0 Replies Latest reply on Sep 9, 2009 11:06 AM by Paul Reilly
    [svn:fx-trunk] 10096: * Added flag to make the compiler report invalid styles in MXML as
    Paul Reilly Level 1
      Revision: 10096
      Author:   preilly@adobe.com
      Date:     2009-09-09 11:05:58 -0700 (Wed, 09 Sep 2009)
      Log Message:
      • Added flag to make the compiler report invalid styles in MXML as
        warnings instead of errors.  This should allow folks to ease into
        the new "Compiler Errors For Other Theme's Styles" feature.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey, Gaurav
      Cycloner:
      Tests run: checkintests
      Is noteworthy for integration: No
      Code-level description of changes:
        build.xml
        frameworks/tests/basicTests/graphics/views/comps/TextGraphicBasic1.mxml
        frameworks/tests/basicTests/graphics/views/comps/EllipseBasic2.mxml
        frameworks/tests/basicTests/graphics/views/comps/RectBasic3.mxml
          Revert unnecessary changes from revision 10087.
        modules/compiler/src/java/flex2/compiler_en.properties
          Replaced mxml.builder.ComponentBuilder.InvalidStyleTheme with
          mxml.builder.ComponentBuilder.InvalidStyleThemeError and
          mxml.builder.ComponentBuilder.InvalidStyleThemeWarning.
        modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          Added reportInvalidStylesAsWarnings variable and accessors.
        modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          Modified validate() to actually use themeNamesString.
        modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          Added reportInvalidStylesAsWarnings().
        modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.java
          Modified unknown() to report invalid styles as warnings if
          reportInvalidStylesAsWarnings is true.
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/projects/framework/build.xml
          flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/EllipseBasic2.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/RectBasic3.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/TextGraphicBasic1.mxml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
