2 Replies Latest reply on Sep 10, 2009 3:27 AM by christoferek
    An easy Array question
    christoferek
      Hi All,
      I spoted something strange in this code.
              var tempArr:Array = new Array();
              var temp1:Array = new Array(null, null, null);
              var temp2:Array = new Array(null, null, null);
              var temp3:Array = new Array(null, null, null);
              var temp4:Array = new Array(null, null, new Array());
              tempArr[0] = new Array(1, temp1, temp2, temp3, temp4);
              tempArr[1] = new Array(1, temp1, temp2, temp3, temp4);
              tempArr[2] = new Array(1, temp1, temp2, temp3, temp4);
              tempArr[3] = new Array(1, temp1, temp2, temp3, temp4);
              tempArr[1][4][3] = 55;
      The last line should change only one cell [1][4][3] to 55 but it changed also  [0][4][3],  [1][4][3],  [2][4][3], [3][4][3] all to 55.
      What am I doing wrong?
      Can you help?
      Christoferek
        • 1. Re: An easy Array question
          _Natasha_ Level 4
          "The last line should change only one cell [1][4][3] to 55 but it changed also  [0][4][3],  [1][4][3],  [2][4][3], [3][4][3] all to 55." - This is correct!
          Your tempArr is different objects, but all contain the same objects.
          Then you create an array with objects, not a copy of objects putted to array. A link to this object is putted there.
          So...
          you write
          means...
          tempArr[1][4] === temp4;
          tempArr[1][4][3] === temp4[3];
          temp4 - is an object in tempArr[0] - tempArr[3].
          So then you change an object in temp4[i] also tempArr[0-3][4][i] is changed.
          So
          equivalent
          temp4[3] = 55;
          If you want to have a different objects (copy of objects), use ObjectUtil.copy(...)
          • 2. Re: An easy Array question
            christoferek Level 1
            Thank you. This is it. I've made a mistake and coudn't find it.
            Regards
            Chris
