:Text id="txt2" text="{myxml.@data}"/>
                 </mx:Box>
            </mx:VBox>
            The output is shown in the attachment. Now whenever I double click on the text in the datagrid(highlighted in blue in the attachment) my doubleclick even is fired; but if i click anywhere in the cell(green region in the attachment) my doubleclick event is not called.
            Hope this helps! Looking forward for your assistance,
            Thanks again!!
            Cheers
            • 3. Re: Double click on Datagrid cell
              Hi Alex,
              My bad, I had not tried your solution, as I thought the background color that I was setting using the opaqueBackgroundColor(on VBox) would be lost if I set backgroundColor='0xffffff' on HBox. But this seems to have done the trick and it works fine now. I believe flex was not taking HBox to be an "item" as it was blank (even though it had Text fields within). Correct me if I'm wrong.
              Appreciate your help!
              Cheers!
              • 4. Re: Double click on Datagrid cell
                Containers have no background by default so clicks can fall through.
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
