1 Reply Latest reply on Sep 17, 2009 7:21 PM by stjonathanmark
    SOAP Response cannot be decoded.
    stjonathanmark
      Hello Everybody,
      I created a simple web service in asp.net using the c# sharp language. The web service extracts data from an MS SQL Database, translates that data in to xml, assigns the xml to a string varible and returns  the string varible to what ever called the service. I know the web service works becuase if you call it in a web browser at the following address http://www.jmmortimer.com/dataaccess/sqlhelper.asmx?wsdl, it will show you the xml that represents web service. Plus, I tested it by calling it in an asp.net application. However when I call it from a Flex 3 application it gives me the following error message. SOAP Response cannot be decoded. Raw response: " faultCode="DecodingError" faultDetail="null" The code that I have in Flex 3 is below. If anyone knows how to solve this problem, please let me know. Thanks in advance.
      <mx:Application
      xmlns:mx=http://www.adobe.com/2006/mxml layout="absolute">
      <mx:Script>
      <![CDATA[
      import mx.rpc.soap.LoadEvent;
      import mx.rpc.events.ResultEvent;
      private function getData(evt:LoadEvent):void
      var connString:String = "Data Source=Family\SQLExpress;Initial Catalog=SDJames;User ID=sa;Password=Password1";
      var storedProc:String = "GetAuxiliaries";
      myService.GetDataTable(connString, storedProc)
      private function resultHandler(evt:ResultEvent):void
      test.text = String(evt.result);
      </mx:Script>
      <mx:WebService id="myService" wsdl="http://jmmortimer.com/dataaccess/sqlhelper.asmx?WSDL"
      load="getData(event)" result="resultHandler(event)" />
      <mx:TextArea id="test" x="10" y="10" width="452" height="348"/>
      </mx:Application>
        • 1. Re: SOAP Response cannot be decoded.
          stjonathanmark Level 1
          Hello Again Everybody,
          I have found the answer to my problem. The Problem was that I had the wrong value assigned the variable "connString" insted of  "Data Source=Family\SQLExpress;Initial Catalog=SDJames;User ID=sa;Password=Password1", it should have been "Data Source=Family\\SQLExpress;Initial Catalog=SDJames;User ID=sa;Password=Password1". Don't you just hate how just  messing up with one character can mess up you entire application. Thanks to everybody who took time to look over my problem.
          God Bless
