0 Replies Latest reply on Sep 9, 2009 7:45 AM by Paul Reilly
    [svn:fx-trunk] 10087: * Feature: Compiler Errors for Other Theme's Styles
    Paul Reilly
      Revision: 10087
      Author:   preilly@adobe.com
      Date:     2009-09-09 07:44:55 -0700 (Wed, 09 Sep 2009)
      Log Message:
      • Feature: Compiler Errors for Other Theme's Styles
      QE notes: Existing tests will start reporting errors when MXML
                documents with spark style attributes are compiled with the
                halo theme and when halo style attributes are compiled with
                the spark theme.  The same kinds of mismatches in CSS will
                be reported as warnings per the spec.
                For the Mxml document errors, the test should be updated to
                use the styles matching the current theme, the test should
                be compiled with a different theme, or the Style metadata
                should be updated to include the current theme.
                For the CSS warnings, the styles should be changed to match
                the current theme's styles, the styles should be moved to a
                theme specific CSS document, or the Style metadata should be
      Doc notes: New option, -compiler.show-invalid-css-property-warnings added.
      Bugs: SDK-17408
      Reviewer: Corey
      Cycloner: Gaurav
      Tests run: checkintests (new valid warnings are reported)
      Is noteworthy for integration: Yes, see QE notes.
      Code-level description of changes:
        frameworks/tests/basicTests/graphics/views/comps/TextGraphicBasic1.mxml
        frameworks/tests/basicTests/graphics/views/comps/EllipseBasic2.mxml
        frameworks/tests/basicTests/graphics/views/comps/RectBasic3.mxml
          Changed backgroundColor to contentBackgroundColor, because
          Container has backgroundColor declared with the halo theme and
          contentBackgroundColor with the spark theme.
        build.xml
          Corrected case of BasicTests.mxml and BasicTests.swf.  I guess I'm
          still the only one that runs checkintests on a case sensitive OS.
        modules/compiler/src/java/flex2/compiler_en.properties
          Added messages for css.StylesContainer.InvalidStyleProperty,
          css.StylesContainer.InvalidStyleTheme, and
          mxml.builder.ComponentBuilder.InvalidStyleTheme.
        modules/compiler/src/java/flex2/tools/PreLink.java
          Moved backgroundColor handling and StylesContainer validation to
          postRun(), so that it only happens once per compilation.  This
          required passing in the SymbolTable and NameMappings.
          Modified run() to only create a global StylesContainer if one
          hasn't been created.
        modules/compiler/src/java/flex2/tools/CompcPreLink.java
          Updated postRun() to new signature.
        modules/compiler/src/java/flex2/compiler/fxg/FXGCompiler.java
          Added themeNames variable, which is used to create the TypeTable.
        modules/compiler/src/java/flex2/compiler/PreLink.java
          Modified postRun() signature by adding SymbolTable and
          NameMappings args.
        modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          Updated compiler to use the new postRun() signature.
        modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          Modified getParentLoader() to format the super type name before
          looking up the super class.
        modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          Added support for show-invalid-css-property-warnings option.
        modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
          Added default for -theme.
        modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          Removed StylesContainer(CompilationUnit, ContextStatics,
          MxmlConfiguration) constructor.
          Renamed checkForUnusedTypeSelectors() to validate() and added
          logic to check for styles not declared with the current theme and
          styles not declared for a particular type.
        modules/compiler/src/java/flex2/compiler/SymbolTable.java
          Added getClassNames() for use by StylesContainer.validate().
        modules/compiler/src/java/flex2/compiler/mxml/lang/AttributeHandler.java
          Removed 'node' variable and modified constructor to initialize 'type'.
        modules/compiler/src/java/flex2/compiler/mxml/reflect/Type.java
          Added getStyleThemes().
        modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
          Added 'themeNames' variable and modified constructor to initialize
          it.
          Added assert to getType() to make sure the className is in colon
          format.
          Modified getStyle() only return a StyleHelper if the current theme
          is null, the themeNames is null, or the current theme is in
          themeNames.
          Added getStyleThemes() and hasTheme().
        modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          Added showInvalidCssPropertyWarnings() and getThemeNames().
        modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.java
          Modified unknown() to check if localPart is a style, but not
          declared with the current theme.  If so, we report an
          InvalidStyleTheme.  Otherwise, we just report that it's unresolved.
        modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          Modified constructor to set the CompilationUnit's StylesContainer.
        modules/compiler/src/java/flex2/compiler/mxml/MxmlCompiler.java
          Made TYPE_TABLE public, so the css package can share the TypeTable
          rather than create a new one.
        modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
        modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          Modified TypeTable() creation to pass in the configured theme
          names.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-17408
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/EllipseBasic2.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/RectBasic3.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/TextGraphicBasic1.mxml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/CommandLineConfigurator.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/AttributeHandler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/DeclarationHandler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Type.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcPreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
